Question about HP Scanjet 5470c Flatbed Scanner
Colored horizontal lines in my scanned image
I am trying to scan an 8x10 picture and when I open the scanned image in Photoshop there are colored horizontal lines through the image. They form bands of green red blue then a skip then three more green red blue lines. Is my scanner shot??
hughv
  • 196 Answers
SOURCE: Horizontal Banding
From the Microtek KB: www.microtek.com Scans that produce lines, fading, and discoloration generally result from a corrupt scanner driver installation or a burned out lamp. To determine if your problem is caused by a burned out lamp, simply open the scanner lid and check the color of the lamp. If the color is a shade of red, pink, or green, then the lamp is burned out. Perform a scanner preview to get a clear view of the lamp. If the lamp is a bright white and the problem still exists, please contact technical support.
Posted on Jun 11, 2007
Noggin
  • 944 Answers
SOURCE: How do I scan colored paper and still read print? HP Scanjet 8270
First thing to try is just play with all the scan settings to see what gives you the best result - try changing resolutions, type of document, type of output document, contrast, brightness, type of scan. If this doesn't give you any better results, then one of the best ways to do this is to get some plastic sheet of the same or almost the same as the predominant colour on your forms (you can go one step further and make a multi coloured filter if you are feeling creative and your forms are all identical). The text jumps out of the page and most scanners will give you a good scan - just make sure the filter is not too thick/dark. Hope this helps :)
Posted on Jun 25, 2007
tom19511
  • 1601 Answers
SOURCE: color lines
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bps03820&lc=en&cc=us&dlc=en&product=57956&lang=en
Posted on Nov 10, 2007
Bubbabear64
  • 2794 Answers
SOURCE: Blue-green background colors in scan with HP 5470c scanner
Uninstall the drivers.
Reinstall the drivers at this link
Posted on Jul 09, 2008
  • 3 Answers
SOURCE: i have this same problem, colored lines in the scanned image
I have the same problem. Can't get any help from HP.
Posted on Dec 15, 2009
Scan/copy issue: horizontal lines and bulb red
It's the scanner fluorescent lamp faulty, replace the scanner will solve the problem
Jul 15, 2017 | Samsung CLX-3175FN Color Laser All-in-One...
It started out with alot of different colored squiggly lines it would clear up after about ten minutes but it just shut off yesterday the red button on the front still flashes though
Especially Projection TVs will shut down to protect the projection tubes because loss of proper scan can burn an image into the phosphors in the tube itself. The squiggly lines most likely are a symptom of a failure in the Horizontal output section (the part that scans the picture from left to right), there is also a possibility of the Vertical output section (the part that scans the picture from top to bottom causing the problem. This will require replacing a circuit board or repairing the one in the set at a component level. This is best left to a qualified Technician to do the work.
May 29, 2010 | Sony KP-61HS30 TV
Mustek Scan Express A3 USB
Got same problem. Beginning to suspect the traveling lamp or associated electronics. Looking out for parts suppliers for elimination trials. Strange, once in a far while it works. Updated drivers again this very day.Suggest you try a good power adapter, and if you are technical, search for loose connections. Will keep you posted if I solve mine, being an electrical engineer, NOT electronics.
Pax
Jan 15, 2009 | Office Equipment & Supplies
HP 5610 scanner won't save image
I just need to understand the exact issue. It sounds like you are able to successfully scan, see the preview of the scanned image, and you initially save it. Then, when you go to open the saved image, you don't see the image you scanned but rather a "line". You've saved the image in a number of different image formats, but there's no difference in the result. It saves the scanned image to the location you want to save it on your computer's hard drive (probably My Pictures if you're using a Windows operating system).
Not sure what you mean by a "line". Do you mean a vertical line, a horizontal line, a diagonal line or what? Also, is it just a solid black line on a white background? Is it the image you scanned compressed into a smaller vertical or horizontal space?
Have to tried scanning both text pages and graphic pages? There have been issues where a document with both text and pictures has been scanned but when the scanned image is viewed, only the text appears. The pictures don't make it. The description of this specific problem is at HP.com.
I take it you don't get any sort of error message associated with this problem. Unfortunately, I can't find your specific problem at HP.com beyond the link I posted in the above paragraph. If you can answer some of the questions I asked, it might help me provide a better solution.
Thanks.
Sep 25, 2008 | HP Officejet 5610 All-In-One InkJet...
Scanning 35 mm slides
SOUNDS LIKE A SOFTWARE CONFLICT.BUT IM NOT SURE
Jul 28, 2008 | HP Scanjet 4470c Flatbed Scanner
Lines appearing in scanned images
it is due to following reasons 1. dust on lense 2. connector problem 3. laser lense gone 4. missalingment
Sep 28, 2007 | Microtek ScanMaker 9800XL Flatbed Scanner
Horizontal Banding
Jun 06, 2007 | Microtek SCANMAKER 4850 Flatbed Scanner
HP Scanjet 5470c Flatbed Scanner Logo
1,099 people viewed this question
Ben Johnson
