Question about Whirlpool LSR5102LQ Top Load Washer
Spinning Cycle My spinning cycle is not working in the washing machine, what could it be?
    Champion:
  • 277 Answers
Hi no' 32/33 is what you need follow the instrctions and you'll do great http://www.applianceaid.com/direct.html#runs good luck
Posted on Apr 03, 2006
3 Suggested Answers
  • 67 Answers
SOURCE: duet Washing Machine spin cycle is spinning slow
make sure u are not under loading the washer with just one or two items and that the load is fairly balanced or else the machine will not go into high speed spin as to not go completely off balance and walk across your floor if that doesnt fix it you might need a new ccu or motor control board probably the second one and make sure u are using HE detergent and not too much because suds will lock the pump up which will not spin with water in the unit
Posted on Mar 20, 2007
  • 1073 Answers
SOURCE: washing machine not draining and spinning
check the lid switch
Posted on May 01, 2008
Spin cycle is not working. clothes are soaking wet when cycle is finished.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Dec 21, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
I have a samsung smart wash B1445V . the drum is not spinning /turning in the wash cycle as well as in the spin cycle..
i have a samsung smart wash B1445V . the drum is not spinning /turning in the wash cycle as well as in the spin cycle..
Sep 21, 2010 | Washing Machines
WASHER SPIN CYCLE WON'T WORK. IN ANY CHOSEN SPIN CYCLE MODE. FILLS , WASHES BUT WON'T SPIN OR DRAIN WATER.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
If you are having problems with your front load washing machine then checkoutthis tip...
heatman101
Sep 18, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Ultima wt940 Not spinning
Hi.
Possible slack belt which will slip with full load of water and washing, check tension, or maybe motor fault. the motor can sometimes work o/k on spin, but not on wash
Nov 23, 2008 | Washing Machines
Wwsr3090t8ww
It's possible that the high speed windings on the motor no longer work, or it could be the clutch.
If the motor is spinning very fast, but the tub is not spinning, then the clutch is broken. If the motor is not spinning fast, then it probably needs a new motor.
Sep 06, 2008 | GE Washing Machines
Drum spinning during wash cycle
if when in the wash cycle the tub spins then the brake in the cluch assembly is worn and to be replaced. this holds the tub from moving when in the wash cycle. thanks tallpaul
Apr 14, 2008 | GE WBSR3140DW Top Load Washer
Whirlpool LSR5102LQ Top Load Washer Logo
54 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
