Question about Whirlpool SF367 Gas Kitchen Range
Electronic oven control malfuntion
Constant oven display (F4E2 over temperature cook) consistantly come on until I push the stop button. Display come up while I have on bake and shuts oven off every 5 minutes. I have tried unplugging several times
  • sametime Sep 10, 2008
    (F4E2 over temperature cook) consistantly comes on even when bakeing and have to push the stop button. Tried unplugging several times
    thanks
    Genius:
  • 2,035 Answers
Bake range over temperature:At room temperature, sensor resistance should be 1K to 1.1K. If not, replace the sensor. If the sensor checks okay, replace the control.You need the check the resistance with multimeter ,if you want parts you can get in this link:
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
Good luck..
Posted on Sep 10, 2008
    Master:
  • 726 Answers
Over temperature cook i would say your thermostat has gone ot the senser to read the temperature the oven thinks its to hot and shuts down
  • chris07551 Sep 10, 2008
    yes i have a few people who agree its defiantly the sensor the senser that reads the heat of the oven
    Sergeant:
    Champion:
  • 331 Answers
Is your oven new??????????????
the display is in Hex as far as i can guess may be the micro controller is faulty and needs to be changed
do not switch it on and off this will not help solve the problem
    Genius:
  • 1,847 Answers
This seem issue with the senser.
How do you change the key pad from celcius to ferenhite on my whirlpool acubake oven
Look for the button marked "Precise Clean" in the upper left corner of the control panel.
Press and hold this button for five seconds until the display reads "Temperature Unit Celsius.
Release the button and push it again for another five seconds until the display shows "Temperature Unit Fahrenheit."
Push the "Off/Cancel" button to lock in the Fahrenheit setting.
Jul 10, 2011 | Whirlpool SB160PEE Gas Single Oven
How do i set the time on w westinghouse pgn659s wall oven?
Instructions below.
  1. 1 Fill the insert of the Corningware slow cooker with food and cover it with the lid. At least a quarter of the insert should be filled with liquid to keep the environment moist during long cooking times.
  2. 2 Press the "On/Off" button on the left side of the electronic control panel in the front of the appliance. This will turn on the slow cooker to the low heat "Warm" setting.
  3. 3 Press the "Cook Time" button on the right side of the electronic control panel to add hours to the timer which will show a total time in hours with a red digital display. Continue to press the button until the display indicates the desired cook time in one-hour increments up to 10 hours. The cooker will automatically adjust the temperature setting based on the amount of time you programmed on the timer. Cooking times of six hours or less automatically start on "High" heat and times of seven hours or more will start on "Low" heat. A small indicator light will come on below the word to tell you the cooking temperature.
thank for visit.
Oct 09, 2010 | Ovens
Turn on oven cleaning, but clean indicator stops after few seconds
hello
what this need is to set the reprograms
here are solution below
You can set the timer on a Corning ware slow cooker to automatically switch to a warming setting when you estimate Foods will finish Cooking The programmable features allow you to leave food stewing at home while you are out of the house, freeing up your day. Set the timer on a Corningware slow cooker to let the kitchen appliance do all the Work, and come home to a fully cooked meal.
  • Fill the insert of the Corning ware slow cooker with food and cover it with the lid. At least a quarter of the insert should be filled with liquid to keep the environment moist during long cooking times.
  • 2 Press the "On/Off" button on the left side of the electronic control panel in the front of the appliance. This will turn on the slow cooker to the low heat "Warm" setting.
  • 3 Press the "Cook Time" button on the right side of the electronic control panel to add hours to the timer which will show a total time in hours with a red digital display. Continue to press the button until the display indicates the desired cook time in one-hour increments up to 10 hours. The cooker will automatically adjust the temperature setting based on the amount of time you programmed on the timer. Cooking times of six hours or less automatically start on "High" heat and times of seven hours or more will start on "Low" heat. A small indicator light will come on below the word to tell you the cooking temperature.
  • hope this hope ?
    thanks
    Oct 03, 2010 | Ovens
    Resetting the clock
    You can set the timer on a single oven slow cooker to automatically switch to a warming setting when you estimate foods will finish cooking.The programmable features allow you to leave food stewing at home while you are out of the house, freeing up your day. Set the timer on a Corningware slow cooker to let the kitchen appliance do all the work, and come home to a fully cooked meal.
    INSTRUCTION BELOW.
  • Fill the insert of the single oven slow cooker with food and cover it with the lid. At least a quarter of the insert should be filled with liquid to keep the environment moist during long cooking times.
  • Please rate this solution after use.
    Thank you and thanks for using fixya.
    Oct 03, 2010 | Maytag CWG3100A Gas Single Oven
    I have lost my manual for a Simpson Appolo Atlas Stove
    call manufactuerer and ask if you can order one or try to do so online
    Dec 22, 2009 | Stoves EC500DOA Electric Kitchen Range
    How to set the oven timer?
    To Program Oven for a Delayed Start Time and to Shut-Off Automatically 1. Be sure that the clock shows the correct time of day. 2. Place the food in the oven. 3. Push "Bake Time". "00:00" and the words "BAKE TIME" will glow in the display window. 4. Push and hold up or down arrows until the desired baking time appears in the display. 5. After the bake time has been set, "----°" will appear in the display and the word "BAKE" will flash. The display will flash and beep once until the oven temperature has been set. 6. Push "Stop time". The time when baking will stop, will appear in the display window. The words "BAKE STOP TIME" will glow in the display. 7. Push and hold up or down arrows until the time that you want cooking to be completed appears in the display. 8. Push Bake (or Conv). "---°" will appear, and the word "BAKE" will glow in the display. 9. Push and hold up or down arrows until the desired baking temperature appears in the display. 10. If the baking temperature is not set, the control will beep. "---°" will flash and the word "BAKE" will appear in the display.
    Mar 11, 2009 | Electrolux Kitchen Ranges
    Timer instructions for a Rangemaster Toledo dual fuel 90 required
    OK, here we go, this is actually a fairly lengthy explanation, but I will do what I can to explain.
    The timer can be used to turn just one, or both ovens on and off automatically, however the start and stop time must be the same for both ovens, though different cooking temperatures can of course be set, so if you play around with temperatures to extend the cooking time of an item in one oven, you can often cook items needing very different settings for the fixed time you set in both ovens. Note that when the timer is on and the AUTO message is on the display, the ovens are disabled and will ONLY work during the timed period unless the timer is disabled again. (This is a common problem when you first power up, because the AUTO setting is automatically engaged on installation or power up after a power cut, disabling the ovens until you figure this out!). So, with all that garbage out of the way, how to use the timer settings:
    For ease of understanding, I will refer to the buttons on the control pannel (Running from Left to Right as: BELL, HOT DISH, COLD DISH, HAND, + and -)
    TO TIME SOMETHING THAT'S ALREADY COOKING (Minute Minder). Press and hold down the BELL symbol (Far left), use the + or - to adjust the amount of time you want to cook for (You can check time remaining at any point, or cancel the beeper when the time is up, by pressing the bell button.
    TO STOP AUTOMATICALLY AFTER YOU HAVE MANUALLY STARTED COOKING. Press and hold the COLD DISH button at the same time use + and - to adjust your required stop time. AUTO will show on the display. When cooking is finished, the beeper sounds. TURN THE OVEN TEMPERATURE KNOB TO "0" FIRST, then press the HAND button, once to stop the beeper, and again to cancel auto and return to manual mode.
    TO START AND STOP THE OVEN MANUALLY: Before you start, decide when you want the cooking to stop and how long you want the food to cook for (The cooker will work back from your stop time and figure out the START time for its self.). Press and hold down the HOT DISH button and at the same time set the minutes and hours you want the oven to cook for with the + and - buttons (You are NOT SETTING THE TIME HERE, you are setting how many minutes and hours to cook. Next, press and hold the COLD DISH button and use the + and - to set the stop time (YOU ARE SETTING A TIME IN THIS OPERATION). AUTO will show on the display. Set the temperature for the oven (or both ovens) that you want to auto cook with. When cooking stops the beeper sounds. Press the HAND button to cancel the beeper and press the HAND again to cancel AUTO and return to manual mode. (Note that the beeper stops after a while if you leave the oven attended, but the manual states you still have to press the HAND button twice to return to manual, I have not personally tested this).
    GETTING BACK TO MANUAL MODE. If AUTO is showing on the display, because you have set automatic and no do not need it, or you have just powered the cooker up, any cooking time already set must be returned to 0:00 before you can return to manual, so hold down the HOT DISH button and ensure the display is set to 0:00, once you gave done this you can press the HAND button to return to manual mode
    Dec 22, 2008 | Rangemaster Toledo 90 (Dual Fuel) Dual...
    Oven temperature only gets to within 20-25 degrees of temp. set
    next to last page in your manual
    Adjusting Oven Temperature
    Oven temperature has been factory calibrated and tested. If
    oven consistently over or under cooks food, adjust thermostat.
    Oven temperature can be increased or decreased 35°F. To
    avoid over adjusting oven, move temperature 5°F each time.
    1. Push BAKE pad.
    2. Press + pad until an oven temperature greater than 500°F
    shows in display.
    3. Immediately push and hold, approximately 5 seconds,
    BAKE button until “00” appears.
    4. Press + or - arrow pad to adjust oven temperature.
    • To increase oven temperature (for a hotter oven), Press
    pad until a positive number appears in display.
    • To decrease oven temperature (for a cooler oven),
    Press pad until a negative number appears in display.
    5. Press OVEN CANCEL pad to save adjustment.
    • Setting is saved if power fails or is disconnected.
    heres a link to the entire manual if needed
    http://shop.amana.com/assets/pdfs/literature/32103601.PDF
    Nov 27, 2008 | Amana AOCS3040SS Electric Single Oven
    Thermador 30" Dual-Fuel Range 0FF error
    Make sure there is proper electrical power going to range. Then check your kitcen circuit breakers or fuse box in your house, then reset the oven controls.
    LOL look what i found, a CHILD LOCKOUT FUNCTION-- check this out
    TO SET CHILD LOCKOUT
    Press and hold the COOK MIN/HR and STOP TIME buttons until indicator word OFF appears in the
    display (approximately 6 seconds).
    TO CANCEL THE CHILD LOCKOUT
    Press and Hold the COOK MIN/HR and STOP TIME buttons until indicator word OFF disappears
    from the display (approximately 6 seconds). Mode selections will now be available on the control panel.
    looks like someones could have been playing with the buttons and locked you out..
    Let me know what happen.........................please rate this
    Oct 15, 2008 | Thermador RDF30 Dual Fuel (Electric and...
    MayTag Stove Model MES5770AAW
    Here are the codes for Maytag Ranges:
    MAYTAG
    Type "C" and "D" Clocks Range/Stove/Oven Fault Codes Failure
    Code
    Condition Check/Repair F1 Supervisory relay enable shorted (non-cook mode); sounds alarm and inhibits cook mode if alarm fault monitor is always active in non-cook mode, and requires removal of power until serviced. Usually a bad touch pad or clock assembly (also called the ERC). Replace touchpad or ERC F2 Bake/broil/clean temp runaway alarm; sounds alarm and resets control to non-cook mode when bake/broil/clean temp exceeds programmed limits. Usually means a stuck relay. Electric @ 525F (bake), 640F(broil), 900F(clean)
    Gas @ 525F (bake), 640F(broil), 900F(clean) F3 Open temp oven temperature sensor; sounds alarm and inhibits cook mode Replace oven temperature sensor F4 Shorted temp oven temperature sensor; sounds alarm and inhibits cook mode Replace oven temperature sensor F5 Supervisory relay enable open (cook mode); sounds alarm and resets the control to non-cook mode Replace electronic range control (ERC) F5 Missing a/c line cycle detector; displays code (no audible) Unplug appliance for two minutes, should clear problem F7 Function key shorted; too hot at the clock assembly (also called the ERC) or shorted touch pad or clock assembly (also called the ERC) Replace touchpad or ERC F8 Analog/Digital supervisory; sounds alarm to non-cook mode Replace ERC F9 Door latch supervisory (door latched) Unlock door and check switches or clock assembly (also called the ERC) F0 Cancel key supervision Requires the removal of power until serviced. See qualified technician
    Dec 04, 2007 | Magic Chef CGS3760 Gas Kitchen Range
    Whirlpool SF367 Gas Kitchen Range Logo
    286 people viewed this question
    Top Whirlpool Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Ismael Rodriguez...
    Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
