When I turn on my camera, the only way it will work is if I want to look at the photos I have taken. If I switch the camera to "Take Picture" mode, the camera will beep and then turn off by itself. I think the lens might be damaged because it seems stuck, but do I have to bring the camera to an electronic store to get it fixed? Or is there a way I can fix it myself? Thanks
Is the lens sticking out at all? does it look square to the body? the front has a square opening is it square with the rest of the camera? Some times a weak battery can cause this or debris in the gears of the mechanism. Sometimes tapping on the unit while powering it on can free the lens and it will function. Sometimes a fresh charged battery will also work. It sometimes can take a bit of power to get it over the jam. Have you dropped it or banged it recently? have you shot in a dusty enviornment latley? sand, dust wind? these conditions can cause problems.
Just wanted to say that the tapping method actually worked! My Powershot SD450 was in a dusty/rainy environment and the screen didn't make any kind of jamming noise at all... just wouldn't open when I turned it on, the camera beeped five times and shut itself off (I have a cracked screen, so I couldn't tell if there was an on screen error). I tried tapping and pressing on the lens area while powering on and after about 10 tries it worked. I ended up opening the camera and trying to dust it out as well. Just wanted to say thanks BowerR64
I have a Canon Digital Camera IXUSi 4.0 mega pixels and everything works except I have no picture in...
(More)
I have a Canon Digital Camera IXUSi 4.0 mega pixels and everything works except I have no picture in the viewfinder. Please can you help Thank you
Every time I turn my camera on it asks me to set the time zone, area I am in, date, etc...again....
(More)
Every time I turn my camera on it asks me to set the time zone, area I am in, date, etc...again. It's causing problems when I download pictures. They're all out of order. Even when I reset the date, time, etc. it always asks me to reset it every single time I turn on my camera.
My IXUS 400 intemittently shows a Purplish unsynchronised picture on the display and it records this...
(More)
My IXUS 400 intemittently shows a Purplish unsynchronised picture on the display and it records this when taking the picture. - any suggestions please? It used to happen occasionally but now it happens most of the time.
