Rca modelP52936 First the picture just went to black, then the sound went out. When is is plugged up it sounds like a cricket has gone in the back...it chirps. Wondered if needed a new fuse or something simple to fix or should we buy a new one.
  • 4,234 Answers
The chirping is an indication that the power supply is having difficulty starting up. This could be a problem with the power supply itself or a problem further down that is loading the supply. For a set this size, I'd invest in a detailed repair estimate. Report the results here and we can walk you through the actual repair.
Dan
Posted on Sep 10, 2008
Rca L42phd37yx8 42' led tv blackscreen with sound wont show anything
Show a torch light on the screen (not too close) when the TV and program is running. If you can see the picture, the backlights have gone off. Anyhow, the TV needs attention by a qualified service technician.
Jul 13, 2012 | RCA Televison & Video
Pop sound tv went black, went off then back on had sound but no picture, I turned it off and it turned its self back on at this time no picture and no sound. I unplugged tv and when I plugged it back in it...
An electrolytic capacitor has gone bad in you high voltage section of your TV or the high voltage oscilater has gone failed please have tech check and replace
Aug 13, 2010 | Samsung DLP HL-P5663W 56" TV
38 '' RCA TV XBOX Model 36V550T, lost the picture
Does it only happen when you use your Xbox?
Try pulling the cable in and out between the TV and Xbox
Dec 05, 2009 | RCA 36V430T 36" TV
Picture went out on my 36'' RCA television, still have sound.
do you have and big sound system if you do the move them away from youur tv. or you sould just bring it to a shop it must be the picture tube
Jan 26, 2009 | RCA 36V430T 36" TV
RCA 52 INCH D52W20B WON'T COME ON
A 1995 60 inch rca good picture and sound. Then it started a cracking noise and a hissing sound, then the picture went blurry. then it was nice picture and sound, then it died. took the back off and turned out the lights. Plugged the tv in and out from the wall socket and there was a sparking noise and a small arc when i plugged it in and out a few times ,at the part that the power plug plugs into.The white part that is beside the white power plug part has thick red wire coming out of it and goes into another plug that has more red wires in it. but the big white part beside the power plug part looks burnt and has black powder on it. that part is probably the problem but maybe not, what it the name of that part and how much would it cost and is it plugged in or soldered.
Oct 18, 2008 | RCA P52937 52" Rear Projection Television
Cricket sound from tv
it sound like a fly back or horz output problem . This is a high voltage problem. very common in rca tvs the cost to fix it depends on size 85 dollars up to 250 dollars
thanks DOCTOR VIDEO
Apr 25, 2008 | RCA F27TF700 27" TV
Picture gone
Is the set completly dead...does the green light flash then go off. or when you plug it up does it come on for a moment?
Jan 02, 2008 | RCA HD52W56 52" Rear Projection HDTV
Picture went out and all the tv does is make a buzzing sound
The horizontal output transistor drives a transformer that gives you the high voltage to light up the picture tube,either the transistor or the transformer have gone bad,sometimes both have to be replaced and sometimes the transistor fails for no reason by itself.Be safe and call for help if you are not familiar with tv service.
Sep 20, 2006 | RCA F32450 32" TV
Televison & Video Logo
74 people viewed this question
Top Televison & Video Experts
Electro Med Services...
