Question about Vcomm Recovery Commander (804526023624)
Removin progaramme every time I try to install a new program, recovery commander appears and immediately freezes the whole computer. The program is not installed on my computer and I cannot find any trace of it anywhere!
  • 72 Answers
It sounds like malware. Run a virus scan and a spyware scan.
Posted on Sep 10, 2008
Add/Remove Window components
Im not sure which file you are referring to but you could just a repair of the installation
this is fot the master boot record
if there are any other files , settings or programs during the repair process options for these should be available
Insert your Windows XP installation CD or recovery disc, and restart the computer.
Instead of attempting to boot Windows as it normally would, the computer will give you an option to boot from the CD.
Press a key when prompted, then wait for the setup program to load.
Press the "R" key on the "Welcome to Setup" screen.
This will cause the CD to launch the Recovery Console instead of attempting to install Windows XP on your computer.
If you have an administrator password on your copy of XP, then you will need to enter it in order to log in to the Recovery Console.
Choose the installation of Windows XP that you want to repair (generally the only option). Wait for the command prompt to appear, then enter "fixmbr." Press "y" when prompted to let the FixMBR utility overwrite the corrupted bootloader with a new copy.
Remove your XP disc or recovery disc, then type "exit" into the command prompt.
The exit command should cause the computer to reboot, allowing the computer to load the new bootloader file and then continue Windows XP startup as normal.
Hope this helps
Oct 30, 2012 | Microsoft Windows XP Professional
My computer fails to boot several times and when it does finally get to the desktop, it freezes and then goes off into power saver mode. how do I fix that?
Try running the Check Disk Utility.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
May 04, 2012 | Dell OptiPlex 360 Desktop Computer
An unexpected i/o error has occurred
Boot into Safe Mode and see if it will allow you to run a System Restore.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.If the check disk utility can't fix the problem you'll need to reinstall windows.
Apr 07, 2012 | Computers & Internet
Can't remove Recovery Commander on VISTA notebook. Does not appear in control panel add/remove programs list. No listing for Vcoomm. No listing under Avanquest. Thanks, Microweb
There is an application called Revo Uninstaller (Freeware). Install it on your PC and then uninstall recovery commander.
Hope this helps.
Dec 08, 2010 | Vcomm Recovery Commander (804526023624)
Every time I attempt to load a new program-Recovery commander starts and I can not load a new program. Deleted program-problem still exists
Try setting your computer back to when it was working correctly. To do this do the following:
Go to start
All Programs
Accessories
System Tools
System Restore
Click Next
Follow the prompts and choose a date from the list when you know your computer was working correctly
This should work for you, let me know if you need further assistance
Please leave rating/feedback if you found this helpful, thanks!
Lori
Oct 17, 2010 | Vcomm Recovery Commander (804526023624)
I want to delete RECOVERY COMMANDER because it arrives unrequested, freezes my PC and refuses to be cancelled. The only way of stopping it is to reboot. Help please.
hi type cnet in your search engine /type uninstaller in cnet search.
to the left choore option "free" then download revo uninstaller/instal
and use. this is an exy... program use it my self .hope this helps.
Aug 20, 2010 | Vcomm Recovery Commander (804526023624)
I am having the same difficulties as you!
http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=en&dlc=en&cc=us&docname=c00220758&product=12455
If you have compressed the hard disk drive using the Compress drive to save disk space option under the Properties menu for your hard disk drive and have performed a non-destructive recovery or a system recovery, the following error message may appear: NTLDR is compressed. Press CRTL-ALT-DEL to restart. This error message is resolved by following these steps:
  1. Insert the HP Recovery Tools CD or Compaq Recovery Tools CD into the CD drive on the computer and restart the computer.Wait for the HP Recovery Tools CD or Compaq Recovery Tools CD window to open.
  2. Select Run Microsoft Recovery Console , click Next , and then follow the onscreen instructions. NOTE: If you are unable to open a recovery console, follow the Alternate steps .
  3. Press R to repair the Windows XP installation using Recovery Console.
  4. Enter the appropriate number for the WINDOWS installation, for example, the WINDOWS installation could be listed as 3: C:\WINDOWS or 3: D:\WINDOWS .
  5. If prompted, enter your Administrator password and press Enter . If there is no password, just press Enter .
  6. At the prompt, if the WINDOWS installation you selected in Step 4 was C:\WINDOWS, type: cd c:\Or, if the WINDOWS installation you selected in Step 4 was D:\WINDOWS, type: cd d:\
  7. At the prompt, type: attrib -c ntldr and then press Enter .
  8. At the prompt, type: exit
  9. Press the Enter key and immediately remove all discs or diskettes from the computer to allow the computer to restart.The error message should be resolved.
Alternate steps NOTE: These alternate steps work for HP and Compaq desktop PCs with Windows XP and a recovery partition. (M0st HP and Compaq PCs with Windows XP have a recovery partition on the hard disk drive.) These steps do not work if you have replaced the hard disk drive, replaced Windows with another operating system, or repartitioned the recovery partition.You can use the following steps if you are unable to open a recovery console:
  1. Turn on the computer. When the initial logo screen appears, press the F10 key repeatedly until a message about starting recovery appears.
  2. At the Recovery screen, click Advanced Options and then press the Alt and D keys at the same time to go to a command prompt.
  3. At the command prompt, enter the following: diskpart
  4. At the command prompt, enter the following: list volume
  5. Remember the drive letter next to line for the main hard drive; HP_PAVILION or PRESARIO.
  6. To close Diskpart, enter the following: exit
  7. At the command prompt, enter the drive letter followed by a colon (:). For example, H:
  8. At the command prompt, enter the following: cd \windows\system32
  9. At the command prompt, type the following: compact ntldr /u <the drive letter>:\ntldr For example if the drive letter was H, you would type: compact ntldr /u h:\ntldr
  10. Type exit and press Enter .
  11. Click Quit .The error message should be resolved.
Sep 06, 2009 | E-Machines eMachines Desktop PC
Removing the program
I have the same problem but have tied mine down to Fix It Utilities which were downloaded. If you have Fix It the solution appears to be run Fix it, at the top select 'settings' then on the left 'recovery', then 'recovery commander' on lower top toolbar. Uncheck 'Detect when a set up program is launched....' and that should cure it.
Aug 11, 2008 | Vcomm Recovery Commander (804526023624)
Vcomm Recovery Commander (804526023624) Logo
74 people viewed this question
Top Vcomm Computers & Internet Experts
David Payne
David Payne
Are you a Vcomm Computer and Internet Expert? Answer questions, earn points and help others
