1991 Mercedes-Benz 190 Logo
Posted on Nov 27, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The air intake valve/choke on carberator/ fuel block will not funtion properly , open up, it is continuely closed chokeing no air intake, there is a vacume line not connected, on this carb, does it control the opening/closeing on the carb, and where does it belong connects to where, it's on my 1991-190-e fuel injected
Rigger DeBusk
Level 3:
  • Mercedes-Benz Master 1,811 Answers
  • Posted on Nov 27, 2017
Rigger DeBusk
Level 3:
Answers
1811
Questions
8
Helped
453285
Points
4826
Firstly, if it's fuel injected, there is no choke. That cold start mode is actuated by the computer. IF it has a carb on it, the choke is opened a little to keep it running with a vacuum line connected from the choke dashpot to the carb base when cold till warm-up, then a heat spring pulls the choke full open. Your gonna have to make up your mid as to whether it fuel injection or natural aspiration with a carburetor.
5 Related Answers
Anonymous
  • 4 Answers
  • Posted on Nov 10, 2008
SOURCE: Intake Manifold choke diaphram for 98 ford windstar
no you need the vacum hose that is what keeps persure on the acc.
Anonymous
  • 75 Answers
  • Posted on Feb 14, 2009
SOURCE: SL600 retractabke top/trunk closure problem
send your car to authorized dealer for diagnose,or you my read your owners manual for closing your roof manually,
Anonymous
  • 408 Answers
  • Posted on Apr 29, 2009
SOURCE: does the mercedes-benz 1986 mercedes 560 sel have
hello, 560 sel,,,model 126.039 engine with v-8,engine number 117.968 ke is is fuel injection system.ref. book;technical data mb,ty
Anonymous
  • 407 Answers
  • Posted on May 08, 2009
SOURCE: HOW TO REPAIR FUEL INJECTION FOR GMC YUKON 98
check for plugged fuel filter on the frame rail on driver side, blow through it to see if it is plugged. also have fuel pressure checked if it is below 60 psi replace fuel pump
Anonymous
  • 6982 Answers
  • Posted on Jun 06, 2009
SOURCE: Blazer rumbling,choking,missing in engine
Check the fuel pressure regulator. generally "failure" position is full open which will richen up the fuel mixture. also check vacuum line to the regulator for cracks and good connection.
1helpful
2answers
My 4.0 V6 will not run when it's cold unless i hold the accelerator down till it's warm?
I'd say the throttle doesn't choke properly. Older carburetors used mechanical link with a thermostat to choke the carburetor meaning the intake flaps would close so the fuel mix would be extra rich in fuel. Once it was warm the thermostat would disengage and the throttle would open up allowing more air and thus better efficiency. Not knowing how old the vehical is makes this a bit tough. Have you cleaned the MAS sensor? Bad air flow detection could make the computer think it's running too rich so it may lean out the fuel equation to compensate.
3answers
My 1983 toyota pickup carburetor flap wont close and it is letting in more air then fuel, so it dies when ideling. how can i fix this?
After 20 years on the road, the carb need to be taken apart and cleaned. It's a work for a mechanic.
Acts like the choke is stuck closed it won't stay started and runs ruff until engine warms up then its fine. What do i do?
Well the choke has an electric part that heats up and makes the choke open in a few minutes. As soon as the engine starts the choke should open about 25 percent by way of a vac pull-off.
You can take the air cleaner off and watch the choke while someone starts the engine cold. If the choke does not open after it starts, check the choke pull-off. You can also open the choke with a screwdriver to see if the engine clears up.
I have a 1994 3.0 L tarus and i have replaced the fuel pump and the maf sensor and it still doesnt run but when i take the intake hose off and choke the intake the car will run fine then i will put the...
Check the fuelpreasure make sure you are gettin g enough fuel, next is check the idle air control valve, it sounds like its getting to much air and not enough fuel if you block off intake you air restricting the air, also the map sensor check that also.
8helpful
3answers
2001 mazda tribute v6 runs rough cold ildes at about 200 rpm till it warms up then its ok what could it be
I replaced the upper & lower manifold runners seals, now it runs perfect, The reason it runs ok when warm is because the manifolds expand and seal the gaps on the surfaces that the worn old seals are not closing. Also change the spark plugs.
1helpful
2answers
1981 dodge power ram carb problem with choke sticking and deisling some times at shut off
One problem is related to the other.The dieseling is caused by a rich air/fuel mixture which is caused by the closing choke.So you need to adjust the choke to where it is slightly open when the engine is cold.If it is electric then it has a thermostatic device that positions the choke just cracked open when cold and slowly opens as the engine heats up.Whats happening is the choke may actually be loose and when the engine shuts off the vacuum pulls the choke close creating the combustable rich fuel mixture(if you watched the choke when someone else turns off the engine you'll see the choke flapping while the engine is dieseling).Try putting a screw driver in the carb(with engine running) blocking the choke from closing.Then shut the engine off.It shouldnt diesel.You may have to replace the carb thermostat
3helpful
3answers
My 2.8 carb.chevy motor has no power and is spuing black carbon and fuel out of the exhaust when idling.
your pistons have all been burning oil. there is a break in a seal somewheres and will need to be serviced. continual usage without repair will ruin your engine.
1993 jeep grand cherokee, choking, pulling then stalled,
Check:
- Fresh Air Intake Hose: Clogged or Damaged FreshAir Intake Hose.
- Carburetor: Worn, Faulty or Damaged Carburetor.
- Mass Air Flow Sensor: Damaged, Loose, or Faulty Mass Air Flow Sensor or Circuit.
- EGR Valve: EGR Valve Sticking Open/Leaking.
- Idle Air Control Valve: IAC Valve Sticking or Faulty.
Good luck.
Top Mercedes-Benz Experts
ZJ Limited
ZJ Limited
xxxxxx xxx
Arnie Burke
Arnie Burke
Are you a Mercedes-Benz Expert? Answer questions, earn points and help others
