Question about Sony KP-46V35 TV
Slow video switching
Dan, the set has been off for several months due to the stated problem so I powered it up last night to see if the problem would show itself again. And it did not...yet. But a new problem was evident without any blinking of the LED. Each time I changed the channel the audio would switch immediately as expected but the video would take about 30 seconds to a minute to switch and again there was no blinking LED. It did not matter which channel I switched. Any ideas?
  • 4,234 Answers
I responded to the comment posted to the original problem/question. If you don't mind, I'd rather keep the discussion there for context.
Thanks,
Dan
Posted on Sep 10, 2008
SONY BDV-E280 BLOWING FUSES
I have not worked on these directly but it sounds like a bad capacitor in the power supply that blows fuses upon a power on. If the unit has a switch mode power supply the switch on from the strip might be sending in a high transient causing the switch mode supply to draw too much current. How does the unit work if you just leave it plugged in?
If switching these on and off the better way would be through a zero crossing voltage solid state switch.
Oct 05, 2012 | Sony BDVE280 3D Blu-ray Home Theater...
I own an ASUS VW224U - Manufacture date is March 2009. Purchase date 4/10/09. Last night i was playing L4D2 and after the game it just powered down. I rebooted my PC, Disconnected it over night. Tried a...
Does your ASUS power on? If it does then your computer power supply is good, and if you computer doesn't boot but you can hear power going to the power supply, then your video card has died and a replacement for your video card is due. The "ticking" noise could be your video card cooling off. But your question was a bit vague, I could not tell if your issue was a power issue with your computer or a monitor problem.
May 01, 2017 | ASUS VW224U 22 inch Monitor
Tfdvd1591 - screen has snow. It was working fine and I changed channels too high I think. the lcs settings has a channel number and I am not sure what that should be
This is actually a copy of the manual. When troubleshooting these units, there are always several variables to consider. First check to see what last occurred with the unit such as did the children play video games, did the electricity go out due to bad weather. You may see that there are many possibilities but let's focus on what occurred last to the unit. Once we determine what happened last, we may isolate the actual cause of the problem. The actual cause may be associated with projection issues, older versions (Picture tube), interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common with the error you have provided today. Please continue to look for anything EXTERNAL to the unit before looking at the internal components
Jan 16, 2011 | Coby Televison & Video
HB ceiling fan is getting slower and slower bi the day
Solid-state controls change the level of power in the fan motor to control the speed of the fan. For instance, when you switch from medium to high on a solid-state fan, the speed control mechanism increases the power of the motor. Solid-state controls are generally equipped in fans with controls that have predetermined settings, such as low, medium and high.
The solid state device in or around the fan motor could be defective and in need of replacement.
https://www.hunker.com/12003281/how-does-a-ceiling-fan-speed-control-work
Dec 07, 2017 | Hampton Bay 52 In. White Redington...
Xbox live will not connect this morning
its fine there just doing maintenance for the day that's all it should be back by tomorrow
Jun 16, 2009 | Microsoft Xbox 360 Console
Emerson rv LC320EM9 3 just shut itself off and
I've been working on Televisions since 1975. I have unfortunily had experience with this model 4 times in the last 2 months. The problem is the same in all sets. First off it is made by Funai in Malaysia and that should tell you the whole story. All the sets that have come through this shop are in the dumpster now. This BLC320EM9 is made just for Wally World and you cann't get parts for them due to a contract between Funai and Wal-Mart. I'm affraid this is just the beginning of your headaches with this set. It has a multitude of other problems... Wish I could have brought you better news. Dan@DBS
Mar 26, 2009 | Emerson LC320EM9 32 in. LCD HDTV
No picture
gets white horizontal streaks for a split second, then back to no picture. i think sound will be alright. while horizontal streaks are called retace lines & is due to video section failure. please call skilled tech to fix it it is not a major problem & can be rectified. at your place without replacing much parts. your tube is ok. good luck
Sep 27, 2007 | Zenith SY2551S TV
Televison & Video Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
