Question about Ricoh Aficio 1035 Copier
Document feeder 2 springs came off
When I lifted the cover to clean the roller in the feeder two springs flew off the roller. where do they go?
  • 2 more comments
  • lori602 Sep 10, 2008
    I have fixed the problem thanks for responding
    the problem has been fixed. Thank you for your response
  • Tim Babcock
    Tim Babcock May 11, 2010
    Correction paper feed rollers can be cleaned by hand but not the rollers on the right side of the machine.
    How big are the springs?
  • Tim Babcock
    Which roller did they come off of?
    Those rollers should never be cleaned by hand.
  • Ricoh Master
  • 2,794 Answers
Those springs in the feed tray come out from time to time.  Glad you got it fixed.
Posted on Sep 10, 2008
How do you clean rollers on manual feeder
To clean the rollers or separator pad
1. Remove all originals from the document feeder tray.
2. Lift the automatic document feeder cover (1).
This provides easy access to the rollers (2) and separator pad (3), as shown below.
1 Automatic document feeder cover
2 Rollers
3 Separator pad
3. Lightly dampen a clean lint-free cloth with distilled water, then squeeze any excess
liquid from the cloth.
4. Use the damp cloth to wipe any residue off the rollers or separator pad.
NOTE: If the residue does not come off using distilled water, try using
isopropyl (rubbing) alcohol.
5. Close the cover of the automatic document feeder.8_29_2012_4_02_48_pm.jpg
Aug 29, 2012 | Dell 1135n AllInOne Laser Printer
HP Officejet 6480 leaves a black line down left side of sheet only when usine document feeder. Already cleaned feeder rollers and feeder glass, as well as glass bed.
I found the following information on the HP web site, under their support forum.
Clean the automatic document feeder (ADF)
If the product is not already off, press the Power button to turn off the product, and disconnect the power cord from the product.
Open the ADF cover.
Lightly dampen a clean, soft, lint-free cloth with distilled water, and then squeeze any excess liquid from the cloth.
Use the damp cloth to wipe any residue off the rollers and separator pad.
NOTE: If the residue does not come off using distilled water, try using isopropyl (rubbing) alcohol.
Close the ADF cover.
Step 2: Clean the glass strip in the ADF
Open the ADF cover, and lift the ADF mechanism.
Lightly dampen a clean, soft, lint-free cloth with a mild glass cleaner.
Gently clean the glass strip inside the ADF, and then thoroughly dry it to prevent spotting.
Lower the ADF mechanism, and close the ADF cover
Close the scanner lid, reconnect the power cord to the product, and then press the Power button to turn on the product
Aug 23, 2010 | HP Office Equipment & Supplies
My printer jammed while trying to fax a legal document. It said to clear the feeder, which I did, by lifting the cover and pulling the document through. It continues to give the error message that there is...
Here's what I think you need to do. 1 Open the top cover. 2 You will see a roller assembly. 3 rotate the assy up so its pointing up. 4 Remove the spring. 5 the roller assy will now lift out. (note how it came out.) 6 you will now see a green piece of plastic on the left. 7 Remove the green plastic and see if any paper is there. (note how the green piece came out.) 8 Re assemble and test. Thank you, Steven 805-520-3003
Jul 26, 2010 | HP LaserJet 2820 Printer
Hp officejet pro L7590 - automatic document feeder will not pick up - how do I fix this problem?
Hi
Check the following
--Check the paper in the ADF (automatic document feeder)
--Make sure the ADF pick assembly is in good working condition
--Remove the document feeder and open the ADF cover.
--While lifting the blue-green lever, carefully rotate the pick assembly toward the open ADF cover until it stops.
--Make sure the bottom roller is held firmly in place by the two-catch, which is located to the left and the right of the roller.
--Clean the rollers and separator pad
Mar 03, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
The copy paper feed misaligns and jams, what's the fix? Jack
to fix misalign and paper jam problem, follow this steps.
Load one or two sheets of unused plain white full-size paper into the document feeder tray, and then press Start Copy Black to pull the pages through the automatic document feeder. The plain paper releases and absorbs residue from the rollers and separator pad.
NOTE: If the automatic document feeder does not pick up the plain paper, try cleaning the front roller. Wipe the roller with a soft lint-free cloth dampened with distilled water.
If the problem persists, or the automatic document feeder does not pick up the plain paper, clean the rollers and separator pad manually.
Follow the steps below to clean the rollers or separator pad.
1.Lift the cover of the automatic document feeder. This allows access to the rollers and the separator pad.
2.Lightly dampen a clean, lint-free cloth with distilled water, then squeeze any excess liquid from the cloth.
3.Use the damp cloth to wipe any residue off of the rollers or the separator pad.
4.Close the cover of the automatic document feeder.
This should solve the problem. Cheers!
Apr 25, 2009 | HP Officejet 6310 All-In-One InkJet...
My HP printer paper get stuck in top feeder whenever I try to fax
Lift the cover to the ADF (Automatic Document Feeder) and remove any paper debris from the rollers. Also, clean the rollers with a very damp cloth and a dab od dish washing detergent.
Also, check to see that the spring loaded lever is in place.
Clear the jam from the automatic document feeder (ADF)
  1. Make sure the product is turned off and the power cord is unplugged.
  2. Grasp the upper edge of the automatic document feeder (ADF) assembly and open it.
  3. Raise the roller assembly.
  4. Gently remove any jammed paper from the ADF.
  5. Lower the roller assembly.
  6. Close the ADF assembly.
  7. Plug the power cord back into the product.
  8. Press the Power button (c01346625.gif ) to turn the product on.
  9. Try the print job again.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Feb 01, 2009 | HP OfficeJet 6110 All-In-One InkJet...
HP 7410 streaks when using auto document feeder to make copies
the document feeder of that unit have its own scanner glass. try opening the document feeder and clean the scanner glass with a lint free cloth that is moist with water and also clean the rollers of the document feeder
Aug 13, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Jam in the document feeder
I think I found my answer. You don't have to un do any screws. Lift up the cover to the automatic feeder. You will see a spring on the side of the mechanism towards the front; remove the spring; that will allow you to lift up the little arm the spring was attached to and remove the roller or bar and the light blue/green plate just under it. Then you will be able to see the jammed paper, which which I was able to carefully pull out with a pair of tweezers. Some was under rubber rollers, but when I pulled the paper sideways it slipped out. Now it works!
Jan 23, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Document feeder doesn't feed well
Try Cleaning the rollers or separator pad
  1. Lift the cover of the automatic document feeder. This allows access to the rollers and the separator pad.
  2. Lightly dampen a clean, lint-free cloth with distilled water, then squeeze any excess liquid from the cloth.
  3. Use the damp cloth to wipe any residue off of the rollers or the separator pad.
  4. Close the cover of the automatic document feeder.
If this solve your issue pls let me know, if not ill try to look for another solution for you.
Jan 04, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Document feeder will not Operate
Try cleaning the rubber rollers onder the cover where the documents feed in, using a rag and some rubbing alcohol.
Jun 18, 2007 | Ricoh IS 330DC Flatbed Scanner
Ricoh Aficio 1035 Copier Logo
46 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Bernard D'Souza
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
