Sony D-VM1 Portable DVD Player with Screen
Problem for Sony D-VM1 Portable DVD Player with Screen
DVD Player not working
By buka on Apr 03, 2006
I have a DVD player. When I am trying to play an any CD whether it is a DVD or MP3 or Ordinary CD it is showing the message as 'OPEN'. After that it is not responding. Could you please tlle me what could be the problem and solution.
Thanks
Vijay
Same Problem
Jun 26, 2008
-   SAME THING HAPPEN HERE and I only used it for 4 months-   meilouie
Jun 22, 2008
-   downloaded drivers-   Guest
Apr 03, 2008
-   Mine won't power on at all. If yours does, you may be able to reset it..go here:
http://www.jvc.com/support/documents/DVD_Procedures.PDF-   Guest
Feb 26, 2008
-   none-   Guest
Feb 25, 2008
-   How do I reset the DVD player?  That was one of the solutions posted.  Is it as simple as unplugging over night?  As a hand me down from parents, I was lazy and left it in the car for several months (shame on me).  Now that I finally decided to bring it inside to use after plugging in the DVD player it shows the red standby button.  When you push the on/standby button, it remains red.  Sometimes it looks like it is trying to start (no noise) with the center screen on the DVD player showing ---(division symbol)---. Can't seem to get the DVD tray to open either.  Any suggestions? -   jiggly_foam
Best Solution
posted on Feb 04, 2008
Very Helpful)
naga24183
Rank: Apprentice
Rating: 100%, 4 votes
i have dvd player, but me inser disk. then dvd told me error disk, then me inser another one disk, same reply, waht i can i do?
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Aug 07, 2007
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
buy a diffrent brand i have nothing but problems with my dvdr 1000. cant even get any buttons to work
Solution #3
posted on Apr 03, 2006
Somewhat Helpful)
techman
Rank: Guru  Sony Expert
Rating: 86%, 7641 votes
Your problem is the small switch that a small boss hits when the doors closed to tell the unit the door is closed.. Its eather the small boss is broken from the door or the switch blades cracked. If you feel comfortable to open small electronics you may be able to open and see if it is the tiny switch BUT highly NOT recomended as there are micro fine wires and ribbon cables inside this unit that can be easaly broken.Best thing to do is to take or send this unit to an authorized repair shop.
Was this helpful?
Yes
No
Solution #4
Somewhat Helpful)
BowerR64
Rank: Wiz
Rating: 80%, 980 votes
Have you tried to power cycle the unit? These units have small computers in them and from time to time need a power cycle. Un plug it and let it sit over night then try it again. Some times a simple reset can cure its ilness.
It may also have a timming problem with the door. WHen it was open did it get bumped? it could be off track and thing its open when its actualy closed because it has a timming problem. Try a power cycle first.
Was this helpful?
Yes
No
Solution #5
posted on Feb 28, 2008
Not Rated)
Kaz-1
Rank: Apprentice
Rating: 0%, 0 votes
I just purchased a dvd hd player phillips dvp5960/37 I also own a 37 inch panasonic tv. I can see normal movies ok and sound is good but when I put an HD movie in I get nothing but spinning. This happened with another dvd player that I bought and I figured it was a problem with the DVD player so I bought a different one which is the phillips. Does anyone have a clue as to why I cannot play an HD movie on this thing. I also have a bell satellite dish and it plays the television HD channels fine. ???? im confused!!!
Was this helpful?
Yes
No
Solution #6
posted on Dec 22, 2007
Not Rated)
lb032407
Rank: Apprentice
Rating: 0%, 0 votes
i havea rj4100 it was saying wrong disc when dvds were put in, so now it is stuck in p-scan and all i get is a snowy screen you cna't access menu
Was this helpful?
Yes
No
Solution #7
posted on Feb 27, 2007
Not Rated)
Joelcress
Rank: Guide
Rating: 92%, 3 votes
I too am having a simliar problem with my DVC880D. Were you able to resolve?
$35 to just have a local repair look at it, and that's not including parts. For that price, I'm half way to a newer unit (and anything other than a SYLVANIA).
Comments:
Apr 03, 2007
- I did power down. That was the initial resolution Sylvania's support gave me. Did not work.
I've opened the case to see if I could isolate the problem, but I have no idea what I'm looking at. If it was a computer DVD drive, then I'd be good to go :P
I'll play with the dead one to see if I can get it working, but I'm not too concerned now. For the price they want to just to look at it ($35) I bought a new RCA DVD with DIVX.
Note to self: Never buy Sylvania.
Was this helpful?
Yes
No
Solution #8
posted on Jan 24, 2007
Not Rated)
daffff
Rank: Apprentice
Rating: 0%, 0 votes
I have philips HTS3400 dvd home theater system from America U.S.A Is only played region 1 and I want it to play other region like region 2
Comments:
Jan 24, 2007
- I have sony DAV-DZ100 Home theater system from U.S.A it only play region 1 I want it play other region like region 2
Jan 24, 2007
- I have DURABRAND dvd-1002 from America I want it be multiregion. It play region 1
Was this helpful?
Yes
No
Popular Solutions for Sony D-VM1 Portable DVD Player
Questions and Unsolved Problems for Sony D-VM1 Portable DVD Player
Do you recommend Sony D-VM1 Portable DVD Player with Screen?
Answer
Answer
elect.816e,plays but dorsn't have any sound! tim.
Answer
my dvd player reports error disk when i put any type of disk. how can i solve the problem
Answer
i have a dvd player not working after 2months, when i insert a disk it says no disk but it can play... (More)
Answer
i have a dvp5960/37 and it is locked. the screen says "title" i can't even shut it off.... (More)
Answer
i have a electrochrome dvd 816E player. i can see the picture but not getting any sound. It is not... (More)
9 Other Users Have The Same Problem - Continued
Comment by donethat, posted on Jan 14, 2008
Have the mustek mp95 dvd player. Menus and everything work but wont play cd,dvd, etc. Evferytime put something in just get the message that there is no disc present. It does try to read everytime though. Also, when bypassing to lid closed and observing the optical scanner everything else seems to function properly. I have tried to power it down over night the reboot but still kaput!! Help with ne advice.
Comment by Guest, posted on Jan 06, 2008
Not sure if this is the same issue but when disc tray retracts I can hear the disc drive cycling. I opened and inspected unit and found that the rubber band used to retract then raise the disc drive into place was slipping. Evidently it has stretched and starts to slip when trying to raise the drive unit up into place. Anyone know where I can get the rubber band.
Comment by Guest, posted on Nov 06, 2007
CD works fine but DVD it only shows after how many seconds then it shows on the screen DISC NOT AVAILABLE please tell me if this is goodbye or tell me what parts need to be replaced and how much. Thanks
Comment by Guest, posted on Nov 04, 2007
I opened up the dvd casing, and saw a plastic bar trapping the CD under it. I can't see any small switch. Previously have already switched the power on and off but still no movement.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sony D-VM1 Portable DVD Player...:
Top DVD Player Experts
Rank: Guru Guru
Solutions: 801
Experience: 30 Years of professional repair and design.
Ask Me
Find more DVD Player Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(21591) 042-9690
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
