Question about AnexTek SP-230 Pocket PC
Soft reset just brought an second hand anex tec pocket pc and when turned on says due to device abnormal shut down the system will soft reset , press action to complete the process, what is action as have tried all the buttons???
  • 13,433 Answers
Its the wheel on the side.
Posted on Sep 11, 2008
My reader won't turn back on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Aug 07, 2012 | Sony Reader Pocket PRS-300
Power on problems
  1. some times it may in loose contact or cool reboot problem, switch off, check and clean all contacts, refix it
  2. in my view after a long time its cooled that make this contact problem, when it warm up this effect is eleminated
  3. it may happened some old systems
Jan 20, 2008 | HP iPAQ HX4700 Pocket PC
I have a touchpad pda that has a bad battery and i lost my password since its a long time since i used it it is a dell axim x50,how do i get the battery and charger since both burst due to an electric...
A "soft" reset clears all open programs and "reboots" the Pocket PC. When the Pocket PC powers back up, you'll start with all active programs closed and the device ready to use. This procedure is intended to reset the Pocket PC if it is malfunctioning or has become bogged down. This reset is also sometimes necessary after software is installed. A soft reset is the Pocket PC equivalent to restarting your Desktop or Laptop. The Dell Axim X50 and X50v can be soft reset by pressing the recessed button on the rear of the unit above the battery. A "hard" reset wipes the RAM and returns the Pocket PC to its factory specs. In effect, the Pocket PC will be just as it was when you purchased it. All data entered, preferences set or software installed (other than ROM updates) on the Pocket PC after purchase will be lost after a hard reset and will have to be transferred or reinstalled via ActiveSync. The Dell Axim X50 Series Pocket PCs can be hard reset by performing the following procedure: With the X50 turned on, press and hold the power button at the top of the unit. While holding the down power button, use the stylus tip to press the "Reset" button mentioned above. Allow the screen to fade to off. Release both buttons. The unit will power back on and display a menu to confirm the hard reset request. The Axim will be hard reset, just as it was when it left the factory hope this helps
May 06, 2011 | Computers & Internet
Not open windows of my pocket pc
You need to reset your i-mate Jam, for doing so please follow these instruction
i-Mate JAM soft reset
Resetting Your Pocket PC Phone
You can perform a soft reset or a full reset. During a soft reset, the device is restarted and only some data in opened programs may be lost. However, a full reset turns the battery off, returns the device to its original factory settings, and deletes all programs, files, contacts and other information you have saved to the device. Therefore, it is extremely important to back up data to a storage card or your computer on a regular basis in the event that a full reset has to be performed.
To perform a soft reset
If your Pocket PC Phone responds slowly, stops responding, or freezes, you can soft reset it. A soft reset causes the Pocket PC Phone to restart and re-adjust memory allocation. Unsaved data in any opened applications may be lost. Use the stylus to press and hold the Reset button, as shown on the next page.
i-Mate JAM hard reset
To perform a full reset
A full device reset clears memory, deletes all data and restores the Pocket PC Phone to its default settings. Programs installed at the factory remain, erasing all data that you have created and programs you have installed. Press and hold the power button, and then use the stylus to press the soft reset button at the same time. Be sure you have backed up all your data in a SD card or on your PC before performing a full reset.
If you require more assistance, feel free to reply to this post Regards-BA
Jan 05, 2011 | i-mate JAM Pocket PC
How to remove align screen
Hi..
Problem can com from your touchscreen panel.
you need to replace it manually. only then this will be solved.
or you can try with soft reset or hard reset.
please find explanation at below :
i-Mate JAQ3 soft reset
Occasionally you may need to reset your Pocket PC Phone. A normal
(or soft) reset of your device clears all active program memory and
shuts down all active programs. This can be useful when the device is
running slower than normal, or a program is not performing properly.
A soft reset is also necessary after the installation of some programs.
If a soft reset is performed when programs are running, unsaved work
will be lost.
You can also perform a hard reset (also known as a full reset). A hard
reset should be performed only if a normal reset does not solve a
system problem. After a hard reset, the device is restored to its default
settings - the way it was when you first purchased it. Any programs
you installed, data you entered, and settings you customized on the
device will be lost. Only Windows Mobile software and other preinstalled
programs will remain.
Remove the battery cover and using the stylus, press on the small
button to the left of the battery. Otherwise simply remove the battery,
wait a few seconds and then insert the battery again.
To perform a Hard Reset
Hard reset by pressing device buttons:
1. Turn off your device.
2. Hold down the Send button, End button and Camera button.
3. Do not release Send, End and Camera, press the Power button.
4. After on-screen indication, release all the buttons.
i-Mate JAQ3 hard resetHard reset using Master Clear
1. Tap Start > Settings > System tab > Master Clear
2. On the System tab, select the Master Clear (!) icon
3. Proceed to enter the confirmation code: 1234 and push reset button,
system will auto reboot to complete the operation.
hope this kind information will be help you to solved
regard,
adhiwahyudy
Dec 24, 2010 | i-mate JAQ3 Smartphone
How to do factory reset of i-mate JAQ
will be lost.
settings — the way it was when you first purchased it. Any programs
i-Mate JAQ3 hard reset Hard reset using Master Clear
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 02, 2009 | i-mate JAQ3 Smartphone
I downloaded a bunch of ringtones and a few wallpapers to my phone. Today the screen went out on me. I can't see the screen to delete the stuff out or to reset it. What do i do
Occasionally you may need to reset your Pocket PC Phone. A normal (or soft) reset of your device clears all active program memory and shuts down all active programs. This can be useful when the device is running slower than normal, or a program is not performing properly. A soft reset is also necessary after the installation of some programs. If a soft reset is performed when programs are running, unsaved work will be lost.
To perform a soft reset:
o Use the stylus to lightly press and hold the RESET button on the bottom of your device. The device restarts, and then displays the Today screen.
Warning! Always turn off your device before performing a soft reset or installing/replacing the battery.
You can also perform a hard reset (also known as a full reset). A hard reset should be performed only if a normal reset does not solve a system problem. After a hard reset, the device is restored to its default settings-the way it was when you first purchased it and turned it on. Any programs you installed, data you entered, and settings you customized on the device will be lost. Only Windows Mobile software and other pre-installed programs will remain
To perform a hard reset:
  1. Press and hold both soft keys on the device. Keep these keys pressed, and at the same time, use the stylus to lightly press and hold the RESET button on the bottom of your device.
  2. Release the stylus but keep the soft keys pressed when you see the following message on your device screen. "Do you want to erase all user data and restore to manufacture default?" will appear.
  3. Slide open the hardware keyboard, and press R to restore to factory default or press X to exit the hard reset process.
Hope this helps, let me know if I can help you with anything else.
JimmyC
Mar 03, 2009 | UTStarcom Blitz Cell Phone
I forgot my passwod to my windows mobile ipaq 5.0
here is your answer
but if you want to solve your problem quick
microsoft takes 11$ to fix it
see this if this help you
Resetting the Device
Sometimes there is a need to reset your Pocket PC. Resetting the
device is known as performing a "soft" or "hard" reset.
Performing a Soft Reset
A soft reset stops all running applications, but does not erase any
programs or saved data. Be sure to save any unsaved data within
a running application before performing a soft reset.
Perform a soft reset to:
■ Stop all running applications
■ Install a new application
■ Restart the Pocket PC if it stops responding
1. Locate the recessed Reset button on the bottom of your iPAQ
Pocket PC.
2. Use the stylus to lightly press the Reset button.
The Pocket PC restarts and displays the Today screen.
Performing a Hard Reset
Perform a hard reset only when you want to clear all
user-installed settings, applications, and data from RAM
(Random Access Memory), where data and applications you have
loaded are stored.
CAUTION: If you perform a hard reset, your Pocket PC loses all data
and programs not saved in iPAQ File Store.
1. Press and hold down the Calendar and iTask buttons.
2. While holding down these buttons, use the stylus to
lightly press the Reset button on the bottom of the iPAQ
Pocket PC for about two seconds.
3. When the Pocket PC screen begins to fade, release the
Calendar and iTask buttons first, and then remove the stylus
from the Reset button.
Note: If you simultaneously push and hold the Reset, Calendar,
and iTask buttons for more than two seconds, the battery
disconnects. To restart the device, either plug the device into the
AC Adapter or press the Reset button again.
After performing a hard reset, you may need to reinstall
applications stored in iPAQ File Store to restore shortcuts and full
functionality.
4. The Pocket PC resets and powers on.
To return your iPAQ Pocket PC to factory settings after
performing a hard reset:
1. Tap Start > Programs > File Explorer > My Device.
2. Tap the iPAQ File Store folder to open it.
3. Tap Edit > Select All.
4. Tap and hold the selected files, then tap Delete.
5. Tap Yes to delete all file in iPAQ File Store.
Oct 16, 2008 | Computers & Internet
Casaio be-300 pda
A Factory Restore will fix the password but you need to do a hard reset to get to the restore screen. Press and hold the power button. At the same time, press the reset button on the left side of the device with the stylus (pen). You will see a blue sroll saying Initializing. Press and hold the OK button. Once the scroll is finished, you will get the Safe Mode Screen. From there, press the OK button and follow the instruction until you get to the Restore Screen. From there, you can do a factory restore if you have the original CD or have the factory restore BIN file. Everything is available at www.be300.org
By the way, there are also newer operating environments available for the BE300. They will turn it into an almost fully functional Pocket PC will fully functional Today Screen.
May 24, 2008 | Casio Cassiopeia BE-300 Pocket PC
Power-on delay
some software program is causeing it to slow down.
try uninstalling some of your programs, or preform a hard reset witch returns the pda into the original state.
How Do I Perform a Hard Reset?
Perform a soft reset when:
  1. Press and hold the Calendar and iTask buttons.
  2. While holding these buttons, use the stylus to lightly press the Reset button on the bottom of the iPAQ Pocket PC for about two seconds.
  3. When the Pocket PC screen begins to fade, release the Calendar and iTask buttons first, and then remove the stylus from the Reset button.
    CAUTION: If you push and hold the Reset button for more than two seconds, the battery disconnects. To restart the unit, either plug the unit into the AC Adapter or press the Reset button again.
Mar 23, 2008 | HP iPAQ HX2400 Pocket PC
AnexTek SP-230 Pocket PC Logo
81 people viewed this question
Top AnexTek Computers & Internet Experts
David Payne
David Payne
Are you an AnexTek Computer and Internet Expert? Answer questions, earn points and help others
