Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Picture shifted to the lift
I have the sony wega 36"
I know there is a function that rotates the screen but I have noticed that picture is shifted to the left... when I look at my cable's viewing guide, the letters on the left are cust off & when the TV has a vertical line; the bottom of the left side tends to arc even more to the left... how can I adjust this?
  • Anonymous Sep 18, 2008
    we have a similar problem...the cable guide is cut off the left and right. Cable repair came out and said it was the tv
Press menu on remote and tab over to settings
Scroll down to tilt correction
Posted on Sep 29, 2008
  • 4 Answers
For me it was the cable box settings...
I'm not a tech person, so take this for what its worth. I had the same problem with my Vizio and my Time Warner Cable HD/DVR box using the HDMI cord connection. HD channels were always fine, and non HD channels were fine until I went to an HD channel and back. When switching back, the non-HD channels would be shifted to the left as you describe. After much back and forth with both Vizio and Time Warner (each saying its caused by the other), I stumbled across the following fix...
I went into the cable box (scientific atlanta 8300) "settings", under "display," under "output resolution." There was a list including 480i, 480p, 720p, 1080i, and "auto select." I unchecked both 480 options and left 720 and 1080 checked. Problem solved. The other "Display" menu settings are as follows: Picture Size = Stretch, Aspect Ratio = 16x9.
Hope this helps.
Posted on Oct 03, 2008
2 Suggested Answers
darjr
  • 378 Answers
SOURCE: picture shifted to the left
Check the horizontal circuit visual check for any burned coils or Inductor. check also the ceramic capacitor in that area.
Posted on Jun 02, 2009
My ty is capable of high definition picture with set up box but it is alot smaller. can you make it larger
Only if the menu screen has the function settings for screen sizes. Other than that you get what you get or hook up TV with only the coax cable.
Dec 30, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Picture shifted to the left
Jun 02, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have a 2001 sony wega 36 inches and the channels
If you are comfortable with working inside the set where there are potentially dangerous high voltages present, you can probably fix this easily. Open up the back and remove it. Plug the set back in and turn it on. In the lower right hand side will be the flyback transformer (large red wire coming out of the top and going to the side of the picture tube). DO NOT TOUCH IT!!! On the back of the flyback should be 2 "knobs". One will be marked screen and the other focus. Carefully adjust the focus until the picture is clear. When you do this, go beyond the clear point and work the control back and forth a few times before settling in to the focused spot.
That should resolve the problem.
Dan
Apr 07, 2009 | Sony FD Trinitron WEGA KV-36FV27 36" TV
Top of screen slants on the right and left side horizontally
go in touch with SONY i assume ur set is still under warrenty.....call customer help and support
Mar 12, 2009 | Sony FD Trinitron WEGA KV-36HS420 36" TV
SONY GRAND WEGA KDF-60WF655 - VERTICAL LINES
This seems to be common problem with Sony projection tv. I have the KDF-E50A10 that lasted only 2 years. It's sitting in a corner now until I figure out what to do with it. I am not going to spend another grand to repair it!! Never Sony again.
Jun 16, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Screen flickers upon power up
Looks like your picture tube is dying, or there is a bust capacitor(s) inside...I'd recommend taking it to a service shop to get it repaired.
Cheers!
IrishDruid
Jan 08, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sone TV Picture not aligned.
This looks like Pincushion problem. nothing you can do. Only a Trained technecian can do this adjustment to reproduce a perfectly aligned image. It requires a pattern Generator and other tools. call the company tech.
May 10, 2007 | Sony KV-36FS100 36" TV
Sony FD Trinitron WEGA KV-36HS500 36" TV - Bowed Picture
it sounds like a convergence adjustment problem. If you hava book on the tv still read it, and it will tell you what to do, other wise, look for a convergence button on the front of your tv, and take the remote and push menu to bring up setup, and go convergence adjustment click it and hit the conv. button on the front of the screen. there should be to lines going vertical and horizontal, these are the limes you adjust with your remote, you have to adjust the red and blue, the tv should blink to let you know which color you are on. when you have them lined up right the line will be perfectly white. hope this helps
Jan 31, 2007 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Picture too big
The horizontal size adjustment is in the service menu only. I would suggest someone who knows the code to do it for you.
Jan 25, 2007 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
223 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
