Trying to finalise a DVD-RW disc and it 'hangs' at 95% - have to power off to get it out of machine. Any ideas why?
  • iomaud Sep 10, 2008
    Hi Ginko
    I've always used Sony DVD-RW
    The programme I was recording was only 20mins long
    I'll try cleaning the head and see what happens.
  • 19,396 Answers
Even if a recorder is supposed to work fine on both +R, -R etc. , often you find out, that due to error correction methor, a device worksd well on one or the other type.
I often get troubles with many DVD low price brands, try testing some good ones like Verbatim, TDK, Sony , Philips etc.
Hope this had been helpful, test both a good brand DVD-R and a Good brand DVD+R.
If it still has problems when finalizing the CD, then it can be the usual lens problem, in this case try using a lens cleaner.
Or the DVD you are writing is too big in size and your player has problem on the final phase of DVD writing. If Data nearly takes all the 4.7 Gb allowed, there won't be enough space to finalize the DVD.
Posted on Sep 10, 2008
Initialising and finalising dvd -rw disc
Hi John, several reasons it could be, first off the DVD and Disk has to be compatible and finalise will only work if it was initialize on this DVD recorder. Cheers Greg.
Mar 30, 2015 | Televison & Video
I had a bunch of pictures on a DVD-RW that I transferred to a more permanent media. I then reformatted the DVD-RW disk. Now when I go to properties it says: Used space: 3.49 GB Free space: 906 MB How do I...
Rewritable DVD discs allow you to record and erase lots of times (up to 1000). Similar to DVD-R disc and DVD+R disc, DVD-RW is approved by DVD Forum, while DVD+RW not
did you finalise the disk after you finished the burn? depending on which burning software you are using some ask if you want to finalise the disk after a burn others just finalise or you might need to select multisession before the burn starts
hope this helps
Sep 08, 2011 | HP Computers & Internet
Model DMR-ES30VEB. I have had this recorder for a few years now but since I got a new Sony TV at christmas I am having problems recording. When I record a programme the DVD says it does not recognise the...
DVD-RW discs are ideal for temporary video recording and data backup, but they are not recommended for successful finalising, as there is no guarantee that the disc will work in another device.
Have you tried using DVD-R discs? these CAN be recorded in video mode AND finalised for compatible playback in other players. I assume the DMR-ES30V is a DVD/VCR combo unit - if so, the DVD recorder will not recognise RW discs; only DVD-RAM and DVD-R.
DVD-R discs are recommended for video recording and finalising in this model. (later model Panasonic DVD recorders allow RW disc recording).
Mar 26, 2011 | Panasonic DMR-ES30VEBS
I have dubbed vcr tape to a Sony DVD-RW disc and tried playing it back through a toshiba player and it keeps coming up Bad Disk. My PC won't even recognise it. When started dubbing the screen displayed 1hr...
Did you say you used a DVD-RW disc to transfer a videotape onto? The reason your PC won't recognise that disc is because the data format on it is a different language to what PCs understand - plus an unfinalised DVD-RW won't play in other DVD players - it is usually an incompatible format.
(DVD+RW discs with titles/top menus created in video mode CAN be played on a PC DVD drive or a normal DVD player as can finalised DVD-R discs (DVD-R discs MUST be recorded and finalised in the same recorder for compatible playback). DVD-RW discs can only be viewed on the unit they were written/recorded on.
The other reason for the 'remaining space' on the disc you describe showing less than 120 minutes is due to a title recently being recorded or erased - unless you format it - the 120 minute / 4.7GB DVD-RW will not show full available space. Erasing titles on re-writable DVDs does not increase space. The same rule applies to unfinalised +R / -R discs (you cannot re-format these to get the space back once recorded - they are 'once only' writables)
I recommend you invest in some DVD-R discs and re-copy your VHS tape to that - then if you are satisfied with the result, title etc., finalise the DVD-R - it will play on any DVD player or PC with DVD support (or it should). These discs are relatively inexpensive to buy just about anywhere.
Final note: do NOT finalise the DVD-RW you recorded (I hope you haven't already done this) - simply format/erase it - re-use it for something else or keep it until you need it.
You can use any brand of DVD, just take note of the format before recording/playing.
Mar 21, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Cannot play certain dvd discs the make is panasonic model num nv vp33
Panasonic NV-VP33 is a DVD/VCR combo unit. These are good, but limited in DVD media playback formats. It depends on the types of DVDs you are trying to play, and their region codes (if they apply).
This model will NOT play:
DVD-ROM / DVD audio / DVD+R (unfinalised) / DVD-RW / Blu-Ray (obviously).
This model WILL play:
DVD-R (finalised) / DVD-RAM (no finalising required) shop-bought DVD movies / CD-R (for JPEG/MP3/DivX) / DVD-R DL (finalised) / DVD+RW (titled or with a top menu to make them compatible with other players, but again, finalising not required).
You didn't specify which DVDs do not play in your unit.
I would be very concerned if your player didn't read ANY DVDs at all. I assume the image below is what the model looks like. I have never had any problems with mine.
Mar 11, 2011 | Televison & Video
Trying to write to blank disk first time (Memorex CD-RW). Get message: Record failed: wrong format for re-write Spectroniq SDR-205 DVD Recorder
Some DVD recorders cannot write CD-RW - only DVD-RW (+ and -) as well as DVD-R (+ and -) (this depends on the brand/model). This unit probably does not support CD recording. Try using DVD-RW instead for this machine - see if it records that (do not finalise even if unit prompts you to with an on-screen message prior to ejecting disc).
There are DVD players and recorders which can play CD-RW (mp3, jpegs etc.) but I don't know of any which record this format (a PC CD/DVD-ROM drive can do this though).
Mar 09, 2011 | Televison & Video
Finalising a disc enables the disc to be played on any other compatible machine. By doing this it changes the disc format so that you can no longer record to it turning it into a Play Only disc. On your Panasonic DVD Recorder you can record to many (if not all depending on the model) of the following DVD Disc formats to the limit of their capacity over multiple occasions. The disc in question can be played back and recorded to on the DVD Recorder during this time but until it is finalised it will not work on any other machine.
How do I Finalise my disc?
  1. When you have finished the initial recording stop the disc and press the ~FUNCTIONS~button.
  2. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad select "To Others" and press~ENTER~.
  3. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad Scroll down to "DISC MANAGEMENT" and press ~ENTER~.
  4. When the disc management screen opens you need to use the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad to scroll down to "FINALIZE" and press ~ENTER~.
  5. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad select "YES" and press~ENTER~.
  6. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad select "START" to begin finalizing the disc, please note by pressing start here you will no longer be able to record or edit the disc being finalized.
Finalizing may take up to 15 minutes.
Do not disconnect the mains power in this time. A message appears when finalizing is finished, press the enter button when this appears. It will now play on other compatible machines.
Apr 23, 2010 | Panasonic SDR-H40 HDD Camcorder
Recorded movie on dvd-rw will not play on another player
the best format to buy is the DVD-R but make sure your disc has been finalised if you reinsert your disc on the functions screen you should see finalise this is essential for compatible playback hope this helps regards Jim
Mar 26, 2009 | Televison & Video
Televison & Video Logo
74 people viewed this question
Top Televison & Video Experts
