Question about Star Logic 17" LCD Monitor
Star logic monitor settings
I have had a star logic monitor for some time and I remember having trouble with the settings when I got the monitor (took it back several times because I thought something was wrong). It had something to do with the setting (hertz maybe). I have recently had an issue installing service pack 3 and now my monitor will flash but won't stay on. I have my old monitor hooked up and it's fine but not the star logic. Any thoughts. Of course I can't find the info that I previously found!
  • 558 Answers
I typically do capacitor replacement on lcds all the time insde, the board for power will most likely have 1 - 4 blown capacitors, replace these and the monitor should be good as new, btw 1 is a 10 v smallish size you can replace it with a 16 volt same MF.
Posted on Dec 03, 2008
I have a star logic monitor and it is not working. When i insert the power cord a dim blue light blinks, but then when i insert the computer to monitor cable, the dim blue blinking light goes away and it...
  1. Please try by reseating the RAM modules.
  2. Please check the VGA output port is properly fixed.
  3. Reset the BIOS to its default.
  4. Check whether the monitor colour resolution is out of range
If yes, set it to default.
Please check whether is works with different computer
IF yes, Check the VGA port.
Feb 07, 2011 | Star Logic Monitor
I have a 17inch star logic flat screen monitor and every time i turn it on the monitor will come on but then it will go black i have tried to shut it off and the same thing happens
Try to connect it externally to a laptop...
and also check the vga cable that is try to connect it first with vga port and then try with dmi port if you have...
Sep 19, 2010 | Star Logic 17" LCD Monitor
I have a Star Logic LCD monitor. Recently I have been having a problem powering the monitor on. Sometimes when I press the power button or bring it out of hibernation, the screen remains black and the...
First place to check will be the DC filter caps in the power supply section. See example of failed monitors due to bad caps here:
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Sep 10, 2010 | Star Logic 17" LCD Monitor
It says no input signal
Try a different monitor, to see if the video-card on the computer is the problem.
Jul 22, 2010 | Star Logic 17" LCD Monitor
19" star logic MJ9BBK suddenly changed color
First check the connections to make sure they are tight,next go to desktop settings and make sure the external monitor has the same color configuration.
Sep 03, 2009 | Star Logic 17" LCD Monitor
I have a Star Logic 20" monitor and cannot get the resolution set higher than 800 x 600. HELP?
You are limited to the capabilities of your video card in your computer. The monitor itself is not part of the ability to raise the resolution. Go to Display Properties under Control Panel and slide the resolution all the way to the right. If the max is 800X600 then that is the max for your video card. Buy new video card.
Rate the solution with 4 diamonds.
Mar 02, 2009 | Star Logic 17" LCD Monitor
Star logic 19inch computer monitor power adapter STD-1205
You can use a power supply for a CCTV system. Here is a website that has one, it is for a DVR4220, code STD-1205
Jul 27, 2008 | Star Logic 17" LCD Monitor
Info on Star Logic manufacturer
HI ,
IM HAVING APROBLEM WITH MY STARLOGIC MONITOR ALSO.....
I HAVE LOCATED THE BOOKLET THAT CAME WITH MY MONITOR AND HERE IS THE FOLLOWING ADDRESS....
SERVICE FACILITY NUMBER..508-435-4830 OR
800-639-3803
FOUR STAR GROUP
26840 FARGO AVE.
SUITE C
BEDFORD HEIGHTS, OHIO 44146
EMAIL SUPPORT: techsupport@fourstari.com
hope this helps you
sandie
Jun 03, 2008 | Star Logic 17" LCD Monitor
Star Logic 17 in LCD Monitor
May be your video in the computer that trouble you.
Try changing the video card and see the result.If it is still the same that mean your video card in the LCD is the problem.
Apr 19, 2008 | Star Logic 17" LCD Monitor
Star Logic 17" LCD Monitor Logo
78 people viewed this question
Top Star Logic Computers & Internet Experts
Jerry Greenberg
Jerry Greenberg
Jerry Umali
ray gallant
Are you a Star Logic Computer and Internet Expert? Answer questions, earn points and help others
