Question about Jl Audio 12W7 Car Subwoofer
Crack in cover
There is a curved crack in the cover of my sub i brought off ebay, how do i go about fixing the crack, what adhesive should i use
    President:
  • 3,130 Answers
Need to know where the crack is. Is it a shipping damage or was it cracked before?? Let me know PLEASE
Posted on Apr 03, 2006
How do I fix a broken toilet seat?
Toilet seats are often found very durable in designs and most of them are made of wooden or particle board to solid wood. Also padded seats are just a padded induced on wooden seat by any adhesive solution. So, its normal to find crack or patch on a toilet seat after long use or by any accident, which also can be repaired by you without any specialized knowledge. You will not need any advanced tool but Basic DIY tools .
Let see the step by step method of fixing a broken or cracked toilet seat:
Step 1: At first remove that cracked toilet seat from the toilet fixture by unscrewing the seat screws using a flat screwdriver.
Step 2: Spread the crack slightly and push wood glue or wooden adhesive solution inside of it. Make sure the glue coated entire inner surface of the crack.
Step 3 : Squeeze the seat together you can use bar clamp. Wipe out any excess glue on the outer surface of the crack
Step 5 : dry overnight or minimum 6 hours and re-install it.
Note: if you find it's cracked or split heavily , or if it is pinching your back. Or if it seems nasty to look at then think about it .Toilet seats are pretty reasonable, so price shouldn't be an issue. If you don't want to look at the nasty underside, get rid of it and replace with a better one.
This toilet guide will provide you all kinds of essential information about toilet and bathroom fixtures,product reviews , expert's recommendations .
Take what you need and Do it Yourself.
Apr 05, 2018 | Home
Do you have a glue I can fix a crack in fiberglass
Yes there are glues and sealers that will repair fibreglass though for an effective repair the crack should be ground out to a vee and a hole drilled at each end in the normal way.
If the area to be repaired is not stressed and the crack is small impact damage a reasonable temporary repair after preparation could be made with a structural polyurethane adhesive sealer, similar to that used for bonding windscreens.
If the crack is stressed it must be properly prepared and filled with fibreglass repair paste and then reinforced with layers of random mat and resin and finally woven mat for a reasonable finish.
Nov 17, 2017 | Boating
Leaking clear water
Mine did the same thing. I took off the bottome cover (you'll need a tamper-proof hex key) The seam on the bottom of the carafe warmer where the water passes though to heat up to make the coffee had a slight hair-line crack. I tried to order part from Delonghi but they said they wouldn't sell it to me because I was not an authorized dealer. (mumbling) I went to a hardware store and bouth a 2-step adhesive. (you need to make certain that it is heat resistant. (mine was 250f) I applied it according to directions and let it cure for 24 hours. Try to force some of the adhesive into the crack.. It has not leaked in over 30 uses. I checked it and found no deterioration of the adhesive so far. Good luck.
Apr 14, 2012 | DeLonghi Caffe Nabucco BCO70...
I have a NAXA 7in tablet and The screen is cracked, can you tell me how I go about getting this fixed.
There is no solution for you to fix the crack of your tablet pc even if you use an adhesive to bond it again the crack..If you want to get rid of the crack buy a new screen or go to the nearest technician and ask him to replace a new screen for your tablet pc...
Jul 05, 2011 | Tablets & eReaders
The plastic lid in our kenmore chest freezer model # 2538195681 has cracked and broken. Is this a repairable or replaceable item?
You can try to repair it. Dry it off and apply some good plastic tape, if it frosts up then you will need to replace it. Hope this was helpful.
Jun 12, 2011 | Kitchen Ranges
Wrong floor tile adhesive used. Contractor used timber floor adhesive instead of concrete. Some tiles cracking and adhesive not drying?
it depends on what kind of tiles they were. If they were soft tile, then they may crack anyway if the floor is not level, also if he made the floor uneven by using the adhesive they can crack. Many soft tiles are peel and stick and no adhesive is needed. If they were hard stone tiles then he should have been using grout to stick them down and grout the cracks in between as well. It sounds like you need to have someone else come in and re-access the problem as I can't see the whole situation, but it sounds like the tiles may need to come back up. You can either get the same guy to come back and fix his mistake or get some one else to fix it then go after him to messing it up. If you want to choose another person I recommend looking at www.superpages.com.
May 26, 2010 | Saws
The back cover of my monitor is cracked.
Usually most adhesives will NOT repair this. One could glue on a sheet of material to cover and support the crack, but that is not very practical. The best plan is to replace the cover. Either get new part from HP or find a cover being "parted" out as a lot are on eBay.
Apr 27, 2010 | HP Pavilion dv4000 Notebook
Broken screen on Blackberry Curve needs to be
you can use warranty or send it to the company and they will charge you if you hadnt taooken the warranty
Sep 12, 2009 | RIM BlackBerry Curve 8310 Smartphone
Jl Audio 12W7 Car Subwoofer Logo
281 people viewed this question
Top Jl Audio Car Audio & Video Experts
hoyzee1
Morne Olivier
Jamie Henning
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
