Question about Dell (4T274-DE) Motherboard
Dell opteplix gx270 problem
My computer ( dell opteplix gx270 ) shuts down when i start it and when it begin to operat give me this massege ( the previous shutdown dueto thermal event )
  • ahmad_water0 Sep 10, 2008
    Novelist:
    Scholar:
  • 85 Answers
It is either dust build up on the CPU heatsink under the fan or that model is known for blown capacitors...
Open case and check motherboard for blown capicitors and / or dust build up on CPU heatsink
And if there are any bad capacitors then you will need to replace the motherboard.
Posted on Dec 02, 2008
My Dell optiplex gx 270 tower's chipset heats up and system shuts down and my friend's gx270 mother board is burnt due to same reasons
check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in
check you CPU make sure its securely seated and has thermal grease might be getting to hot
another possible reason could be a memory dump you might be running to many programs at the one time putting to much strain on the CPU central processing unit
hope this helps
May 06, 2012 | Dell OPTIPLEX GX270 (Y1057) Motherboard
Gx270 tower mother board amber LED solid on
If the fan is not spinning this can be the issue ...but it can also be the motherboard itself ..if you have the possibility try to change the fan ..cause if it fails to start the computer will also fail cause the cpu it will shut down the system instantly if it has no cooler working ..(gets to the shut down temperature in one sec or so ) If it seams that it is trying to start ..but , like I said , it shuts down ..just try to change the fan ...but it may be a issue with the power supply or the motherboard as well...
Dec 18, 2011 | Dell OptiPlex GX270 Small Mini-Tower...
Fan stop working but computer turns on after a couple of mins it shuts down gx270
fan stop working but computer turns on after a couple of mins it shuts down gx270
try
cleang ram
repair os
Feb 12, 2011 | Dell OptiPlex GX270 PC Desktop
My Dell Optiplex GX270 wont allow me load an OS on it. It gives me 'low battery voltage' error and unusually slow attempting to load xp but wont
This indicates that you need to replace your the computer's CMOS battery. To open your desktop follow the instructions below:
Opening the Computer Cover Dell? OptiPlex? GX270 Service Manual
caution.gif CAUTION: Before you begin any of the procedures in this section, follow the steps in "Safety Instructions."
  1. Shut down the computer through the Start menu.
  2. Ensure that your computer and attached devices are turned off. If your computer and attached devices did not automatically turn off when you shut down your computer, turn them off now.
notice.gif NOTICE: To disconnect a network cable, first unplug the cable from your computer and then unplug it from the network wall jack.
  1. Disconnect any telephone or telecommunication lines from the computer.
  2. Disconnect your computer and all attached devices from their electrical outlets, and then press the power button to ground the system board.
  3. Remove the computer stand, if it is attached.
caution.gif CAUTION: To guard against electrical shock, always unplug your computer from the electrical outlet before opening the cover. notice.gif NOTICE: Ensure that there is sufficient space to support the open cover—at least 30 cm (1 ft) of desk top space. Small Form-Factor and Small Desktop Computers
  1. Locate the two release buttons shown in the illustration. Then press the two release buttons as you lift the cover.
notice.gif NOTICE: Open the cover slowly to ensure that you do not damage any cables.
  1. Raise the back of the cover, and pivot it toward the front of the computer.
Small Form-Factor Computer
security cable slot
padlock ring
release buttons (one on each side)
security cable slot
padlock ring
Small Mini-Tower Computer
  1. Lay the computer on its side as shown in the illustration.
  2. Open the cover:
    1. Facing the back of the computer, press the release button on the right side of the computer with one hand while pulling up on the top of the cover with the other hand.
    1. Press the release button on the left side of the computer with one hand while pulling up on the top of the cover with the other hand.
    2. Hold the bottom of the computer with one hand, and then pull open the cover with the other hand.
release buttons (2)
security cable slot
padlock ring
You will need to replace the one labeled No. 3 Below.
Aug 15, 2010 | Dell OptiPlex GX270 PC Desktop
I want to download the sound driver for my desk top computer opteplix 360
http://search.dell.com/results.aspx?c=us&l=en&s=gen&cat=sup&k=optiplex+360&rpp=12&p=4&subcat=dyd&rf=all&nk=f&sort=K&ira=False&~srd=False&ipsys=False&advsrch=False&~ck=anav put in your service tag and it will give you all your driver downloads.
Jun 13, 2010 | Dell OptiPlex 360 Desktop Computer
Dell optiplex gx270 shuts down when cpu setting is on normal but runs when on compatible mode
The GX270 has a manufacturers defect with the motherboard. Open up the case and look at the capacitors, they look like a bunch of upsidedown double AA batteries sticking out of the board. The capacitors on the GX270 are bad if you see a crust on them or some kind of brown liquid, DO NOT TOUCH this it is battery acid.
Jan 08, 2010 | Dell Heatsink and Fan Optiplex GX270 K4598...
Hey, My Dell Optiplex GX270 will run for a quick second, beep, and then a light with a barrel looking icon lights for a second too. How do I fix this? Thanks so much!
I would run diagnostics. Here's how you do it if the utility partition exists on your hard drive:
Starting the Dell Diagnostics From Your Hard Drive
  1. Shut down and restart the computer.
  2. When the DELL™ logo appears, press <F12> immediately.
NOTE: If you see a message stating that no diagnostics utility partition has been found, run the Dell Diagnostics from your Drivers and Utilities CD.
If you wait too long and the Microsoft® Windows® logo appears, continue to wait until you see the Windows desktop. Then shut down your computer through the Start menu and try again.
  1. When the boot device list appears, highlight Boot to Utility Partition and press <Enter>.
  2. When the Dell Diagnostics Main Menu appears, select the test you want to run.
Aug 11, 2009 | Dell Optiplex GX270
Computers & Internet Logo
327 people viewed this question
Alun Cox
