Question about Mitsubishi VS-45607 45" Rear Projection Television
Channel volume I have one, maybe two channels with no sound. I know the network is ok as my other televisions have sound on those channels...Can you help?
    Novelist:
    Champion:
  • 203 Answers
Make sure that the sound setting in the menu are NOT set on SAP. The sound should be set on stereo. Use the mitsubishi remote to pull up the menu then go to the audio portion and look for that setting. If you need more help or it is set on stereo let me know and we can go further.
Tim
Posted on Sep 11, 2008
Is there a way to set the volume so i dont have to keep changing them all the time
hello, are you referring to the volume of the TV set when you change channels? to reiterate every time you change channels the volume also changes? in this case I do not want to speak too much but I'm almost certain that television providers are required to adhere to a volume leveling standard which would require television broadcast stations to broadcast at a certain volume level for unity. Are you watching cable television? I happen to know that not all cable television providers level they're broadcasting some do.I notice that you are using a CRT unit are you attempting to use a converter box with the unit? If you are using a converter box there may be a chance that volume level is one of the options in the menu, I can not say there is much at all you can do about this.
As an alternative your television set maybe damage and the volume maybe adjusting randomly or in a way other than intended.
Good luck and thanks
Questions? Just ask!
Nov 25, 2015 | Televison & Video
Sounds and volume is ok but no sounds coming out from all channel on video
Hi
If you have sound on AV mode and no sound on channels then there is something wrong with the setting in sound system function, you can do this using your remote, find a setting some where on sound and you will have to change frequency to get good sound.
regards
Ashwin
Aug 03, 2013 | JVC AV-A21M3U 21" TV
I just switched to an HD receiver. The sound on the HD Channels is lower than the sound on the regular channels. How can I fix this? Dishnetwork has aready checked their end.
Some Sanyo TV's have a feature called Dynamic volume, this feature can be enabled by just pressing the dynamic volume button on the factory remote. We happen to offer a similar feature called volume leveling on our VIP 722k, 612, and 222k receivers. This is a recently released feature that will keep the volume even, during commercials or when changing channels. To access this press menu 6-1-6 and select enable under volume leveling.
Daniel Busa
DISH Network
Customer Service
Oct 03, 2010 | Sanyo DP37647 37 in. LCD TV
I have a Sharp 19 with no sound on some channels.
Make sure it is not on the SAP or secondary audio setting. Some channels broadcast English and Spanish or English and Silence. If you are set on the second audio broken you may hear nothing. Check your manual.
Jul 30, 2010 | Sharp 19 in. LCD HDTV
No sound on channel 3
Maybe the cable signal is defective not your tv.the other channel is ok.if you tv has a defect all channel has affected.
Jul 02, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
No antenna tv signal
Your dish remote should be set to the code for your TV. Then you will be able to control the channel number, not just up/down, as well as volume and maybe even the input. But do try to get a real remote for your TV so you can get to its menus.
Meanwhile, use menu+menu to see the channel being output by the Dish receiver. (Must be a 622/722... based on the 60 you listed.) Try to find an unused UHF channel number that your set does have in its up/down list. Match Air/Cable setting of Dish and TV. The Dish output is analog (NTSC) although the tuner(s) only accept digital (ATSC).
-Ken
Jul 26, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
The volume on my television has sound when playing dvd or vhs, but does not have sound when it is on a television channel.
that indicates that the amplifier is fine, the problem is that sound on a channel is combined sound and picture signals,
you can fine tune a channel,
if that is happening on all channels, a tv is suppose to alingned with a signal generator
Mar 17, 2009 | Orion STV2763 27" TV
Getting remote to control the menu
I'm not really sure why it's doing that...are you sure the remote has working batteries? I know that's a dumb question, but some times it happens. I just checked my remote and I have pretty much the same tv as you. Maybe you're just not operating the remote correctly. Click on the menu button, use the channel up and down buttons to scroll up and down. Once you got to something you'd like to change, click on "ok" to the right. To adjust sound, time, date, setup stuff, just experiment with it. You either use the up and down channel buttons or the left and right volume controls. Once you're done, click on ok. If you want to go back, press menu again. Hope it helps.
Jan 16, 2009 | RCA TruFlat 27F520T 27" TV
Ww42lhdtv10a
Turn off the sound options you have active in the customer menu see if that fixes it first.
Aug 29, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Mitsubishi VS-45607 45" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
