Question about Oracle 10g Database Standard (ODBSEONUPP0)
Oracle 10g Error
I'm using oracle 10g and I keep getting this error message: "Wrong password for user".
    Problem Solver:
  • 8 Answers
When you get this error with oracle 10g you have to do this steps:
1. Control Panel >Administrative Tools > Local Security Policy > Local Policies > User Rights
Assignment > Log on as a batch Job
2. Right click > Properties
3. Add user or groups > give your OS username
Posted on Sep 16, 2008
  • 72 Answers
You're using the wrong password.
Posted on Sep 10, 2008
Orcale problem ?
This is an Error generated by the Oracle Client when the Oracle Server can not be reached.
This error can be caused by several items:
The Listener on the Oracle Server is not running. Check with an Oracle Administrator
The Oracle Server is off line. Check with an Oracle Administrator
The network connection to the Oracle server is not fully up and running. Check all connection points between the Notes server and the Oracle Server
A firewall exists between the Notes Server and the Oracle Server, and is not configured to allow access to both the Oracle Server's IP address and Port
The ADDRESS Parameter in the TNSNAMES.ORA file is incorrect. Use TNSPING (or TNSPING80 on Oracle 8.0.x) to check the connection to the Oracle Server. Example of a successful connection:
D:\ORANT\BIN>tnsping80 oracle
TNS Ping Utility for 32-bit Windows: Version 8.0.5.0.0 - Production on 23-APR-99
10:24:39
Attempting to contact (ADDRESS=(PROTOCOL=TCP)(HOST=DBSERVER)(PORT=1521))
OK (50 msec)
If this is Not successful, check your Oracle Network Products Messages Manual to resolve the errors that TNSPING points out.
well i found this from one site .... hope u can read it and can solve your problem
Oct 14, 2009 | Computers & Internet
How to install oracle 9i in vista ?it is not supported.
Your best bet is to look on metalink and search for the error code you are getting. Oracle is very particular about what versions work with specific OS's
Oct 03, 2009 | Microsoft Windows Vista Ultimate Edition
Uninstalling oracle 10g from vista
To uninstall oracle from your PC,
first you should run the oracle setup from the installation disk.
The installation setup will automatically detect the oracle products installed in your PC.
After checking the list of installed products, mark the programs you want to uninstall & then click on uninstall.
Apr 11, 2009 | Oracle Database 10g
I didn't know how to uninstall oracle 10g enterprise edition.
Dear sir
Please do the following.
start>run> ( please type services.msc)
in services window you can find some oracle services.
please stop all the services by right clicking.
after that you can uninstall the oracle software.
again you can reinstall the oracle.
please vote.
regards
murali
Feb 15, 2009 | Oracle Database 10g
Oracle Error
if it occurs after imported, it's because ctx'preferences was not imported. Try to get preferences from source (by reverse engeneriing or see with ctx_report.create_index_script package).
You will get severals scripts to execute on target db
Sep 08, 2008 | Oracle 10g Database Standard (ODBSEONUPP0)
Oracle SQL Error
Does it connect after the error ?. First try to connect from your client to Oracle server using SQL plus client.
Second - Do a tnsping <server name>
This will give you the correct Host name, SID and Port number.
Make sure that your JDBC connection parameters match with the actual connection from TNS output
Sep 04, 2008 | Oracle 10g Database Standard (ODBSEONUPP0)
Fault code 010-333 xerox 7132
Most likely you will have to have the fuser replaced. That is an overheat problem. You may just have a piece of paper wrapped in the fuser shutting it down. You can open the left hand drawyer adn remove the fuser , check inside it and put it back in and see if that clears.
But, more than likely you will have to put in a new fuser.
Aug 13, 2008 | Xerox Office Equipment & Supplies
Uninstall oracle 10g database
hve uninstalled oracle 10g from xp!! but still one program is left over say oracleserviceXE, that i could not find!! how to remove this, to install the s/w again!! plz kindly help me regarding this
Jun 01, 2008 | Computers & Internet
Can we install Server component in Vista Home Basics
I see no reason why you cannot do so. Just make sure you find all the drivers for you laptop before you migrate.
Apr 18, 2008 | Microsoft Windows Vista Ultimate Edition
QUEST SQL Navigator 3.2 with Oracle 10g Fails
I followed the advice given above and copied the ORACLE_HOME/bin/ociw32.dll to ora73.dll in the same directory. copy ociw32.dll ora73.dll
And the software worked immediately.
Dec 21, 2006 | Quest Software SQL Navigator Professional...
Oracle 10g Database Standard (ODBSEONUPP0) Logo
196 people viewed this question
Top Oracle Computers & Internet Experts
CNewton2
CNewton2
Level 1 Expert
cwradio73
Bonded Repair
Are you an Oracle Computer and Internet Expert? Answer questions, earn points and help others
