Question about HP Pavilion dv9000z Notebook
Won't power up
My laptop won't power up.  It tries to power up, then stops and makes a hiccup noise.  It then powers down and tries to power up again.  This happens over and over again.  The only way to stop this is by unplugging it and taking out the battery.  Help! When I try to power up the unit most of the time the screen stays completely blank, the CD drive seems to whir a bit then all the lights go off and the process starts all over again. After going through this process I usually "kill" the unit and restart all over again. The problem is not related to OS (reinstallled), boot order (set to boot from HDD). Really annoying never knowing if and when the unit will power up. Also, what's the definitive answer to the wireless card not being recognized any longer problem?
  • 72 Answers
I can't help you with the first problem, but as far as the wireless card, if you reinstalled Windows, you have to reinstall the wireless card driver.
Posted on Sep 10, 2008
Monitor won't come on when power on
Try unplugging it and then plugging in again, and make sure the monitor is turned on.
Apr 20, 2013 | Acer Aspire 5600 Series 5630-6951 Laptop
Hp laptop won't power on
Hello. It sounds like either...
1. Your power adapter is damaged/not working. Look and see if a LED is illuminating on the power adapter. If it is chances are it is working fine and the problem may lie on your laptop. If not replace it. The easiest way to tell if your power adapter is bad is to go out to Wal-Mart or your local technology store and purchase one of their universal power adapters. They are expensive but you can buy it, try it, and return it if it does not solve the problem.
OR
2. The DC pin on your laptop is bent/broken/loose. Look at where your power adapter plugs in on your laptop. Get a paper clip, bend it out to make a long paper clip and slightly push its tip on the pin inside your laptop. If the pin moves chances are either the DC pin needs to be soldered down or needs to be replaced. The part is usually cheap around $10 but the labor can cost more than $50
Dec 11, 2012 | HEWLETT-PACKARD G72250US Laptop
Laptop won't turn on
Remove main battery and try again, have the power supply adapter checked, the DC jack in the motherboard is another source of trouble from no power to intermittent operation, at this point the laptop must be dismantled to down to the main board to address the issue.
May 25, 2012 | Lenovo IdeaPad Y530 Laptop
Dv6000 won't power up
Remove main battery and try again, next! have the power supply adapter checked for output voltage, if okay! the DC jack in the laptop is a common source of trouble, at this point the laptop must be dismantled down to the motherboard level to address the situation.
Apr 26, 2012 | Computers & Internet
MY SAMSUNG P35 LAPTOP STOP ITSELF ON BATERY AND AC POWER
This maybe heat problem.
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Mar 27, 2012 | Samsung P35 HZM (NP35TP0FL2/SUK) PC...
My laptop was left with the top down and turned on. It was plugged in and when I opened it to use it again, the screen remained black. I tried using different keys but nothing would happen. I unplugged...
Hi, Nan.
Disconnect the power adapter, flip the laptop, unlock and remove the battery. Then, reinsert and lock the battery, connect the power adapter and try again.
Hope this helps.
Jul 30, 2011 | Toshiba Computers & Internet
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Jul 16, 2011 | Toshiba Computers & Internet
My dell inspiron 1545 won't shut down went i click on the shut down icon it won't turn off .
Hold down the power button for 10 seconds. That will hard-shut the PC. Once that is done, fire it back up, and try again. Somethimes, windows will act goofy shutting down. Especially Vista when it is left on too long without shutting it down.
Jun 20, 2011 | Dell Inspiron 1545 Notebook
Won't power up
Did u hear any beeps???
Oct 28, 2007 | HP Pavilion zd8000 Notebook
HP Pavilion dv9000z Notebook Logo
41 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
