Question about Husqvarna Forest & Garden 125c 17" Curvgastrimmer
Husqvarna string trimmers 125c
Having trouble getting it to start, its not even firing. The gas has been changed out as well as the spark plug and gas line. I was using the trimmer and when it died I can't get it to crank now.
You can contact vie email or call 318-655-8409
Thank you
  • Antonio Boscia
    Antonio Boscia May 11, 2010
    what happened when it died? did it make any kind of noise or start to hesitate then stall?
Check throttle cable near connection to carb. It has to go around the semi circle guide or it does not work.
Posted on Jun 15, 2011
  • 50 Answers
Check for a spark. If none, then the coil is bad. Replace it. That should solve your problem.
Posted on Feb 14, 2009
Looks like oil and fuel is leaking or blowing from exhaust.
John - Husqvarna makes really good power equipment that seldom offers trouble. The unit you are talking about is a 2 cycle system, meaning you mix oil and gas together in lieu of having an oil sump at the bottom of the engine like 4 cycle motors have. First question, did you mix a bottle of One Mix 2 cycle oil to a gallon of regular gas to start off using your machine? If you did, then I would think your unit is badly flooded, which happens a lot with 2 cycle equipment. Try taking out the spark plug and see if the spark plug looks wet from too much fuel. If it is, leave the spark plug out for a day or so to allow the cylinder head to vent the gas fumes. Replace the wet spark plug with a new one and try to start the unit again. Here's a tip: If you do flood a 2 cycle piece of equipment (trimmer, chainsaw, blower, etc.) again, make sure the choke is off and hold the throttle trigger wide open. Pull the started cord several times until the unit starts to run. Keep holding the throttle wide open until it clears itself out. Remember, you run the equipment, it does not run you :-)
Aug 01, 2016 | Husqvarna 223L 24.5cc 2-Cycle Straight...
Will not fire
Do you have a spark.? Even a new plug wont spark if you have a damaged switch or ignition module.
Spark - Fuel - Compression. If you have all 3 it should fire.
May 24, 2013 | Husqvarna Garden
Husqvarna Problems
Have you changed the fuel tank vent.? Could possibly be a vaccum being created in the fuel tank, starving the carb of fuel.
May 21, 2013 | Husqvarna 128LD 28cc 2-Stroke Gas-Powered...
Husqvarna weed eater starts , but blows alot of smoke & then stalls out
Rod, Carb. may need adjusted, try loosening gas cap and start to see if cap vent plugged, there is a in tank fuel filter that you could fish out and remove to see if it is plugged. If still not running remove muffler and clean spark arrester screen, if screen plugged the trimmer will do this.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
String Trimmer Starts Then Stalls
My String Trimmer Starts But Won Stay Running
Craftsman Trimmer starts then dies
How to Clean Spark Arrestor Screen on Small 2 Cycle Engine Quick Fix
How to Clean Two Cycle Two Stroke Engine Carburetor
Sep 06, 2012 | Husqvarna 128 LD Weedeater
How can I determine if my husqvarna magneto is working?
Remove spark plug from the engine, reconnect it to the plug cap cable which come from the bobin.
Find a piece of steel wire jumper, atleast a foot. Make a jump from the metal body of the plug to the chassis of the engine.
Safety issue: Place the plug away from the spark plug's hole on top of the engine to avoid gas ignite.
Set the trimmer on the floor, set the gap of the spark where visibility while you pull the string.
Pull the start string and the arc could be seen right on the plug gap. Consider an Arc Purple or Blue coloration are good.
If the arc has not been seen, the Magneto need to be serviced.
Jun 11, 2009 | Husqvarna 28cc Gas Line Trimmer
Husqvarna 324LDx 4 cycle string trimmer. Have
Probably needs a carb kit, check main jet and main fuel inlet jet, is the spark crisp, fat and powerful, try running it with a borrowed coil as this may have an intermittent fault. Is fuel cap breather working or blocked, these small carbs are very sensitive. Make sure all is well with gaskets and diagrahms. Good luck the Yeti
May 17, 2009 | Husqvarna 28cc Gas Line Trimmer
Cannot start my trimmer, even change the spark
Take off the air cleaner and squirt gas in the carb. If it fires it is not getting gas from the tank. If it does not fire pull the spark plug and squirt a little gas in the cylinder. Replace the plug and try starting it. If it fires it is not getting gas from the carb.
May 14, 2009 | Craftsman 25cc Gas Line Trimmer
Husqvarna Forest & Garden 125c 17" Curvgastrimmer Logo
813 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
