Question about Kenwood KM800 Major Classic Stand Mixer
Kenwood chef A701A capacitor and other components.? I thought it would be a good idea to replace the capacitor on my Kenwood Chef A701A because of its age and before it blows!! Can you tell me if the 0.1microfarad capacitor on the A701A motor control board can be replaced by a maplin capacitor metallised paper 0.1mF N69CN (275V) or is it an electrolytic capacitor -I cannot see any polarity marked. If not any other known source?? I have used the above capacitor parrallelled with a 0.047mF one to successfully repair my daughters A901 mixer board 0.15mF capacitor which had burnt out. Also there are three components hidden beneath shrink plastic tubing on my A701A board, do you know what these are and if it is worth just replacing them. Two are white plastic shrunk in series with the Live and neutral supply wires and one is black and connected between the 0.1mF capacitor terminal and a terminal on the motor board. I think the A701A was made in the 1950/60s do you know? Thanks.
The 0.1 microfarad can be safely replaced with a 275 VAC 0.1mF mains capacitor. You can remove the clip that held the old electrolytic capacitor by sliding the old capacitor out and squeeezing the metal clip so that it disengages with the plastic base. The load resistor is 450 Ohm 15W or 20W wirewound. There is a 56 ohm resistor in series with the capacitor which helps smooth the speed change and reduces wear on the contacts. A 2W wirewound resistor works best. (It is worth removing the contacts and removing any pitting or carbon build up with fime emery paper). I have repaired about 20 speed controls sucessfully with these components.
Posted on Dec 27, 2008
Sorry I can't help with your A701a - but could you please advise exactly which maplin capacitor you used with your daughter's A901 - link would be useful - I only ask as my existing (blown) A901 capacitor is a 0.15mf (150nf) - thanks
Posted on Sep 15, 2008
  • tahc1 Sep 15, 2008
    Apologies - I should learn to read :- )
    You used two capacitors in parallel to make up the 150nf - the N69CN and I'm guessing the N68CN
    I got confused as the A901 also has another 0.47uf capacitor on the circuit board
    Thanks again
You have hit the nail on the head, i have repaired my Kenwood Chef with these two AC type capacitors. The Electrolytic type which came out with the mixer are not available anymore. What i did was buy a 0.1 uf AC cap and a 0.01 uf AC cap, twisted one leg of each together, soldered wires to the three legs and used Heat Shrink to seal the joints up. The difference between an AC, or non Electrolytic Cap and an AC Electrolytic Cap are that the Electrolytic one is ever so more responsive. My mixer is now good for another 10,000 miles. The caps dont have to be spicifically Maplin caps, as long as they are the correct value and are 220volt rated.
Regards
Brian Le Roux
Posted on Apr 25, 2009
    Problem Solver:
  • 5 Answers
The capacitor is rated at 1000V a modern cap will be OK .01uf and the resitor is 450ohm 15w there is a resitor across the resitor which is 56Ohm 2W there are 2 small ferite chokes on the mains input . Have a look on ebay full kit with all the components for 17.00 do a search for kenwood motor repair
Posted on Dec 17, 2008
SERVICE MANUAL FOR KENWOOD CHEF A701A
Hi Alfred. I don't have the manual but I have repaired dozens of these machines. Do you have a specific question?
May 10, 2013 | Food Mixers
I need a service manual for the Kenwood Chef A701A. Can bGR1 help please
Can I please also a have a service manual for my kenwood chef a701a mixer. e-mail is ncb06045 AT gmail DOT com DOT au
thanks
Feb 10, 2013 | Food Mixers
Kenwood Chef A701a Service manual
Hi, my email is: jespersovndal@live.dkcan you send me the service manual too?Thanks
May 11, 2012 | Food Mixers
I need a service manual for a KENWOOD CHEF model A701A Francis Barclay. fbarclay@ihug.co.nz
Hi, Can you please send me copy of A701A service manual. My email address is bhaymes@engineer.com
Thanks
Nov 08, 2011 | Kenwood KM400 / KM410 Chef Classic Stand...
Drawing of Kenwood Chef A701A
Can someone email me service manual please? S1m0nh@hotmail.com thanks in advance
Jul 30, 2010 | Kenwood Food Mixers
Manual download for Kenwood chef A701A
there is one here...
http://web.archive.org/web/200707171...tions-A701.pdfbut the pages are in the wrong order and i think some are missing.
Mar 13, 2010 | Kenwood Food Mixers
Kenwood Chef - slowest speed
if you have max speed you have to replace the .1uf capacitor the 2 spring loaded screws serve far fine adjustment
Feb 02, 2009 | Kenwood KM400 / KM410 Chef Classic Stand...
Kenwood Chef A701A Motor
Hello graham.
yes we can supply the armature to A701
or maybe the problem is another's .. is necessary check all machine first before change the armature.
Regards
Kenwood Chef Restore
Jan 05, 2009 | Kenwood KM800 Major Classic Stand Mixer
Difference Kenwood Chef A701 and Kenwood A901
Hello.
the difference between A701A and A901 is :
high speed outlet
slow speed outlet
planetary hub is similar . A701A, A901 and KM series
A701 Different planetary hub and fit different tools.
is not same A720 and A920 A7 = A701/A
A9 = A901 and KM
In our web site Kenwood Chef Restore in Downloads section.
you can download the compatibility of the models A700, A701 , A900 and KM series .
Regards
Oct 02, 2008 | Kenwood KM400 / KM410 Chef Classic Stand...
Kenwood KM800 Major Classic Stand Mixer Logo
3,123 people viewed this question
Top Kenwood Food Mixers Experts
ashburton
Owen Barnes
Are you a Kenwood Food Mixer Expert? Answer questions, earn points and help others
