Question about NEC Dterm DTP 16D-1 Corded Phone
NEC Dterm80 Phone rings, but will not go to voicemail
  • Anonymous Oct 11, 2008
    If you call my ext it rings but never goes to my voicemail.
Try pressing the ext number then 7
Posted on Oct 16, 2008
4 Suggested Answers
  • 3 Answers
SOURCE: NEC Dterm80 ring tone
To here ring types hit speaker then 711, then 1 for internal rings (select 2 for outside ring selection) then 1-8 the ring type.
To set ring type hit speaker then 720 (follow all the steps above).
Posted on Jul 28, 2009
SOURCE: NEC Dterm 80
Press feature; press 9; press #; use key pad to change time; press recall to change am/pm; press feature again to when time correct; new time should show.
Posted on Mar 24, 2008
  • 43 Answers
SOURCE: trying to change night ringer voicemail
Ok. You will have to find someone who has access to system manager, or has system manager rights for their mailbox.
They will then be able to select System Manager Options, then Change the Greetings. It will tell you which mode you are in, and ask you if you want to change to Holiday Mode. The responses are 1 for YES and 2 for NO. Say no to Holiday Mode, and then it will go thru Day Mode and then Night Mode, playing each one first then asking if you want to change it.
If you must call in a service order with your phone system vendor, make sure he/she not only assigns someone's box with manager access, but also creates a back-door box with manager access. This way you won't be messing with the original Manager Box. It gets expensive having NEC decipher the Manager's password if it gets changed and no one remembers it.
Posted on May 10, 2008
How do outside callers get my voicemail instead of the operators voicemail?I have a NEC Dterm80 phone model DTH-8D-2BKTEL.
Outside callers, only get an operators voicemail, when your phone can't be reached. For whatever reason. No contact to a cell, switched off, airplane mode, you name it.
Then when you have contact to the provider, you should setup your voicemail, the way your provider would like you to do.
Feb 03, 2015 | NEC Lands Phones
How to disable do not disturb on NEC Dterm80 phone?
Have a coworker call your extension to see if DND is on, they will go straight to voicemail or get a fast busy. Speaker 42 may be the default cancel DND code, depending on your system and whether the codes were changed. Anyway, ringing is set up in system programming. If someone calls your extension it will likely ring, but outside calls have to be assigned to ring in system programming. Usually need a tech to do the programming since it gets complicated very quickly.
Sep 09, 2014 | NEC Dterm DTP 16D-1 Corded Phone
Nec dterm80 how to keep the voicemail from
Check the controls window and recheck your settings. Set as you like.
Oct 03, 2013 | Mrv new 8000 40 port term server dc power...
My voicemail stopped working. The phone rings and rings but doesn't go to voicemail.
Press Speaker
Dial *6
Enter Voicemail # (will appear on screen if you hit your voicemail button)
Press Speaker again
Nov 27, 2012 | NEC Dterm DTP-2DT-1 Phone
May 20, 2009 | NEC Dterm DTP 16D-1 Corded Phone
Headset for NEC Dterm80
Do a search for a plantronics headset. All of theirs work well with NEC
Nov 11, 2008 | NEC Dterm DTP 16D-1 Corded Phone
NEC Dterm 80
Feb 28, 2008 | NEC DTU 8D-2 Corded Phone
Dterm80 NEC phone
How do I get the following off my display?
MSG >>> In-Mail #2
Sep 12, 2007 | NEC Dterm DTP 16D-1 Corded Phone
NEC Dterm DTP 16D-1 Corded Phone Logo
281 people viewed this question
Top NEC Lands Phones Experts
Craig Butler
Craig Butler
Oloyede Monsuru
ray gallant
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
