Question about Bosch Axxis WFL 2060 Front Load Washer
Bosch Maxx WFL2061 Scraping sound when rotating the drum
Hi - Out of the blue the machine has developed a scraping sound when I rotate the drum. Otherwise it works fine. Can you please assist? Will it completly fail soon?
2 Suggested Answers
  • 86 Answers
SOURCE: No drum action from my Bosch Maxx for Kids
Hi, How old is your maxx? Have you ever experienced this before?
This is quite a common problem and can be sorted quite cheap to. You will need to take the back off depending on which model you have to access the motor! Take the motor off and then we can sort the problem.....
Get back to me....
Posted on Mar 07, 2009
How do I fix my Bosch Maxx 6 washing machine. The drum wont rotate? Can I reset it?
Check the drum motor power supply if its OK then problem can be in the control box try to figure out the trouble. And trouble shoot it
Jul 19, 2016 | Bosch Maxx 6 WAB28260GB White 600 mm...
Something is scraping the drum as it rotates. How do I remove the drum to clear the debris?
You have a bad bearing it's about a 700 dollar repair and it takes 2 people 2 hours to do
Nov 07, 2013 | Whirlpool Washing Machines
Hi, my Bosch maxx 900 front loader washer was in the process of doing a load when a really loud bang happened..now it won't spin..makes all the right noises, but barrel won't move. Took off back panel and...
If you rotate the pulley on the back of the drum does it rotate the drum? i have seen these snap the back of the drum off. also they can have issues with the controller board for the motors which would require a technician to determine.
Oct 24, 2010 | Bosch Washing Machines
DRUM WILL NOT ROTATE AND WHEN MOVED BY HAND MAKES A SCRAPING NOISE
the drum belt is broken and this lets the belt tensioner ride on the motor shaft which gives you the scraping noise,you need to remove the front and top cover to replace the belt
Jul 24, 2010 | Whirlpool AWM029 Front Load Washer
DRUM MAKES NOISE WHEN TURNING ALMOST LIKE IT'S RUBBING AGAINST SOMETHING INSIDE THE MACHINE. SOUNDS LIKE DRUM IS TRYING TO STICK AT SOME POINT OF ROTATION.
check that all the support springs are connected and one is not broken. It is also possible that something is between the drum and the frame.
Sep 26, 2009 | Dryers
Drum seems to be loose. Metal to metal sound each time it rotates
the rear bearing is bad and maybe also the glides on the felt need to be replace they sell it as a kit
Aug 22, 2009 | Kenmore 98702 Stacked Washer/Dryer
Get back to me....
Mar 07, 2009 | Bosch Washing Machines
Scraping sound inside casablanca stealth fan
You need a new flywheel. Go here: http://www.bostonplus.com/parts.html#flywheel
Jan 24, 2009 | Casablanca Fan Stealth 3211T Ceiling
Scraping sound when tub is rotating.
The motor turning the drum may be bad OR the spindle or axle the drum turns on may be bad as well. The belt turning the drum may have been to tight thus putting too much pressure on the drum which eventually would wear it out then causing the noise which will only get louder as time goes on.
You will need to take off the back of the dryer and possibly the top to gain proper access to the drum and motor.
Jan 14, 2009 | Dryers
under wire of a bra caught in drum , I have taken out hundreds,Close Ireland
Nov 12, 2008 | Washing Machines
Bosch Axxis WFL 2060 Front Load Washer Logo
43 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
