-   I have a I-Inc 191D monitor, on the left side of the monitor is a 1 1/2" horizon Black vertical Line which prevent part of the deshtop from veiw.-   Ralphf
first, I would check screen cable. try replacing it with a new one, you will be surprised to know how many display problems are are caused by a defected screen cable. in case this is not the problem, it can get more complicated, but first, just in case, reinstall drivers. its a long shot, but if you get lucky it will save you alot of pain. in case it didn't help, It's probably a bad vertical output chip. if you have some familiarity with monitors and decent soldering skills you could probably fix it yourself, but I would advise looking into taking it to a shop, or at least find an experienced hobbiest if you're not yourself. It's a pretty straightforward fix for someone who knows what they're doing.
my acer monitor flashes colors when the computer is turned off. It will only stop if I unplug the...
(More)
my acer monitor flashes colors when the computer is turned off. It will only stop if I unplug the monitor. any suggestions?
Monitor buttons stop working, including power on-off when in suspend mode. Also, colors cycle on the...
(More)
Monitor buttons stop working, including power on-off when in suspend mode. Also, colors cycle on the display continuously. Have to start the system to turn off monitor the shut down computer
