Question about Hotpoint Aquarius WMA42 Front Load Washer
How do I take the top off. There are no apparent secrews
To remove top, remove plastic luggs on each side carefully with a knife under which ther is a screw, this screw has a special head, this can be found in a screw driver attachment set avilable from any diy shop
Posted on Sep 17, 2008
Hotpoint aquarius wma54s bumping when operating
hi take top off push left side drum down then right if one side easyi than outher more than likly the easy side has weak leg from drum to chassis
Jan 30, 2014 | Hotpoint Aquarius WMA42 Front Load Washer
Fabric softner not draining away on my hotpoint aquarius
take out your soap draw and in side there on the top you will see all black gunk that need cleaning i use a toilet brush with hot water ok
Oct 19, 2012 | Hotpoint Aquarius WMA42 Front Load Washer
F-07 flashing on display
(and again!) Hi from retired Englishman in SW France,
For most Hotpoint (and other named) models 'F07' means 'heater relay (possibly) stuck'. 'Check power supply connections to the heater, wiring and module (i.e. PCB) connections' (apparently poor PCB connections are often the cause)
Good luck,
John C
Mar 14, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Where is the element on a Hotpoint Aquarius dwf30 dishwasher?
It sits in the base of the machine and you would need to remove the complete top section of the dishwasher to gain access to it, which involves removing the door first, then the balance weight and finaly the stainless steel top section
Mar 17, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint aquarius drum fills to top with water
will it stop when you stop the cycle? if so your pressure switch could be the problem however if that does not stop the water you intake water valve is most likley the problem
Feb 06, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
No manual how to use thei machine
Try this website may be helpful to you in finding the Manual:
Hotpoint Front Load Washer
Best of Luck Scott
Jan 18, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Model WMA 42
Normally remove the back panel.
Ensure the plug is removed from the powerpoint (not just switched off) to avoid electrocution.
Sep 08, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Model WMA 42
The 2 screws securing the top are located behind 2 plastic covers on the front top, remove these 2 covers and the screws are located there, you will need a torx screwdriver to remove the screws.
Hotpoint Aquarius WMA42 Front Load Washer Logo
228 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
