when trying to record anything only sound will record no picture looks like lens cover on but is,nt everything else works ok previus recordings will play back as normal.
Comments:
Apr 03, 2006
- how do i resolve this problem is there a easy fix ?
-   I have a JVC GR-D71 and am having the same problem.-   blm1968
Jun 02, 2008
-   I have a JVC GR-D33U. I am experiencing the same problem. I can play back previously recorded material. The machine functions properly (all the icons, date and time on the LCD), except for the fact that it seems as though the lens cap is still on when it is not. I get a black field where there should be an image. I tried the tapping... to no avail.-   ssumbrella
Apr 19, 2008
-   I have either the same problem or a similar one. My ZR 85 will play back tapes on my viewer screen, but when I attempt to record, nothing shows up on the screen or through the view lenz although the sound is there.-   Guest
Apr 15, 2008
its dark as if the lens is still on the camera
-   Guest
Mar 23, 2008
-   Have same problem please help-   Guest
NAAAA all of my years I have never had a ccd open up where you got no picture at all!! Most of the times its a small line or discoloration or a pixle or a group of pixles out. The most common problems with a camcorder that has no picture on the camera is a stuck shutter or iris. you can turn on the camcorder and tap on the lens around the middle and sometimes it will open up. now if this fails then you have failed capacitors in the camera section and most of the time it dosent pay to repair as the entire board has toi be replaced. sorry windman sorry silly girl.
Comments:
May 12, 2006
- Yes silly girl But have you seen the fault??? its not like a compltely black picture as Iv'e seen it as a matter of fact my fuji film piece of $%^%$ camera went out after 2 months and when imsent it in they said sorry its been damaged and i never damaged it so i took it back to walmart for an exchange!!It has shadows all around a darkened image and some brighter pictures were differant colors shades then what they should have been. Sounds familuar dosent it??? OH well thats life in the big city!!
If its really a CCD like the previous post suggested(very possible), then you won't be able to do this yourself, unless you're really handy with these things, and can manage getting your hand on a replacement CCD(bog knows how you fix them if at all;)
Comments:
May 10, 2006
- no sweat techman, you daman ;]
May 11, 2006
- just an example of a CCD turning all black: "Fuji Photo Film USA has announced a service advisory notice for four of its digital cameras. The FinePix S2 Pro Digital, FinePix A303, F410 and F700 may all develop a problem with the CCD sensor, which leads to captured images that appear completely black(!), have a purplish cast or multi-colored distortions. Fuji USA will repair all affected cameras (serial numbers are listed below) free of charge, even if the one-year warranty has expired."
Same kind of bug with many other companies that probably used the same CCD
i have windows XP. i bought a new Firewire which is being recognised by the laptop, however when i...
(More)
i have windows XP. i bought a new Firewire which is being recognised by the laptop, however when i plug in the mv700 i and power on using the power cord, windows Movie maker isn't recognising the camera. i'm not sure what could be the issue
v-as ruga daca puteti sa ma ajutati.camera doar inregistreaza sunetul si nu stiu *** sa...
(More)
v-as ruga daca puteti sa ma ajutati.camera doar inregistreaza sunetul si nu stiu *** sa filmez.camera este canon mv700.
In play mode, the camera does not see any footage recorded on the camera, even if I recorded it only...
(More)
In play mode, the camera does not see any footage recorded on the camera, even if I recorded it only a few seconds before. It shows a blank screen and the -:--:--:-- which signifies a completely blank tape.
Cannon NTSC ZR65 MC.
suddenly the when you switch it on it's as if the lens cap is still on only with a few shaky lines also, but as with jayjay's, previous recordings can be veiwed fine.
