Question about Sony VAIO FX340 Notebook
Sony PC Notebook system starts but screen does not.
Just the day before my notebook screen just decided to not turn on anymore, it was working just fine. The system starts (I can see the power lights flashing) eventhough it makes no on sound, BUT THE SCREEN IS TOTALLY OFF! it's dead, it doesn't turn on and I have no idea what might be possible reasons for this incident...does anyone have any possible solution or idea?
  • roble2lizara Sep 26, 2008
    I have my old battery off and already replaced my clock battery, but still my vaio can´t start, The green led is ON, but the HD yellow led makes an attempt to get ON but doesn´t go further, the display never gets ON.
    Every once in a while the PC starts but very rarely
    any idea what is the problem?
  • Anonymous Mar 10, 2009
    on my laptop the gren power light turns of but the HD light flashes for a second then goes out and it does not boot up nor does the screen turn on and none of the keys work
It may be the battery, have you replaced yet?. if a battery is too old, instead of providing power, takes some on it. I mean, your old battery may be overloading your PC, just to check, take the battery off, plug the vaio to an outlet and try again to start it up.
If that solves the problem, replacing the battery will be the solution.
Posted on Sep 26, 2008
    another possible problem may be the clock battery that one is accesible by screw driver, on the bottom of your laptop, in the case of this vaio is located inside the smallest cover, hold by a screw.
    Very simple to replaced and very cheap, a buck or two in any radioshack
Blue Screen hardware error on new HP g series notebook pc
It appears you have a faulty notebook. This can happen if the notebook come from the same batch of units that could be faulty.
I suggest you return the notebook to the store and get it fixed under warranty.
Mar 08, 2012 | HP Pavilion G60-120US NoteBook
Screen does not light up - stays black
remove charger,
remove battery
press and hold the power on button for 1min
place battery
press power on button,
if it doesnt light up, then check your memories chips. try another one
good luck
Jun 19, 2011 | Sony VAIO Notebook
My sony vaio VGN-AW41ZF keeps turning off by itself. It doesnt shut down, just cuts off as if there is no power but the battery is fully charged and plugged in. Could this be an overheating problem?
I have a Sony VAIO GRS170/GRS175 in use almost every day since 2003. It used to turn off regularly during hot summer days even with its battery fully charged and plugged in. The problem was eliminated by using a small fan to blow air at its side where the air intake was located. Later, the fan was replaced with a notebook cooling pad which was more convenient. You could first try using a fan to see if it makes any difference. If you don't get anymore shut downs, then the problem is definitely due to overheating. You could then replace the fan with a notebook cooling pad.
Apr 14, 2011 | Sony VAIO FR130 Notebook
I have a problem with the camera on my vaio notebook vgn-fz140e. I don t know why, is not working anymore. I run vaio care, tried to reinstall original soft from sony website, but nothing happened; when I...
Did you install the driver from esupport.sony.com ?
Try uninstalling the driver from device manager in control panel and restart. Try again
Otherwise system restore from the start menu - accessories...
Feb 13, 2011 | Sony VAIO FZ Series VGN-FZ140N/B Notebook
HP dv9830us intermitently working
its a common problem of hp pavillion. i'm the expert. chat me at fixya romsky79
May 31, 2009 | HP Pavilion dv2000t Notebook
Hi guys, I keep getting an error message that says: Stream reading error when I try to use the sony vaio recovery wizard. My computer is the sony vaio pcg-frv27 notebook. The first problem was that...
Try rebooting and hitting the F8 repeatedly as soon as the boot sequence starts. When it comes up to an options screen select repair. From there you can let windows try to repair or select to install to the factory settings.
Mar 14, 2009 | Sony VAIO FRV27 Notebook
I accidentally uninstalled sony image converter 2.
go to system restore it might have restore point from earlier date before you accidentally uninstall the program.
click START>>>>>All programs>>>Accesories>>>>>System Tools>>>>System Restore
Mar 13, 2009 | Sony VAIO VGN-CR305E/R Notebook
Vista vaio survey has stopped working
VAIO Update has been disabled. Start , all Programs, VAIO Update 3, VAIO Update Options , Reenable the checkboxes and you shouldn't get the message anymore. This program runs at startup to check for updates with SONY, pretty useless.
Feb 04, 2009 | Sony VAIO VGN-NR285E/S 15.4" Notebook PC...
Screen doesn't work
If the lid switch isnt stuck I'd look to the Inverter to be bad. Check on external monitor to verify Video there however.
Feb 18, 2008 | HP Pavilion dv6000z Notebook
Sony VAIO FX340 Notebook Logo
125 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
