Question about Samsung Digimax A5 Digital Camera
LCD is showing wierd colours and patterns - Samsung Digimax A5 Digital Camera
    Novelist:
  • 130 Answers
Sounds like you have damaged the LCD. The LCD is made of 2 sheets of glass and then there is a liquid between the sheets that carry light. Sometimes the glass can crack and the liquid will leak or bleed and then the unit needs a replacement LCD. An impact can crack the glass, dropping it or freezing the unit. A damaged LCD is common because they are so small and thin you cant push on them. A used LCD runs about $40. labor may be a bit more if this is the problem. People buy broken cameras on e-bay it maybe cheaper to get a different unit. If its under warantee you may be able to sxchange it. On the bottom of your camera there is an A/V port you can hook the unit to a tv. To verify the screen is damaged hook it to a tv and see if you can see an image on the tv in record or review mode and see if the LCD and the tv view are the same. You could still use it if the LCD is damaged but you will need another way to view the menu. I have done this
Posted on Apr 03, 2006
Radeon hd6670 showing strange colours on my monitor occasionally
hello,
this "colours"appear becuase the graphic card cant display the image is too big to handle,check the spec for the game if your car is ok if yes maybe the graphic card itself has a problem.
Jun 11, 2012 | XFX Radeon HD 6670 - graphics card -...
Colour on my alba tv looks wierd
Digital processor section and T'Con board should be suspected.
May 02, 2012 | Alba LDVD1538WDCH LCD TV
Monitor is changing color when power on:- red, green, yellow, violet, white, blue etc......repeating continuously ...... more tha ten times switch off monitor but the problem remain the same... VGA...
1706,
the monitor is bad if OSD , menu shows bad colors
try the reset in the OSD menus,,
google, HP L1706 manual, read it.?
some newer hp monitors even have test pattern in the OSD pages. (on screen display) try that.
Oct 04, 2017 | HP L1706 17" LCD Monitor
N70 display white please solution mee
Dear friend:
First get the lcd checked
Second connector of lcd
Third display driver crystal IC
Fourth get the smps ic power controller checked
Fifth get the line checked (lcd ic to lcd connector)
and last get the omap (cpu) checked
Nov 25, 2009 | Nokia N70 Cellular Phone
SAnyo 32" LCD: Pattern appearing on the screen after sometime
im sorry friend, your processor over heated and the Processor is toast, they will fix it and it will work for a month or 2 then it will **** out on you again. so best to get another one. i know this problem all to well
the reason the processor over heated is becasue the fan cut out, prolly seased up.
May 02, 2009 | Sanyo DP32648 32 in. LCD TV
Xacti camera shoots stills with a grid pattern
The grid pattern is in the settings of the camera, its designed for architecture photography, you can remove it in the menu.
Jan 08, 2009 | Sanyo Xacti VPC-S60 Digital Camera
I have an LCD TV. All of a sudden the picture colour has gone wierd. The best way to describe it is that it is similar to either a colour negative or one of those scientific 'false colour' images. This...
TFTs can produce a wide array of colors, but it takes an enormous number of transistors to make up a display, and a problem with any one of them creates a defective pixel on the screen. Typically this shows up as a bright spot on a dark background, caused by a damaged TFT failing to turn off a pixel. Most active matrix displays contain a few bad pixels, but a few bad pixels are not going to have much of an impact on the overall picture.
The properties of liquid crystal material can create problems with viewing angle effects, causing the image to darken, disappear, or reverse the dark and light tones when the viewer is not directly in front of the display (kind of like looking at the negative of a photo). The light bulbs make LCDs heavier than the plasma TVs (though they are still lightweights compared to CRT televisions.
Benefits of LCD TVs include a picture that can't burn in and doesn't deteriorate over time. Because of their flat-panel nature, placement options are plentiful, optimizing the cool factor over standard TVs
Apr 30, 2008 | Televison & Video
COLOURS WILL NOT WORK ON PRINTER
What does the nozzle check pattern show? If the check pattern is patchy or has lines missing then you need to clean the head. If you are using rubbish compatible inks instead of the genuine stuff then doing head cleans may make the situation worse.
See my previous post about under head cleaning and follow the instructions there.
If the check pattern is good you may be experiencing a common CX problem with one of the vacuum pipes. A rescue kit is available from tradebit
Oct 11, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Wierd colours on LCD screen.
Check LCD ribbon cable. 99% LCD ribbon cable is defective. Replace LCD ribbon cable.
Nov 09, 2006 | Panasonic PV-GS31 Mini DV Digital...
Samsung Digimax A5 Digital Camera Logo
147 people viewed this question
Top Samsung Cameras Experts
Jerry Z
Andy Bale
Andy Bale
Are you a Samsung Camera Expert? Answer questions, earn points and help others
