Question about HP Pavilion dv6000z Notebook
Slow boot up
My dv6000z hp pavilion computer is taking 30min to boot up in the past startup only take 2 minutes. I tried cleaning the registry , i tried going to the msconfig to disable programs not necessary during startup. I also, check the memory which is 2g. Please suggest what i can do to speed up boot up time. addditionally , I run spyware software by name spysweeper, it clean all spyware for my computer. spysweeper cleaner is the other software i have install I run this every night.
    President:
  • 2,961 Answers
Spysweeper could be the problem, as it may be checking over the system before the pc is allowed to run, also if you have got more than one antivirus if any (hope you have!) or spyware programmes, they all use up system resources reducing your memory and processor speed, check what you have installed.
Remember, some trojans cannot be found by some lower end anti virus programmes, and can only be found by decent spyware programmes.
Also if possible run any antivirus and spyware programme in safe mode, to allow you to run it faster (F8 on boot up and choose safe mode)
Posted on Sep 10, 2008
Slow computer reformat
insert the cd, choose boot option >from cd > press continue and follow the insturstion from the disc
Nov 11, 2013 | HEWLETT-PACKARD Hewlett Packard Pavilion...
My HP laptop (Pavilion) is running very slow. I'm afraid to download the ''TV Specials'' we see advertised. Thx, Ray
download 'ccleaner' from filehippo.com & run it & remember when u run it, only check the temporary files,recycle bin,recent documents....
this might speed up ur notebook...
If you are using XP or Vista, you have this. You can access the boot menu by loading your MSCONFIG. During the boot up your computer issues a time out to find new hardware and software. You can short this time to boost your startup speed.
1. Open your Start menu.
2. Click Run
3. In the command screen type msconfig
4. In the system configuration utility, click either BOOT tab.
5. In the boot menu, change the default setting for Time Out from 30 to 5 seconds.
Jul 09, 2010 | HP Pavilion dv6000z Notebook
Did a recovery but computers still running slow. I would like to try a reinsall what do I got to do. to preform this. HP Pavilion Media Center a1600n
Running slowly could be a lot of things. It could be you don't have enough physical memory (RAM) in your computer to do what you want. Less than 1 or 2 GB might be seen as slow. If you really want to reinstall Windows, back up all the files you want to save to someplace else, like an external hard drive or thumb drive. You will have to reinstall all your programs (Office, etc) after you reinstall Windows. Take the CD copy of Windows that came with your computer and boot your computer to that. You may have to change the boot order by entering Setup (usually by pressing F2 when it starts). Make sure the CD drive is first in Boot Order. When you boot to the CD follow the instructions for installing Windows in the screens which follow. Delete any existing partitions and install it on a clean partition.
Mar 08, 2010 | HP Pavilion a1600n (882780776265) PC...
Froze. very slow. very hot
Sounds to me like the cpu fan,has died and the cpu is overheating causing the freeze, the slow running, and the excessive heat. the cpu is probably fried.
Jul 12, 2009 | HP Pavilion dv6000z Notebook
My hp pavilion mx70 is running so slow
The issue can be caused by many many reasons such as outdated hardware, overload startup programs, corrupt registry issues, too many junks, virus attack, poor security software taking too much system resources, remnants of uninstalled applications etc. The fact is, you should keep some system maintenance job regularly. If you don't want to do these manually, try the solution: http://www.speeduphp.com/fix-slow-hp.html
Meanwhile, upgrading hardware configuration (add RAM, change a new video card, larger-volume HDD etc) can be a fast yet effective way to improve your pc performance. But that won't be the most economical way, as you know you can't always afford to do that.
Jun 14, 2009 | HP Pavilion MX70 17" CRT Monitor
My HP Pavilion is running slow now, fairly new. How do I fix it?
Is the reaction time slow like opening up apps? Is it reading all the ram installed?And if all that is fine then there might be a program in the backround taking up your memory
Feb 27, 2009 | HP Pavilion dv6000z Notebook
Plss i need an urgent information i dont want to format my system cos everyone has been telln me to do that cos i forgorgot my administrator password on my hp dv 6000 pavilion series laptop pls wot do i do...
Google the OPHCrack Live Cd on another computer. download the cd image and then burn this cd. boot it on your laptop... this can take a while.... after it fully boots(which can take up to 30 minutes) it will display all windows passwords in the program window in the top let corner of the screen.... If your first boot off of the cd fails then choose a different video mode in the startup menu....
Feb 02, 2009 | HP Pavilion dv6000z Notebook
HP Pavilion Slow boot up
Well, that's absolutely abnormal. Generally the problem can be caused by many many reasons such as outdated hardware, overload startup programs, corrupt registry issues, too many junks, virus attack, poor security software taking too much system resources, remnants of uninstalled applications etc. The fact is, you should keep some system maintenance job regularly. If you don't want to do these manually, try the hp speed up tool http://www.speeduphp.com/ to give a free & full scan of your slow HP PC to find & fix all possible issues. Regards!
Oct 18, 2007 | HP Pavilion dv4000 Notebook
HP Pavilion dv6000z Notebook Logo
57 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
