Question about Samsung L200 Digital Camera
Status lamp blinks and the camera freezes.it cant come off
I am having problems with my samsung L200 [red] camera the status light comes on when i am revuing my pictures .it blinks and then the camera freezes .it does not shut off when i press the power bitton i live in trinidad [wi] i visited miami 2days ago and now i am back home i have this problem what do i do?
  • 2 more comments
  • conan_kalanj Dec 28, 2008
    After taking pics, when reviewing them, the camera freezes and the LED light blinks continuously. Nothing reacts on the camera at this point and I have to actually remove the battery and put it back in to resume camera use. The problem again re-occurs on the same pic that the camera froze on previously. Even if delete the pic through my pc, the camera apparently chooses another one to freeze on and the same exercise has to be performed again. I also live in Trinidad and bought it in the US.
  • pixzdust831 Jan 01, 2009
    i have the same problem. the light blinks and the camera completely freezes. removing the battery is my only solution as well but it seems rather annoying. any other way to fix it?
  • Anonymous Jan 03, 2009
    my samsung L200 [red] camera the status light comes on when I am reviewing my pictures .it blinks and then the camera freezes .it does not shut off when I press the power button what do I do?
  • dstoner Jan 03, 2009
    Camera gets locked when reviewing certain pictures. The only way to reset it seems to be remove / replace the battery or the memory card. Any ideas?
    Problem Solver:
  • 4 Answers
You'll have to click out the battery then click it in again , then you should be able to resume to what you was doing., you"ll have to do this every time this happens , if you don"t it will drain you"re battery,,,
Posted on Oct 23, 2008
Sony VPL-DX100 projector red light blinking first focus coming after 20 second focus off than red light blinking now how to solve this problem
light is in red means standby mode.
Flashes in red - The projector is in abnormal status. Symptoms are indicated by
number of flashes. Address the problem in accordance with the
following. If a symptom persists, despite having taken measures below, consult with qualified Sony personnel.
Dec 04, 2015 | Sony Office Equipment & Supplies
Replaced bulb yesterday worked fine. Today light will not turn on. projector turns on both lights green for 10 seconds, then power goes red and status blinks green for about 5 seconds, then status light...
green green is power on, normal
then it tries to light the lamp, but it can't so the protection circuit comes activated.
you get red and green blinking
Then it goes to standby, red and off.
so something has happened to the lamp, or lamp ballast power supply.
Take the lamp out and check if all is OK with the 2 terminals in the connector, and the leads to the lamp are intact.
Failing that, I would suspect the ballast lamp power unit
Mar 25, 2011 | Mitsubishi HC1600 Projector
I am trying to learn about the different coloured lights on the USB cable of the samsung L200 digital camera, to start with looking at this website i learnt the orange light meant that the camera is...
you should change either your battery or your usb cable when an orange light blinking on the usb cable indicator. .maybe one of those accessories was already defect..
Mar 12, 2011 | Samsung L200 Digital Camera
Status indicator flashes 3 short times, then one long red flash
Once the status light blinks 3 times, this is an indication that there's a problem with the lamp. The lamp may need a replacement.
If you replace the lamp, but get the same problem, check the inverter board.
If you're not sure where the inverter board is, then you may need to contact a pro for your safety.
Good luck and have a good evening!
Feb 14, 2010 | Mitsubishi WD-52327 52" Rear Projection...
I have replaced bulbs in 3 different types of NEC projectors: a silver, older model thta uses a VT60LP bulb, model VT595 and VT470. The lamp will still not work - the power and status light just continue...
I had the same issue, what I figured out was that I never removed the lamp door correctly, causing a small plastic piece to break off. To see if this is also your problem, inspect the back of the lamp door, top right corner, if it seems a rectangular plastic piece is missing, thats the problem. It presses in a small button nearby the lamp to let the projector know it's safe to power on.
Sep 01, 2009 | NEC VT695 LCD Projector
USB Cord
try changing the USB cord to avoid purchasing one, bring your camera to your retailer and ask them if you can try to charge it there, if it does you have to purchase a new USB cable through myaccessorymall.com if the camera is still in warranty, you can try to call samsung and ask them for a new USB cable
Mar 19, 2009 | Samsung L200 Digital Camera
Samsung L200 10.2
I called 1-800-samsung, and they sent me a new battery. After the problem insisted, they asked me to ship the camera back to them (still under warranty). The concluded that the cable was defective, and they shipped me a new one within 1 week. That was fast!!!
Aug 20, 2008 | Samsung L200 Digital Camera
Samsung L200 Digital Camera Logo
107 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
