Question about Xerox Phaser 7750DN Laser Printer
Phaser 7750 - printing slow
Our printer recently started printing at a snails pace. no error messages come up, how do we get it back to normal speed?
    Scholar:
  • 49 Answers
Have a look at the link below for the solution!
http://office.support.xerox.com/SRVS/cgi-bin/webcgi.cgi
Niallbt
Posted on Mar 30, 2009
  • Niallbt Mar 30, 2009
    Slow Printing, Print Times Too Long, Processing Between Pages, First Page Out Times Too Long
    Phaser printers are rated on a page-per-minute basis. This encompasses print engine speed only, and does not take into account processing time or file transfer rates.
    Total print time is affected by many factors, some of which are listed below:
    • Image complexity
    • Image size (amount of coverage)
    • Collation from the software application
    • Number of non-resident fonts used
    • Type of port used and network traffic
    • Printer's memory configuration
    • Resolution/print quality settings set at the host or the printer front panel
    • Media type(ie: paper or transparencies)
    • If the printer model supports job pipe-lining
    Check the Driver Settings
    Driver settings may have an impact on total print time. From the platforms listed below, check for correct driver settings.
    • Macintosh: the driver defaults to binary data. This is recommended.
    • Windows 95/98/ME: check printer properties. Under the Postscript tab, click the Advanced button. Ensure the box Use Automatic Data Format is checked. This automatically selects the correct data format for the connection method.
      Note: The information above applies to printer models prior to the Phaser 850 and Phaser 750. These print drivers have the driver set correctly by default.
    • Windows NT: change the output protocol. The Adobe driver must be installed before changing. Once this driver is installed, go to printer properties and select the Device Settings tab. Locate the selection for Output Protocol and change from ASCII to Binary for a network connection, or from ASCII to BCP for a parallel connection.
    Collation
    Collation from a driver level allows the printer to process a print job once and then print N copies, where N is the number of copies selected by the user (ie 5 sets of a 10 page document = 10 processed pages).
    Application collation requires the printer to process every page of the document N times (5 sets of a 10 page document = 50 processed pages). To avoid collating from an application level, ensure the collate box (see figure below) is not checked when in the print dialog box (ie selecting file/print).
How to clean phaser 7750
Included general maintenance video and how to clear smears from the paper.
Solution: Remove Print Smears / Printing Fuser Cleaning Pages
7750 Support Knowledge Base Remove Print Smears Fuser Cleaning...
With Troublshooting highlighted on the printer display perform the following steps:
  1. Press OK.
  2. Press the Down Arrow and scroll to Print Quality Problems.
  3. Press OK.
  4. Press the Down Arrow and scroll to Remove Print Smears.
  5. Press OK. The printer will print 5 cleaning pages.
Repeat this process five or six times, to remove stubborn toner buildup from the fuser.
Always make sure you are matching the type of paper loaded in the printer tray(s) to the correct Paper Type front panel setting. When you load a tray with paper, the front panel will ask you to indicate the type of paper you loaded. For correct print quality and printer operation, be sure to set this correctly.
MAINTENANCE:
Phaser 7750 Video Instruction Maintenance for the Printer Phaser
Apr 23, 2014 | Xerox Phaser 8550/SDP Color Laser Printer
Tip
XEROX PHASER 7750 7760 FAN ERROR.
Hey guys this is a Xerox Phaser 7750 and 7760 fan error video tutorial.
In this video you will learn how to fix the error code 48 on the Xerox phaser 7750.
Also you will learn how to fix the error codes 010-391,010-392,010-398 that are related to the Xerox Phaser 7760.
This video shows how to remove covers.
All the wires that you need to disconnect from the machine to fix these errors.
There is also another video part two that shows you how to reinstall everything back
in it’s place. Step by step tutorial hope you enjoy.
http://www.youtube.com/watch?v=yMud-Md2xpc
on Dec 30, 2009 | Office Equipment & Supplies
Phaser 7750 Not Printing, No Error codes, Fuser Wont Warm Up, Wont Detect Open Trays or Doors
It sounds like one of the cover or tray sensors is not working correctly. Check the actuator on the fuser cover, sometimes these break off so the printer thinks the cover is still open. If that seems ok and you have a lower tray deck unplug it to eliminate them as the cause.
Apr 07, 2017 | Xerox Phaser 7750 Laser Printer
The printing speed slowed to a snail pace. I pressed Setup, 2, and then 6 to print a self-test report. I got a a "cartridge error" message. Then I removed both cartridges and cleaned them. Still...
This is caused by the failure of one of your cartridges. Remove the black cartridge and print a test page. Does the printer print at normal speed? Is so the black cartridge was the issue and should be replaced. If not then put the black cartridge back in and remove the color cartridge and print test page. If the printer now prints normal speed the color cartridge was at fault and needs to be replaced.
please vote for better sharing.. thank you and good luck
Nov 24, 2010 | HP Officejet 5610 All-In-One InkJet...
Xerox Phaser 7750 error code 14 & 15.
try to hold down the on/reset button a few seconds when you power it up ...on most printers this resets them ..about 10 sec it is enough ...
Nov 26, 2009 | Office Equipment & Supplies
"Print Error-Contact Service; Report Fault 7-401"??
Reset the Tray 2 feed counter within Service Diagnostics as follows:
1. Enter Service Diagnostics (back arrow botton with the "i" button soon as you turn it on) and scroll to NVRAM Access and press OK
2. Scroll to Reset CRU Life Counters and press OK. The display will show the status of all CRUs. Press OK until the Reset Counters menu is displayed.
3. in the Reset Counters menu select Yes and press OK.
4. Scroll to Tray 2 and press OK.
5. Exit diagnostics.
That's what worked for me I called a company called Iteminc they gave me the instructions and they told me to :Replace the tray 2 pick, feed and separate rollers before it starts jamming soon. www.iteminc.com is their website good luck give them a call if it does not work.
Mar 11, 2009 | Xerox Phaser 7750DN Laser Printer
Printer too slow
Sounds like you might have the wrong, or old drivers loaded.
Go to the HP site and download and install the latest drivers for your printer.
Aug 28, 2008 | HP PhotoSmart 7760 InkJet Printer
PRINTING ERROR
> Home > Support & Drivers > Knowledge Base
Solution --> ERROR 0082" name="Note" /> Phaser 790 / DocuColor 2006 Printer's: Cancel print job and cycle the printer's power
  • On the printer's Control Panel, press the Cancel Key (12 KB).
    Note: The READY message may only appear briefly. You may need to keep repeatedly pushing the CANCEL key.
  • If the error message persists, turn the printer off for at least 30 seconds and remove the computer interface to the printer (17 KB) before turning the printer back on.
  • Use the menu keys to perform a front panel reset (under RESETS menu).
  • If the printer redisplays the error message upon reboot, a file is likely STUCK at the front of the print queue. Use the front panel RESETS menu to CLEAR LOGS AND QUEUES, which will delete all print jobs in the printer's disk spool.
    Note: The READY message may only appear briefly. You may need to keep repeatedly pushing the MENU key to gain access to the front panel menu.
  • If the front panel menus can not be accessed turn the printer off for 30 seconds and then turn the printer back on.
  • If it is known which print job was last sent to the printer, try to reprint the last job spooled, which may be the cause of the error. Step 4 on clearing logs and queues may need to be repeated to eliminate the crashing job.
Note: Most XX82 or XX1E front panel error messages are NOT hardware related, but caused by a specific print job or application.
Mar 04, 2008 | Tektronix Phaser 860DP Thermal Printer
Phaser 7700 Accumulator Belt Replaced, upon startup there is an error
POSSIBILITIES
Problem:
1st BTR Contact Failure or 1st BTR Retract Failure Message is displayed after replacing the Accumulator Belt Cause:
A Phaser 7700 Accumulator Belt was installed in a Phaser 7750. The Phaser 7700 Accumulator Belt does not have retractable 1st Bias Transfer Rollers; so these errors will be reported if one is installed in a Phaser 7750 printer. Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. Remove the Phaser 7700 Accumulator Belt and install a Phaser 7750 Accumulator Belt. TRY FIRST (Solutions without parts):
1. Check that all shipping restraits have been removed.
TROUBLESHOOTING TIPS AND HINTS:
1. Test the 1st BTR motor in diagnostics to verify proper operation. 2. Test the 1st BTR sensor in diagnostics, then run the 1st BTR motor test and recheck the 1st BTR sensor. Sensor state should alternate between L and H. The sensor is part of the accumulator belt.
PARTS:Parts are listed in the order of highest probability for repair.
NUMBER QTY DESCRIPTION
116177400 1 *KIT IBT - UNIT
REPAIR/INSPECT/PREVENT PROCEDURE:
1. Clean feed rollers, exit rollers and guides; replace if
necessary.
2. Clean feed rollers and exit rollers only when dust or
debris is visible.
3. Remove and clean all paper trays.
4. Clean the Laser Scanner Unit window.
5. Inspect the image density sensors; clean if necessary.
6. Inspect the accumulator belt home sensor; clean if
necessary.
7. Inspect the fuser assembly; clean if necessary.
8. Print the Error Log, diagnose and repair any problems as
indicated.
9. Print the Usage Profile, diagnose and repair any
problems as indicated.
10. Check version of all installed firmware; as
appropriate, install the latest version of firmware.
11. Check cleanliness of interior and exterior of printer,
including fans; if necessary, clean (dust or vacuum) these
areas.
Problem:
Jan 25, 2008 | Tektronix Phaser 860DP Thermal Printer
Xerox Phaser 7750DN Laser Printer Logo
874 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
