Question about Fujitsu Siemens AMILO Pro V2010 Notebook
Power supply when jack is plugged in if its not positioned exactly right it flickers going from power to battery and jack feels very hot
  • Fujitsu Siemens Master
  • 4,338 Answers
This sounds like a loose power connector on the system board. Users tend to wiggle the AC adapter out of the laptops, rather then pulling it straight out. It can be fixed, but the unit has to be dissasembled.
Posted on Sep 27, 2008
Hp pavilion g6 series
Have you tried another cord/charger with the EXACT same power specs? Has the AC jack, in the laptop, been damaged due to pulling on the cord/charger? Have you tried with and without the battery? Does it power with the battery? Has there been ANY damage? If you remove the battery what does it do? Describe what happens, without battery, when you push the on/off button? Anything? Led blink? Fan spins?
Jul 08, 2013 | Computers & Internet
Fast flickering Greenish orange light w/ clicking noise, no power up, unresponsive
Check whether the lamp door is securely closed?
Does the fan operate?
There is also chance of bad power supply .
Oct 25, 2008 | InFocus ScreenPlay 7200 Multimedia...
I have a Dell Inspiron 1525, I purchased a new battery and a new charger and I still getting the message that it's plugged in but not charging. What could be the problem?
Your problem is that the power jack in your actual laptop is loose. it may not seem like it is but one of the 3 connections (positive, negitive, data) that hold the jack to the board broke. In this case its the data connection that tells the laptop what kind of adapter is plugged in, and dell laptops wont charge without knowing that. Solution- 1.Pay someone to replace the power jack 2. If you can solder, by a new jack (around $5) and disassemble the laptop and replace it yourself.
Jan 13, 2011 | Dell POWER SUPPLY Power Supply
I have a asus m6000 laptop the power supply green led flickers when plug in and the power light. I tried different power supply and the same problem. Cheers Greg
Hello.
The most common reasons are the power adapter/cord and power jack.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement.
If no change, the power adapter is probably faulty and needs replacement.
Also, power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
Hope this helps.
Dec 23, 2010 | ASUS m6n Notebook
It's an Acer Aspire One 110 running Windows XP. When battery is inserted or power supply plugged in, the green light on the power button comes on and as long as there is power going to the machine the...
Hi
Thank you for your query
It would seem you have a possible DCf jack problem, causing the mentioned issues
If the DC jack is faulty it can cause the problems mentioned above.
I would recommend that you book the laptop into a reputable PC shop for them to replace it
I hope this has been useful
Mar 16, 2010 | Computers & Internet
I just replaced my ac adapter for my gateway lap top mx 6931 thinking that was the problem for why my screen flickers when i plug my ac adpater in to charge my battery. The battery wont charge unless i...
Chances are the power jack in the laptop that is to blame. It's common for the solder connections holding the jack to the motherboard to break because of the power plug flexing. One way to check is to keep the laptop steady and wiggle the power plug. If the power indicator flickers, that's what's wrong.
The good news is that this is usually repairable. The bad news is that not all service shops are willing to get into this level of repair. The motherboard needs to be removed from the computer so the connections can be repaired. Sometimes the board needs some mechanical repair as well, and occasionally the only way to fix the trouble is to replace the board. Most shops want to replace the motherboard right off.
Call around to shops in your area and see who's willing to try soldering the board. That is usually all that's needed to get you going again.
Feb 02, 2010 | Gateway MX6931 Notebook
Help!!!- Gateway w340ua. Brightness flickers and comp shuts off
sounds like a power probelm
check the pin in the dc jack where you plug the adapter in, if this pin is loose just a little
it could be that yoru going from battery power to ac power , for that reason your screen would flash and you would shut off now and then
Jul 22, 2009 | Computers & Internet
Power cord cuts in and out
There are two places the trouble can be happening, at the adapter plug or at the power jack in the laptop. To determine which one is causing the power loss, hold the plug in the computer steady with your fingers while you wiggle the adapter cable. (If you have access to a voltmeter you can measure the voltage at the plug while you wiggle the cable to see if remains steady.)
If the charge light flickers it's the adapter cord that's bad. Because the wire flexes so much at the plug, it can break inside the insulation and cause the power loss. You either need to replace the adapter or repair it by cutting off the bad end and installing a new plug.
If the charge light remains on with the plug held steady but flickers when you wiggle the plug itself, the trouble is on the main board in the computer. The solder connections at the power jack have broken from the plug flexing and need to be repaired. This involves opening up the computer and getting at the solder side of the main board. It's tedious but relatively simple. If you are not experienced with soldering on small electronics, leave this to a professional shop.
Apr 23, 2009 | Acer (56.04145.901) (5604145901) Power...
Battery: Fast Discharge, Slow Charge, Charging Lights Flicker, Runs off battery when plugged in
Problems sounds like a damaged power pin from pulling or jerking on the AC cable. I use a Cable Retention Device like the one in this video to keep from hurting the pin.
Dec 29, 2007 | Toshiba Satellite M35X-S149 Notebook
Fujitsu Siemens AMILO Pro V2010 Notebook Logo
187 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
