Question about Philips 27PT6441 27" TV
Philips 27PT6441 27" TV Problem
I have a phillips flatscreen television. i turned on the tv and there were white horizontal lines at the top of the screen. the lines look like this,
__________________
__________________
__________________
________________
______________ except the lines are much closer together and white. also when i turn the television on before the picture appears a red, blue, and green line appears on the screen about a quarter of the way down from the top.
then the white lines appear that i mentioned above when the picture comes on. can you please help! model# 27PT6441/37
I've read on this and other boards that replacing a capacitor is the fix. Can you help identify which capacitor and any safety precautions needed to safely replace it/them.? Thanks
  • jon5902 Sep 19, 2008
    Thanks for the info. Do you know if the capacitor needs to be discharged in any way before replacing in order to avoid electrical shock? And if so how? Thanks again.
  • Davidfbabayy Dec 03, 2008
    I had the same problems with the white lines so i replaced the capacitor at place 2465 and now only half of the screen is showing, i dont know if the guy who replaced the cap messed something up or if it is another problem, anyone know how to fix this? The guy said that the cap at 2465 was indeed a bad cap
    Problem Solver:
  • 6 Answers
Jon5902,
Pls note that my experience is with the phillips 27" model27PT6341/07. It may not be the same board as yr model, as I can't remember nor find the service manual anymore. (browse around online for it though)
However, after taking the back off. Look close to the rca jack and svideo connection. Mine is located about an inch from the svideo connection.
Here are some pics that may help you.
http://farm4.static.flickr.com/3215/2337629026_eaa30cfa18.jpg?v=0
http://farm3.static.flickr.com/2411/2337627420_b45bbf1a74.jpg?v=0
The new one is the black and gold one marked 10uf 100v in the pic.
Other users have advised to go as high as 10uf 250v, to avoid having the cap overload again.
PS. I had the lines for about 2 weeks. They got steadily worse then one day my tv looked like it was broadcasting an hourglass. The lines converged in the center and flared outward (no pic).
Posted on Sep 12, 2008
  • Ed Rafferty
    Ed Rafferty Sep 19, 2008
    Not sure what you can expect. I have been told to unplug and allow about 4hrs for it to discharge.
Hello-I have a 19" Philips flatscreen LCD television set model#19PFL3504D/F7. After attempting to upgrade current software via a USB flashdrive I reversed the disconnect instructions. I removed the...
connect a laptop to the set, using the usb port contact phillips on line download the old flash to the computer save the old flash download as a file and, to the usb flashdrive connected to your laptop reload the set either with the laptop or, the flashdrive unplug the set first then: remove the flash drive
Jul 17, 2010 | Philips 19PFL3504DF7 19 in. TV
Phillips model # 27PT644 1/37 this tv has
I'll sell you the solution for $75, you bunch of crooked A*#es
Jul 31, 2009 | Philips 32PT6441/37 32" TV
White horizontal lines in my 27 in Phillips Magnnavox tv
I have seen this on mine. Check the cable going into your TV and make sure it is good. The ground portion of the cable could not be making a good connection.
Jan 17, 2009 | Philips Magnavox 27MS343S 27" TV
Horizontal lines on top of phillips tv
bad feedback electrolytic in vertical circuit. need tech.
Nov 23, 2008 | Philips TP2797B 27" TV
Blue Screen with thin horizontal white lines
THI IS THE INTERNAL CIRCUTRY FAULT BEST YOU
call the service person and dont try to open it other than in side of TV SET HAVING Hazard of electrical shock be handle most care fully .
and check video board and all.
Oct 19, 2008 | Philips Magnavox 20MS233S 20" TV
Horizontal ines---original post got wiped. Sorry.
leaky cap(s) in vertical circuit. shouldn't be more than $125 (plus taxes) parts and labour
May 14, 2008 | JVC AV-27230 27" TV
White horzontal lines on the top of screen
Typical symptom of a faulty screen voltage capacitor. You'd need a schematic to locate the cap and then change it out.
Geno
Mar 10, 2008 | Philips 32PT6441/37 32" TV
Phillips/Magnavox 9P5544C102 white raster and shuts down
This denotes a problem called blooming the horizontal lines you see are called retrace lines this is caused by the increase in anode voltage which could be caused by an increase in HV section current which trips the overcurrent protection dircuit and turns the TV off.If you do not have electronics experience I would suggest taking the set to a TV repair shop.
May 29, 2007 | Philips 9P5544C 55" Rear Projection...
Philips 27PT6441 27" TV Logo
303 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
