Question about Sherwood RX-4103 Receiver
Sherwood rx4103 my receiver was working fine but now its on standby and when i press the power it turns on and then it cuts right back off how can i fix this problem
  • 2 more comments
  • Anonymous Jun 05, 2008
    when you apply the power, the unit goes on for few second and shuts down,with everything diconnected.. I hear a clicking sound with the three an or four relays.
  • Anonymous Jun 10, 2008
    when i tern it on it stays on for like five seconds then it goes off
  • skisomor Dec 15, 2008
    is it repairable?
  • Anonymous May 09, 2009
    I have the same problem with a model 626. It seems the chinese
    mfg to not believe in actually testing what they make over a period of more than one Chinese minute which equals 2 US seconds.
I have the same problem with mine... its anoying is there like a reset on this item?
Posted on Aug 30, 2009
I have the same problem with my sherwood receiver, I turn it on and then 4 seconds later it clicks off. Nothing is hooked to it, not a speaker, cd,tape plater, etc. It started when I hooked up the speakers 8olm, and turned the sound to half way. How can that be repaired by me?
Posted on Sep 08, 2008
  • 3 Answers
Hi i have a Sherwood r125 with the same problem i have noticed that there are two transformers one feeds the processor with 5 volts but then i noticed that the ac supply was missing for the display going back to the transformers the mains transformer on the secondary side appeared to be open so maybe a replacement will do the trick for yours the problem now is finding a supplier
Posted on Apr 24, 2009
    Novelist:
  • 130 Answers
Are you sure you dont have a bad speaker cable? or a blown speaker? unhook everything from the receiver then try and power it on with nothing plugged in. One at a time plug each speaker up if its still working and hasnt shut off when all speakers are plugged in then start connecting each device (dvd, vcr,tape deck,) Some receivers have a blow protection circuit that blows like a cirquit breaker in a home if there is a problem. Maybe you have a short? blow speaker? hooking each device up one at a time starting from nothing will help you trouble shoot the problem. If it clicks off with nothing plugged in then the unit may need serviced.
Posted on Apr 03, 2006
I have Sherwood rd-6106 amplifier and when i turn him on it goes back to standby after few seconds. can anyone help?
bad fuse, something is sending it to sand by to keep from ruining the rest of it, have it looked at by a pro technician
Feb 02, 2015 | Sherwood Audio Players & Recorders
RD-6506 sherwood back to standby mode after 3 second when attemting to operate the system, any help please.thanks and God bless
Hi,Need more info. Was the unit working then failed? tell me anything you noticed, this sounds like a fault in the audio output or power supply stages,I have had other receivers do this for variou reasons
Feb 27, 2014 | Sherwood RD-6506 Audio and Video Component...
Sherwood
does a code pop up like f20 or just any code
Mar 20, 2013 | Audio Players & Recorders
How do I reset the defaults on my Sherwood RD-8108 AV receiver?
I just got a tip from Sherwood tech support on resetting my Sherwood receiver, and it solved my problem perfectly. It's not the same model number but here's what I did: Put the receiver on Standby. Press and hold the Setup button for 3 seconds. When you see the model # on the display, press Enter. The word "Cleared" should show on the display. Hope it works for you also.
Feb 03, 2011 | Sherwood RD-8108 6.1 Channels Receiver
Power cuts off after 2 seconds after stereo start button is pressed
Disconnect your speaker wire's from your receiver, and then turn the receiver on.
If your receiver cuts off with the speakers disconnected, there is something wrong with your receiver, and take your Sherwood receiver to a qualified reputable technician.
If your receiver stays on with the speakers disconnected, their is a short circuit either in your speakers wires, or in your speakers. Make sure your speaker wires are pushed all the way in the speaker terminals in the back of the receiver, and do not leave no naked speaker wires exposed. If you have too long of bare speaker wires exposed at the receiver's speaker terminal, or at the speaker's terminals, they could touch each other, and cause the receiver to cut off. If the speaker wires are OK, then you may have a short circuit in your speakers.
Nov 12, 2009 | Sherwood RX-4105 Receiver
Sherwood rd7103 rec.
no listing for Sherwood receiver. must do the remote "search" function. here is how:
  1. Turn on your TV.
  2. On the remote control, press TV once.
  3. Then press and hold SETUP until the TV key blinks twice, then release the SETUP key.
  4. Using the number pad, enter 9-9-1. The TV key will blink twice.
  5. Aim the remote control at the TV and slowly alternate between pressing Power and TV. Stop when the TV turns off after pressing the POWER key. This means that a working code has been found.
  6. Press the SETUP key once to lock in the code. The TV key will blink twice.
Hope that helps!
Feb 28, 2009 | Sherwood RX-4103 Receiver
System lights up when plugged in but stays in stand-by mode
if it is wet please remoove the cover and dry it by using hair dryer .after that still the same it can be bad solder joints.
can you resolder the printed circuit board.
nuwan....
Jan 12, 2009 | Sherwood RD-6500 Receiver
Sherwood rv 6030r does not turn on.
Try these simple trick to find out yor remote control working or not....
Point the remote control towards the Camera of a Mobile Camera phone,with the camera on. While pressing remote, we can see a light (Infra Red) coming from its IR LED through the Mobile Camera if the Remote is working.
If the remote is OK, then the problem with the Remote Sensor or related components of the receiver.
Dec 25, 2008 | Sherwood R-945 Receiver
Switches to standby at high volume
First you should check is there something improperly connected. If malfunction still occurs, check is there cooler inside, and if it is, is it working. That seems like heating problem.
Oct 11, 2007 | Sherwood RD-7502
Sherwood RX-4103 Receiver Logo
755 people viewed this question
Top Sherwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Sherwood Audio Player and Recorder Expert? Answer questions, earn points and help others
