Question about Insignia Computers & Internet
When i booth up the computer it go to window start up and go blank,and start over again
    President:
  • 2,961 Answers
When it's booting up turn it off by the power up button, it will then either start ok, or say windows did not shut down properly and let you select start windows as normal.
Posted on Sep 10, 2008
My zinox laptop wont booth to the user environment.when i press the power button at first it shows me bios and when it gets to windos xp it blacks out and then repeats the same thing again. How do i get...
There are a couple of things that may be causing this problem. First test your windows. to do this once you are on the bios start tapping f8 and continue tapping f8 until you get to the advanced menu. use the arrow keys and choose safe mode. if you are able to go into safe mode then you can try to restore your system to an earlier date. choose a date before this issue has started. if you are not able to go into safe mode and still get this issue then there is a problem with your windows system or it could be hardware as well. so better try to reinstall your windows system first. if you still get the issue it could already be the hard drive or other possible hardware issue. but there is a high percentage where you might just need to reinstall windows.
Jun 06, 2012 | Computers & Internet
How to provide the computer to the genuine microsoft
Goodday!
I have a good solution for you!
Try to download windows downloader.
you can sereach it through the internet.
after you download the windows downloader,
setup it. after a few minutes! your computer will restart!
after the booth, your computer is now guinue!
Mar 21, 2011 | Microsoft Windows XP Professional
Black Screen on laptop start up. Makes a slight noise after pushing start button but screen never changes from black and eventually the light on the power up key goes out. We checked the hard drive and...
There seem to be a problem with the module of the laptop, that is why you are having a black screen through out the boothing process of the laptop.
The module is the chip that allows information from the main board reach the screen.
The hardwares would be working perfectly fine, but since the module is having problems, the screen will not light up, and the computer can go off after boothing.
Have the module checked and replaced and your laptop will be in good condition once again.
Good luck.
Sep 09, 2010 | Toshiba Computers & Internet
Booth up the computer
First When you power up the computer press F1 or F2 or del or ALt+F2 to enter in bios.Then make sure harddrive is detected.
If you harddrive is not detected or you can't see any display on screen then open cpu cabinet.
Reattach the RAM memory ,both connection to harddrive .Reconnect processor and it's fan pull cmos cell from motherboard for 10 minutes.Remove pci card or vga card if any then check.Make sure motherboard is not ground with cabinet.
Let me know if you need further assistance.
Thanks for using FixYa.
Jun 05, 2010 | Dell Dimension 3100 PC Desktop
Evrytime i booth my laptop the messge showed and it slows down my computer speed and loosing some application i have currently on my computer please help
Try this goto start then programs then applications then system tools then do a disk cleanup on your primary drive then go through the same steps to get to your defragmenter and run that after the disk clean up is finished if this has not been done in a while it may take a hour to defrag the information then restart and see if the speed increases. Another good tip is to leave your computer hooked and running over night so it can update.
May 20, 2010 | Microsoft Windows XP Professional for PC
Hang on booth
Use your restore disk, or if you have a Windows OS disk, bootup with that.
When you see the screen that gives you an option to "Repair Windows" hit the "R" key. You will be taken to a DOS prompt. Choose the Volume you want to repair (Usually number 1) then it will prompt you for an Administrator password. If you have never put one on the system, simply hit Enter. The it will take you to "C:\Windows" Type in the following...
"CHKDSK /R" (without the quote marks and hit Enter. Let chkdsk utility see if it can repair the volume. It will prompt you when it is finished.
Apr 27, 2010 | Toshiba VGA Board Graphic Card
My laptop doesnot start up. erer massege saisafter accuratly cheking the license window cant start
try to reinstall the OS, from cd drive, you'll need to booth it first from cd(press F10 or F12 after power it on and choose the first booth at your cd drive. then follow instruction for reinstalling the OS, first try to repair it, it might solve the problem but if not try a fresh install or clean install.
hope this will solve the issue
Oct 31, 2009 | Dell Latitude C610 Notebook
Computer not booting up
This sound like you might have corrupted windows systems files. See if you can restart the PC using the last known configuration. You can do the by pressing the F8 key during the windows startup process.
Mar 24, 2009 | Computers & Internet
No post/blank screen
Do you have your Windows XP CD? Boot from that CD and at the prompt, press r for repair.
select 1 for windows installation and at the prompt type the follwing and press enter:
chkdsk /r
once complete (will take some time), reboot and you should be back in action
May 02, 2008 | Compaq NX6110 TFT XGA Notebook
Windows locks-up during start up
That's a hardware report you are talking about. The drive has problems.
Mar 23, 2008 | Computers & Internet
Computers & Internet Logo
Top Insignia Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Carlos L. Burgos
Carlos L. Burgos
Martin Clarke
Martin Clarke
Are you an Insignia Computer and Internet Expert? Answer questions, earn points and help others
