May have damaged drum
I may have inadvertently damaged the drum on our brand new Canon. This is because the person who installed it kept the Basic Operation Guide at home, so I could not consult the book on a paper jam problem. Two "experts" have agreed that the drum is damaged. Is there anything I can do besides replace the drum?
Can you try it, if it runs! or message of not functioning...Sometimes a reset do the job..just the quality of print is uncertain...
Posted on Sep 10, 2008
Print outs are coming blank in ir3025 ????
This might seem basic, but sometimes we overlook it when changing ink, or drums. Most come with a plastic seal at the bottom that you need to remove. Check if is still attached. Also, some laser printers need that a bar is slided to the opposite side (sometime back and forth) before installing the new cartridge.
After changing, try realigning, or notifying the system you changed the drum or the cartrigde; sometimes the problem is that is software locked. Hope this general guidelines help you.
Dec 22, 2014 | Canon IR3025 COPIER FOR 220 VOLTS ONLY
Moving Oce tds400 plotter
there is in fact a way to remove the cartridge. her is a link download the users hand book that has that information and more.
http://downloads.oce.com/ProductDownloads/Index/278
Oc TDS400 downloads drivers manuals software firmware and safety data...
Mar 11, 2014 | Office Equipment & Supplies
SIR,i AM RUNNING IR 400 FOR 2 YEARS THIS TIME ONLY wHEN I CHANGE A DRUM THE PRINT WILL BE GOOD WHEN 200 COPIES CONTINUOUSLY TAKING THE DRUM DAMAGED IT MEANS SMALL CRACK ON THE DRUM AT THE FRONT DOOR SIDE...
first, did you install complete Canon original drum unit or just replaced with not genuine low quality drum?
Maybe the problem is in bad quality of drum.
In original drum unit you get whole unit with new drum, blade and charge roller.
Second, you should inspect the developing cylinder, he is magnetic and in some cases something like paper clip or other metal dirt can stuck on it and cause breakage or damage of drum surface.
I recomend you to remove the toner unit, vacume it and check for foreign materials, also rotate the developing cylinder and look for damages or foreign materials.
Hope that something of this will help!
Aug 24, 2011 | Canon imageRUNNER 400S Copier
Np 6412 copy dirty lines length of paper
Sounds as if the drum needs to replaced. How long has it been in the copier? They are supposed to be good for 30,000 copies or one year. It could also be dirty optics ( mirrors and glass ). Drum is easily installed by the customer. Just practice with the old drum - removing and re-installing before using the new drum. Too expensive to damage when installing. **** open the copier, Look under the control panel and you should see two levers. Move the right one to the right - this moves the developer away from the drum. Then move the left one down and this releases the drum for removal. Reverse procedure and power up the copier. It will automatically run and set the new drum settings into the copier.
Dec 08, 2010 | Canon NP 6551 Black and White Copier
E079
The transfer drum cleaner HP
sensor (PS59) is faulty.
• The transfer locking driver PCB is
faulty.
• The DC driver PCB is faulty.
• The CPU PCB is faulty.
0000 The transfer drum cleaner HP
sensor does not go '1' when
the transfer drum cleaner
locking motor has been kept
on for a specific period of
time.
0001 The transfer drum cleaner HP
sensor does not go '0' when
time.
Jun 20, 2010 | Canon CLC 1120 Color Copier
Even with brand new ink, my canon iP4500 won't work
A few basic causes.
1. The cartridges you bought iwere not proper HP ones and many "clone" cartridges are known to have problems with the ink level chips
Take them back and get them replaced with a different brand
2. They are original cartridges but may still be faulty (rare but possible)
3. Your print head is clogged or faulty
Run your printerthrough the head cleaning process a few times and see if it clears up.
4 your cartridges are out of alignment
run the cartridge alignment process
if this information was useful please click below
Aug 12, 2009 | Canon Pixma iP4500 InkJet Printer
Error messages but I can't find the errors
ona brand new machine you get a starter cartridge, you will need to put in a new cartridge
Feb 01, 2009 | Brother MFC 7420 All-In-One Laser Printer
Canon c3220 won't print after new drum installation...
this error reoccors when one or more drums are damage or reach their end it is best to replace all the drums since they tend to go all at the same time almost
Aug 14, 2008 | Canon imageRUNNER C3220 Color Copier
k24674
jasbo
jasbo
