Question about Dell Latitude D600 Notebook
No power through the laptop dell d6oo
When i plug in charger the LED light on the charger goes off but no power goes to laptop, i tried using differnt chargers but same problem
  • 72 Answers
There's evidently a short on the laptop's motherboard. Unless it's something obvious that can be repaired easily (and it'll still cost a lot for the labor to take the laptop completely apart and put it back together), you're going to have to get the motherboard replaced (expensive)or get a new laptop - depending on which seems more cost effective to you.
In any event, contact Dell.
Posted on Sep 10, 2008
Orange light trying charge
I would try this:
take the battery out
unplug the charger
turn upside down
hold power button down for 1 min
keep holding power button down as you turn over the laptop
while still holding power button down plug in charger and try to power on
Jan 26, 2014 | HP Computers & Internet
Using a Dell Inspiron no apparent power to laptop with our without a adapter. New universal laptop charger...still light on charger goes off as soon as connected into laptop power port.
hi
sounds like the laptop has a motherboard fault, dell laptops need to be run from dell chargers only and at correct voltage and correct amps output. the information is normally provided on lable on the base of the laptop, universal chargers do not normally work on dell laptops, would suggest you try and use original dell charger .
Aug 07, 2013 | Computers & Internet
My Dell Laptop was working fine in 220V country, when i moved and try to use it in US (110V) the charger LED is ON but once i plug it in the laptop it goes off and the laptop is not working. i even tried...
So two different devices, each with their own charger, don't work in different power outlets in different rooms? How about if you plug a light into the same outlet. Does the light work? Does it dim when you plug the charger into the laptop? If so you have a bad electrical system, either a loose wire or bad outlet.
Jul 15, 2017 | Dell XPS M1330 Notebook
My dell D810 won't power up. After pushing the power button, one LED light comes on. About 5 seconds later, that LED light goes off. I swapped power adapters and symptoms remain the same. The battery is...
Please try the following troubleshooting steps:
1 Disconnect the battery and the charger
2 Let it sit for 1-2 minutes.
3 Press and hold down the power button for 30 seconds.
4 Connect the charger (don't connect the battery yet) and try to start by pressing the power button.
Let me know if everything remain same.
Feb 18, 2010 | Dell Latitude D810 Notebook
When I plug in the power cord to charge the battery, the light on the cord goes off. I tried several charges and they work. Can charged battery on another computer and place on the dead computer and it...
There's no fuse problem with that computer, try this first, Plug in the charger to an outlet don't plug it in the laptop, if the light on the charger turns on, then the charger is working try to plug it on the computer if the light on the charger goes out there's a problem with your motherboard. Contact the tech support for that so you can get that part replaced.
To double check try to use a known good charger if it works then you'll need another charger if not, Then contact your tech support for your dell make sure you still have a warrant.
Hope this helps!
Feb 15, 2010 | Dell Latitude D505 Notebook
Green light cuts off when plugging into laptop
Replace the charger, it probably overheat and died.
Try with a voltmeter to measure the output power (usually aroud 19 V DC)
Then the tricky part, try to power something else with the charger , something who might work with the output power (a car light bulb for exemple).
If it does work then you have a short cut on the motherboard of your laptop if it's the case replace the laptop, it's the hell of a job to repair the motherboard...
good luck
Dec 12, 2009 | Dell Inspiron 1501 Laptop
Power failure on Dell XPS M1530
sounds like a bad charger, try taking out the battery and plug in the charger to the laptop and see if it will boot if it does it might be a bad battery
Sep 25, 2009 | Dell Latitude D600 Notebook
Old battery not charging plug in charger green light goes out
If the system will not power on, and the LED on the AC adapter goes out when plugged into the system, then the most likely senario is the motherboard has failed. Remove the battery, Wireless card, Drives, RAM and connect the AC adapter see if anything changes. If no change, the MB is most likely bad.
May 01, 2009 | Dell Latitude D505 Notebook
Dell Inspiron 2200 Charger Malfunction
Try to turn off the computer and remove the battery from the bottom of the notebook. Turn on the computer with just the charger plugged in. If it doesnt turn on. you may have a bad power port.
If it has no power/charging issue since that happened except that the indicator light doesnt turn on when you plug in the charger, you may just need a bios update. Click here. That's the bios update for the inspiron 2200 from dell's website. You should have at least 30% charge on the battery and the ac adapter should be plugged in so you can run it. The computer will restart and will come back normally after this. I'd suggest that you backup your files before running this.
Sep 28, 2008 | Dell Inspiron 2200 PC Notebook
Dell Latitude D600 Notebook Logo
95 people viewed this question
Alun Cox
