Question about E-Machines eMachines Desktop PC
Detecting array... I am sorry. I could not boot it. when i turn on pc it's appear the black screen with " Detecting array..." and stay on untill i am turn it off. Thank you
  • bethuy Sep 11, 2008
    the monitor is fine.
    I was following your instruction but still does not work. Do you have another ways? Please help me
    Genius:
  • 1,027 Answers
Does any other monitor work? if not than the video card may be bad. or the settings in the bios may be altered. first try this...unplug the tower, open the case and remove the bios/real time clock (RTC) button cell battery, press the power button to dissipate any voltage that is stored. Re-install the battery, plug tower in and power up. If anything was changed in bios everything would go back to default settings and you would have to enter set up to update date/time etc.
Posted on Sep 11, 2008
POS X Evo TP1 A1N screen appears to be off, but power is on
first of all check your monitor. it would be the best if you can plug some other monitor just to check... if your monitor is OK then probably you VGA is bad and you`ll have to change it.
Dec 14, 2013 | POS X POS-X EVO TouchPC (PXI-EVO-TP1-A1N)...
Getting detecting array message
And what else? If the system just hangs at detecting it's expecting to find an array of hard drives attached to the system. Do you have an array that it can boot to? Does it load the OS finally? Was it working before? Did you make changes to the bios ro the array controller bios?
Nov 13, 2013 | Gateway GT4016 Desktop PC
Turns on but black screen
Restart your computer and then press and hold F8 keys until you get Advanced Options menu screen.Use the arrow key to highlight Safe Mode, and then press Enter, your computer will boot automatically to safe mode.
If you able to start in the safe mode then Scan your computer for viruses. Some viruses can cause a black Screen , especially ones that infect the master boot record (MBR) or boot sector.
Update drivers for your hardware. black Screens are hardware or driver related so updated drivers could fix the cause of the STOP error.
Return BIOS settings to their default levels. An overclocked or misconfigured BIOS can cause all sorts of random issues, including black screen.
If it didn't helps you then simply get the system utility program like PC Fresher that will fix windows errors that cause of black screen screen
Oct 04, 2013 | MSI Wind U100-030US Laptop
When i turn it on the screen stays black
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Jul 14, 2012 | Sony Computers & Internet
MediaShield ROM BIOS 6.33 detecting array on the screen of an emachine pc
You need to be more clear than that. You say detecting an array? What kind of array? When does it say that? Do you mean you have an array of hard drives installed? If so, then so what?
Sep 25, 2011 | E-Machines eMachines Desktop PC
Everytime i turn on my pc it goes to detecting array, how do i solve this problem?
Does it boot into the operating system after this as post information is normal (detecting hard drives, optical drives etc).
Regards.
Jun 25, 2010 | E-Machines eMachines Desktop PC
Acer Aspire 5100 laptop's screen remains black at start-up
This is probably a hardware issue with the monitor. Just to make sure, uninstall, and reinstall the monitor's driver. If that doesn't fix it, it's a hardware issue.
You will have to either take it to a shop, or contact the manufacturer (your computer should be under warranty if you've had it for less than a year).
Sep 19, 2009 | Acer Aspire 5100 Notebook
Toshiba M115
Hi again and welcome back to FixYa,
Appreciate the direct "Ask Me".
Would initially suggest to clean the memory(/ies). Turn over the laptop, behind one of the panels/lid/cover secured by a screw or two would be the memory modules. Snap them out, use a hard pencil eraser to clean the little gold pins, a dry brush on the memory slots and re-insert the memories back, try again.
Should this be not corrective, it would appear that you have a video driver problem and fails to load correctly. Try booting into "Last known good configuration that worked", otherwise might require re-installing Windows all over again, sorry.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 14, 2008 | Toshiba Satellite A100-S8111TD Notebook
Model #w3118
If you can get in setup after pressing F2 check on the advanced chip tab,video and make sure 8mb buffer is selected. save and exit.
F-2 is for setup utility
F-10 is for network boot.
if it stll won't boot up correctly press F8 when booting up and select vga support then maybe get in to the os that way and adjust video display settings after.
Apr 13, 2008 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
598 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
