Question about Dryers
Kenmore Electric Dryer, HE4, Model #110.85876401
None of the panel lights work, how does the thermostat affect this? I replaced thermal fuse, front control panel, dryer cord, and still won't work. Outlet works fine.
Adrianne
5 Suggested Answers
  • 103 Answers
SOURCE: i have a kenmore he4 no. 110.85871400. i have no
Check thermistor with ohm meter, make sure you unplug unit first, make sure wires are removed from thermistor or you will read ohms thru the wiring. If thermistor checks ok, the you have a relay board problem. replace power board.
Posted on Oct 01, 2009
  • 119 Answers
SOURCE: Model 110.87983110 Kenmore dryer. We have
yes you can temp. bypass to see if it runs if so replace fuse and look for a lint clog in vent
just plug the wires toghter add some tape or make sure the wires do not ground to anthing. remeber to unplug
Posted on Feb 16, 2010
  • 2677 Answers
SOURCE: electric dryer won"t heat. Kenmore Heavy Duty 70
are you getting power down to the heater?why did you change all those other parts?you need to unplug the dryer,with a meter read out all the parts you changed out again but first make sure you have 240 volts coming to the machine,you can check it at the cord in the back,touch the white to the red,you should have 110 volts or 120,then go from the white to the black and you should have the same thing,if not the problem is in the house,if it's correct make sure you have power coming down to the heater,you could have a bad timer or a burnt wire,when you check the other parts unplug the dryer and whatever part you check at least one wire has to be removed,do this and you'll find your problem,if you did this first you wouldn't of bought all those parts.let me know what you find
Posted on Nov 05, 2010
danoyachtcap
  • 2904 Answers
SOURCE: I have a lg dryer
No. the new dryers have to have a 220V power. You first have to replace or add a 220 outlet on the wall that matches the connector on the dryer.
Posted on Jun 26, 2011
GEW9200 electric dryer turns fine but won't heat up. I tested the thermal fuse, thermostat, heating coil and they are fine. What am I missing?
If you have 240 VAC to the dryer, the control likely has a faulty relay for the heater. Provided all the thermal fuses (especially the one on the side of the element can) are good and the voltage supply is good, the control will likely need to be replaced and is available below.
Control
Nov 24, 2013 | Kenmore Elite HE4 Electric Dryer
My Kenmore He4 electric dryer is not heating. It is running fine, but does not heat to dry the clothes. What do I need to do?
Hi tomsavaloja...
Here are a few things to check:
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor/thermal fuse one at a time by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor/thermal fuse as it is faulty.
If you have an ohm meter then you can test the thermostat/thermistor/thermal fuse,
then you do not have to tape the wires together as described above.
To test your thermostat/thermistor/thermal fuse remove the wires from the thermostat/thermistor/thermal fuse and check for continuity, if you DO NOT have continuity then replace the thermostat/thermistor/thermal fuse.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST AS THIS COULD CAUSE A FIRE BECAUSE YOU HAVE REMOVED THE SAFETY.
Check your blower wheel to make sure it is secure to the shaft and not plugged with lint,socks,etc.
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset.
You can test it with an Ohm meter or continuity checker, remove both wires from the thermal fuse and put the test probes to each of the ends of the thermal fuse, if no continuity then replace the thermal fuse.
A vent clogged with lint can cause it to overheat.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace a generic element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
Please take time to rate me thumbs up
Sep 15, 2011 | Kenmore Elite HE4 Electric Dryer
I have a Kenmore Elite HE4 dryer and it is not heating up. I changed the coil and cleaned out the lint. Is there a reset button?
If it isn't heating up but running otherwise, you probably blew the thermal fuse. The thermal fuse is often blown by the high limit thermostat going bad, and thus may need to be replaced also.
Mar 10, 2010 | Kenmore Elite HE4 Electric Dryer
Wiring
You are missing over $150 in parts. You can buy a working unit out of the newspaper for that or less.
All of the wires on those models have letters and numbers on them near the connectors at each end.
Go to the Sears Parts Direct website with your Model Number and you may be able to print out a wiring diagram, because that is what you will need.
Jul 13, 2009 | Kenmore Elite HE4 Electric Dryer
Dryer not Heating
Take the bottom front panel off and the thermal fuse is mounted on the blower duct near the thermister
Jan 18, 2009 | Kenmore Elite HE4 Electric Dryer
No heat from he4 kenmore dryer
did you check the outlet got 240 volts? if you did and your not getting that at the heater it could be the board or the motor if the switch in the motor is bad it wont send power have you found the tech sheet? that will give you how to test it but if you think swapping parts is OK then you need to go buy a multimeter so you can find the faulty part
Dec 09, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore dryer model no. 110.85087400 won't start
hello
i have a kenmore model 110.85087400 that will not heat up i just replaced the heating element and still have the same issue.what do you think it can be...when i open it to replace the element i notice some lint that was burnt...help please.miguel
Aug 19, 2008 | Kenmore Elite HE4 Electric Dryer
Fuse
one fuse is on the heater housing the other is on the blower housing if you have not removed it the wiring diagram is inside the console
Apr 10, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 Gas Dryer-triple beep
Did you have any lights at all on the panel? I just took off the User Interface as going through the troubleshooting guide I found underneath the control panel led me to that solution.
Feb 11, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
81 people viewed this question
Top Dryers Experts
