Question about Riso RZ220 Duplicator
Rp 3100 Drum Problem
I have a Risograph RP3100 that we have not used for a couple of months. When we tried to use it there is what I would call a dry spot on the drum and the text in that area does not print. I tried pulling the master back and rubbing the area with alcohol but that did not help. Any ideas????
  • Anonymous Jan 14, 2009
    SAME PROBLEM ANY ANSWERS
  • 22 Answers
You can clean it, thats a good idea but,,(and this is messy) roll back the master.. take out the ink cartridge, use a rod to squeeze some ink onto the area, and smooth it out into the screen with a plastic scraper.. Lay the master back over. Keep scrap paper around and print a big black square and run a couple hundred sheets through.. This will work. Messy but will work. If you don't want to manually put some ink on the area.. Print a large black square and run a couple hundred sheets.. see what that does.
Posted on Aug 10, 2009
Hi
WD40 spray and rub in the area with finger where you don't get image works great !! Thank you Dermot for your help.
Posted on Oct 03, 2016
What error for Wrong side print slinder
Posted on Jul 20, 2013
  • 682 Answers
After cleaning with  alcohol leave drum for a couple of days in dark place nd try again.
Posted on Sep 10, 2008
2 Suggested Answers
  • 19 Answers
SOURCE: Risograph Drum
Try run a hundred copies at slow speed and full density/ pressure.
If that fails get a can of WD40 and spray it under the master, then rub the area with your finger. this will desolve the dryed ink on the drum surface.
Dermot
Posted on Mar 08, 2009
How do i change the color of riso drUm from red to burgundy?
How-to: Convert Z-type Color Drums ' stencil.wiki
stencil.wiki/how-convert-z-type-color-drums Procedure for converting the color of a Z-type drum. Steps 1 - 9 also work ... Z-type Color Drums. Posted: 17 Oct 2014 14:04 by issuepress Last edit: 01 May 2015 14:20 by issuepress ... This tells the Riso to recognize newly installed ink tube.
Riso RP3505 drum color change - CopyTechNet.com
www.copytechnet.com > Forum > Technical Forums > Digital Duplicators Sep 9, 2008 - 3 posts - ‎3 authors Is there any way to change an RP color drum to black? How to change a drum color on a Riso MZ 770E? (I'm new ... 3 posts 8 Apr 2014 Riso gr3750 Drum versus GR377\GR373 Drums. 6 posts 1 Jul 2013 Riso RP3700 Print drums wont ink up 7 posts 28 Sep 2012 Riso GR 3750 alignment, drum and colour change ... 9 posts 3 Oct 2009 More results from www.copytechnet.com
change color drum riso Questions & Answers - Fixya
www.fixya.com > Forum > Tags Find solutions to your change color drum riso question. Get free help, tips & support from top experts on change color drum riso related issues.
Risograph GR drum conversion.mp4 - YouTube
z? 0:25 https://www.youtube.com/watch?v=YCttIfFdu0Q Jun 30, 2012 - Uploaded by SpareResidency Used citrus solvent to clean the exterior of an old red drum then switched the ink for a new tube of blue.
My Top 7 Risograph Lessons - Alfalfa Studio
alfalfastudio.com/my-top-7-risograph-lessons/ Jun 16, 2014 - When you need to add another color, you open up the drum door and change the drum to use purple, for example. The Risograph prints one ...
Replacing The Print Drum (cylinder) (color Change ...
www.manualslib.com > ... > Printer > RZ1090 > User manual Riso RZ1090, RZ1070 Manual Online: Replacing The Print Drum (cylinder) (color Change), Replacing The Print Drum (cylinder) (color Change), Removing The ...
Riso printing - Instructables
www.instructables.com/id/Riso-printing/ Risograph The underlying technology is very similar to a mimeograph. ... This master is then wrapped around a drum and ink is forced through the ... Change the color drum, change the paper on the glass sheet, make a master layer and . ... Remember that every different color you want to print, you have to print separate.
Jan 31, 2016 | Office Equipment & Supplies
Risograph 3770 Drum problem
Seems the 'synchronisation' between paper feed and drum ist lost. Maybe you have heard a ripple sound? This means the toothed belt has jumped one or more teeth.Remove back cover loose paper feed clutch to readjust the belt accordingly ...
Sep 03, 2012 | Riso RP 3700
Hello I have to run a risograph tr1510 that have not been used for a couple of years or more. The drum are completely dry. I read this post: http://www.fixya.com/support/t4515933-risograph_rp3700_not...
I don't think WD40 oil is the best solution.
I had to do such a procedure a few months ago. - I got a drum which was not in use some month. This is normally no problem with original ink. But some cheap plagiators have their own ink recipe.
I used a solvent for professional offset printers. It is the one to clean the ink rollers with. it was blue colored and I think it is so with most manufacturers. (I have seen some brands for this purpose and all were lighter or darker blue.)
By the way, it isn't so easy as it seems: The drum looks clean enough after some time. But to remove really all of the hard and gummy ink inside I had to take the drum apart. It took so much time and was so dirty so I will do this again only if I get paid accordingly.
Dec 31, 2010 | Riso RZ220 Duplicator
Have a Risograph RP3700 that we have not used for a couple of
try cleaning the dry spot with WD40 or penetrating oil to melt down the ink
Apr 08, 2010 | Riso RZ220 Duplicator
I have a riso RP3100ui. I am looking to buy a used drum. Currently i use only black ink. I see used drums on ebay and alike but they are colored drums. Can I put a black in cartride in a rp3100 drum and...
No.. A color drum is a color drum. You can change any color drum and re-program it to be a different color but you can't use a black drum for anything else. The RP is a sophisticated machinge and even the card inside the black drum is different. I think it would give you an error at some point.. Besides the fact you'd go through about a half a tube of ink before you got the new color.. I've converted color drums as you say.. even after 5000 sheets of paper I still have the old color on the sides and stuff. My local service shop changed one of my drums to a different color for $175.. I thought it was a good deal after doing it myself once. Helluva mess. You want to use a color drum as black.. Might work..maybe.. but I've never tried it.. If there's a problem with your black drum... buy a color drum and strip it for parts (except the printed circuit board) and get your black drum working.
Jun 25, 2009 | Riso Office Equipment & Supplies
What does the error code E 01 stand for?risograph 4050
If its CR or TR, E-01 is main motor lock. turn off machine and hold reset button in while you turn the machine on again. Make sure your master removal unit and master feed unit are closed corectly.
Apr 07, 2009 | Riso RZ220 Duplicator
My Riso RP 3100 is not getting ink to the drum I switched out to another drum and the same thing- feels like the machine ''attacked'' the second drum the same way. Master is almost dry. Any help?
Ok,if you strip the drum open and remove the drum body there is a gear with a one way bearing on the inking roller remove that gear and clean the bearing and the sarft it is running on.If the machine is giving the same problem that ger needs to be replaced.
Remember if you strip the drum the drum is full of ink and can get everything full of ink.If you dont know how to strip the drum it is beter to get a qualified technicin to do the job.
Hope this was helpfull
Feb 25, 2009 | Riso RZ220 Duplicator
RZ 220 Risograph error code A-16-525 after paper jam indication. No jam was present.
The master is stucked on the print drum,open print drum remove master and try again.
Let me know for futher help.
Jan 26, 2009 | Riso RZ220 Duplicator
Risograph rp 3100 ui
Reset machine... and check connectors to the boards... its a communications error to the digitizer cpu
Oct 13, 2008 | Riso RZ220 Duplicator
Risograph Drum
Dermot
Sep 09, 2008 | Riso RZ220 Duplicator
566 people viewed this question
Top Riso Office Equipment & Supplies Experts
Marius Chiriac
paulfvincent
Adorjani Laszlo
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
