Question about Dishwashers
Kitchenaid dishwasher - small pieces of food are left on otherwise clean dishes. Water level comes to about 1 inch below heater coil. I ran it without dishes (or soap) and added about a quart of water so that level came to about 1/4 inch below heater and that's when I noticed food pieces on drain surfaces (nylon filter under bottom spray arm unit and circular plastic "trap" surrounding it). Spray arms holes are clear and water is hot.
  • rlittles Sep 22, 2008
    Added rinse agent, re-cleaned mesh filter (below bottom arms) ands problem persists. After several washes, top rack (glasses) still have dried pieces of food on them. Bottom items are clean. Mesh filter has particles of food on it. It's as though the bottom holes on the lower arms which are supposed to flush the particles off the mesh filter and into the pump is not working.
  • 1,543 Answers
It sounds as if you figured the solution out. The holes in the spray arm(s) get plugged by small debris, (tooth picks, seeds, bits of plastic like candy wrappers, etc) and the water does not reach the dishes to wash and rinse effectively. Try placing the wash arm(s) in one position and marking one side, then running the dishwasher for a minute or so. Open door to see if arms have moved. If some holes are plugged, arm(s) may not be rotating. Also check that there are no obstructions which would interfere with wash arm rotation.
Posted on Sep 22, 2008
  • 185 Answers
Hello
contact the Help line
Call 1-800-334-6889
Major Appliances:
8 am - 8 pm EST (Mon - FriKitchenaid dishwasher - small pieces - spacer.gifr /> spacer.gifspacer.gif
Countertop Kitchenaid dishwasher - small pieces - spacer.gif:
10 am - 5 pm EST (Sat)
KitchenAid Experience® Store
1-888-886-8318
Thank You
Posted on Sep 11, 2008
    Genius:
  • 2,920 Answers
You need to clear the filter on the dishwasher so food particles can pass...also try using jet dry in the wash mode it really helps
    Genius:
  • 3,422 Answers
If your dishwasher is cleaning poorly, check these:
Water-inlet valve
Internal filters
Drain valve
Spray arms
Water temperature
Detergent cup
Water-inlet valve Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it.
When a water-inlet valve is defective, you may hear the sound that's usually referred to as "water hammer." If the water-inlet valve is defective, you need to completely replace it.
Dishwasher Water Inlet Valve Replacement
Be sure to read and understand any instructions that come with the new water inlet valve.
Tools required:
Adjustable wrench
Multi-Screwdriver
Pliers
Step 1. Disconnect the dishwasher from its power source.
Note: Dishwashers are usually wired directly to the home’s electrical system. To disconnect the power, switch off the circuit breaker or remove the fuse for the electrical circuit the dishwasher is attached to. Try to turn the unit on after disconnecting the power to be sure you were successful.
CAUTION: If you’re not sure you’ve shut off the power properly, DO NOT CONTINUE. Call a qualified appliance repair technician to complete the repair.
Step 2. Turn off the water supply to the dishwasher. This is usually underneath the kitchen sink or in the basement or crawlspace near the location of the dishwasher. Pliers may be helpful here.
Note: If there are no shut-off valves, you must shut the water off at the main water supply valve for your home.
Step 3. Remove the lower panel(s) of the dishwasher. These are usually held by 2 to 4 screws at the upper and lower corners of the panel(s).
The inlet valve is usually near the front of the dishwasher. Attached to the valve you’ll see: 2 or 4 wires, the water supply line from the house and the water feed line that goes to the dishwasher.
Step 4. Remove the household water supply line from the valve. The line is usually secured with a brass compression nut. The water supply line is usually copper or braided stainless steel.
CAUTION: Water supply line may be hot.
Step 5. Remove the fitting from the valve the water supply line was attached to. This fitting may be very difficult to remove. It may help to put the valve into a vice in order to remove the fitting. If you cannot remove it, replace it. The fitting is not an appliance part but a plumbing part that is available at most hardware stores.
Step 6. Remove the screws holding the valve to the dishwasher frame.
Step 7. Label the wires to the valve so you’ll be sure to reattach them correctly.
Step 8. Remove the wires from the valve.
Step 9. Remove the clamp on the black rubber water discharge tube and pull the tube off of the valve.
Step 10. Reinstall the old fitting (or a replacement fitting if necessary) onto the new valve the water supply line was attached to. Use Teflon tape or pipe joint compound as a thread sealant. Make this fitting tight to prevent leaks. Make sure that the fitting points in the same direction as the old one so that the water supply line will meet up with it properly.
Step 11. Install the new valve in the reverse order of the removal instructions.
Note: The water supply line is under high pressure. Be sure to tighten the fittings properly.
Step 12. Turn on the water to the machine, and check for and correct any leaks.
Step 13. Reinstall the access panel(s). Restore the power to the dishwasher and test.
Note: You may have to let the dishwasher run a few minutes before it reaches the next water fill cycle.
Internal filters Every dishwasher has some type of filter to keep large food particles and foreign objects away from the pump assembly:
  • Most modern dishwashers have self-cleaning filters that don't need any routine cleaning.
  • Some have filters in the bottom of the dishwasher that you need to periodically clean. You don't need any tools to remove the filter, and cleaning it is easy. Consult your owner's manual to determine which type you have and its maintenance requirements.
If your filter is clogged, it may be causing the cleaning problem.
Drain valve Some dishwashers have a valve (or gate) that should open only during draining. If debris lodges in the valve, it can't close properly, so water drains out during the wash cycle. Most dishwashers drain into the garbage disposer. If yours does that, listen for water flowing into the disposer during the wash cycle. If you can hear it then, the drain valve may be clogged.
Spray arms There's a spray arm at the bottom of your dishwasher--it may have a tall spray tube mounted to the center of it. There may also be a spray arm located directly beneath the upper rack of dishes and/or above the upper rack.
If debris is blocking the holes in the spray arms where the water comes out, it could cause cleaning problems. Regularly inspect each of the spray arms and clean out the holes as necessary.
Water temperature To get the best cleaning results, the water entering your dishwasher needs to be hot enough. Try running the hot water in your kitchen sink for about 30 seconds before starting the dishwasher, to pre-heat it. Also, if your dishwasher lets you select a higher wash or rinse temperature, try that to see if it helps.
To check the temperature of the hot water that comes from your kitchen faucet use a waterproof thermometer. If the water isn't 120 degrees Fahrenheit, your dishwasher may have trouble getting your dishes clean. You could increase the temperature of the hot water to the whole house--and therefore the dishwasher--by adjusting the hot water heater thermostat.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Detergent cup Dishwashers don't perform their best if detergent is introduced only at the beginning of a cycle, so add detergent to both parts of the cup.
If the detergent cup isn't opening, see the "The detergent cup doesn't open" section, below.
  • Priya darshan Sep 11, 2008
    Dual action detergent usually contains rinse aid, which is released at
    a different rate to the cleaning agent and so helps reduce smearing etc
    without the need to add separate rinse aid. Some 3-in-1 tablets contain
    an ingredient, which has a 'salt action', which also helps to improve
    cleaning, but NOTE this is not a substitute for adding salt to the
    water softener. The salt action takes place in the cleaning chamber of
    the machine, but does not actually replenish the water softener.
    Research has shown that whilst 3-in-1 detergents do clean dishes
    effectively, their performance is improved by adding salt to the water
    softener reservoir.
    As the performance of machines can
    vary, as can local water conditions, it is always best to follow your
    manufacturer’s advice. Some manufacturers advise that if you have
    unsatisfactory cleaning performance eg white powder residue, poor
    drying or dirty dishes, then you should return to using three separate
    products ie detergent, rinse aid and granular salt. Be aware that if
    you have not been filling the salt reservoir and relying on the salt in
    3-in-1 tablets, then it may take a few cycles to re-generate the
    softener.
What is the correct water level in a kitchenaid dishwasher?
There is a float inside, the float should be nearly to the shut off position when the dishwasher is full. If it isn't add water until it's about 2 inches deep, or within 1/2 inch of overlowing the front of the dishwasher. Run a cycle and see if your dishes are cleaner. If so, then the likely problem is with the water pump. Take this off, clean all screens and soak in Lime-Away or something similar and reinstall. In all probabilty if the dishwasher doesn't fill, there is dirt in the pump screen or buildup in the pump itself. If this does not fix the water level, then a new pump may be necessary (around $20-$40 on eBay).
Apr 15, 2012 | KitchenAid Dishwashers
Dishwasher spray arms don't spin & spray water
Check that the water pumped on arms has enough pressure.
Aug 15, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Kuds301vbl3 not cleaning
Two major issues I have found with mine, and have to believe these are happening with other folks. First of all , clean the drain trap all the way down to the food erator. My drain was completely clogged with food and small plastic parts that broke off of the utensil holder. Largest issue of top dishes not getting clean was the engineering on the blue plastic Pro-scrub nozzles. On the bottom left and right , closest to the cal-rod unit, the plastic had disintegrated and water was just running out of here instead of heading to the top of the unit . Poor design and cheap plastic. Once these two issues were tacled, ran like a champ again.
Jan 16, 2012 | KitchenAid KUDS301V 24 in. Built-in...
I have soap build up in the dishwasher. The dishes aren't getting completly clean. Ran load today twice and they didn't look any better.
Most likely causes are:
Not enough water entering dishwasher (check level after fill... Should be slightly below bottom wash arm)
Water filling but draining during wash cycle. Check toward end of wash cycle but before drain. See if water level is diminished from start of wash cycle.
New 'water saver' dishwashers are notorious for having smaller water jets, and thus easier to stop-up jets. Check the jets on all wash arms to be sure they are cleared of food particles.
Another way to check the wash arms is to manually position them at specific locations, momentarily run the dishwasher for a few seconds, then open the door to inspect the location of the wash arms. Do this three or four times to eliminate the possibility of coincidence.
If the wash arms do not move from the location that you put them, the most likely cause is food particles stopping up the water jets. These jets not only clean the dishes but also the water pressure they generate turn the arms inside the dishwasher to properly distribute water pressure on the dishes.
Sometimes you can dislodge and remove food particles stuck in one of the jets with a toothpick or other small probe. Others require that you remove the arm(s) and get a little more creative. I use compressed air to clear mine, but not everyone has access to compressed air, so use whatever you can to remove the food particles.
Simply dislodging them from the water ports is usually not effective... As soon as water pressure is applied, the particles return to the jets and stop them up again. The real fix in this instance is to completely remove the food particles from the arm if you can.
Hope this help. Good luck.
Sep 11, 2009 | Frigidaire 24 in. FDB635RF Built-in...
Correct water level?
Yes, the level should be above the heater but that is not likely the only problem. Make sure your filter at the bottom of the unit is clean (for adequate water flow) and that you're not overloading. Use the recommended amount of cleaner. Always scrape your dishes of loose food.
Feb 25, 2009 | GE GSD2200Z Dishwasher
Noise
Have a look to make sure something has not fallen into the pump assembly, sometimes a hard piece ( like a pit ) or small utensil can fall into the pump and make a grinding style of a noise.
Q - My dishwasher is full of soap suds....help!!
Q - Can you use dishwasher pucks in every dishwasher?
Q - My dishwasher racks are getting rusty, is there anything I could do about them without having to buy new ones?
Q - My dishwasher looks dingy inside...is it time for a new dishwasher?
Q - My dishwasher wont drain, what can I check for?
Q - My dishwasher is making a noise, is there something I can check before calling for service?
Q - The dishwasher is empty when the cycle is over, but the next morning there is water inside the dishwasher, what could be wrong ??
Q - I just installed my food waste disposal, now my dishwasher will not drain, what could be wrong??
just click on the above questions and the answer will be displayed on your screen
Which detergent type is better, liquid gel or powder?
We recommend the powdered/granular detergents--like Cascade--because sometimes the gels don't perform as well. We've also found that prominent brands are better than some of the generics.
Do I need to clean the inside of my dishwasher? It depends. If you use the dishwasher at least twice a week, you don't need to clean the inside. Otherwise, if it begins to get moldy inside--or if the residual water at the bottom of the dishwasher smells bad--put detergent in the soap dish and run the dishwasher empty, through a complete cycle.
Is there any routine maintenance for my dishwasher? Yes. See our Maintenance Tips section.
My dishes aren't getting clean. What should I do? Check our Troubleshooting Guide for help with functional problems.
Do I have to rinse my dishes before washing them? Not usually. Most dishwashers handle the normal food residue left on dishes after eating, if you first scrape the dishes to remove any larger bits of food. But if anything is burned, melted, or stuck to the dishes, rinse and scrape them well, before you put them into the dishwasher. Leaving some residue is actually best, because the protein in the food reacts with the soap for more-effective cleaning.
My dishwasher takes too long. What's wrong? It may be a model that pre-heats the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water.
To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater.
Should there be water in the bottom of my dishwasher? Yes. All dishwashers leave a small amount of water in the bottom, to keep the seals and pump wet. If the seals dry out, they can become brittle and begin to leak water.
My cups and glasses are coming out spotty and filmy. What's wrong? For spotting only, try using the heated drying cycle. If that doesn't help, try one of the rinse-aid products you can find at your supermarket.
Film can be caused by a couple of things:
  • It could be from a lack of water flow within the dishwasher--see the Troubleshooting Guide section for more information.
  • It also could be from hard water. If you can remove the film with vinegar, it's probably caused by hard water deposits.
Etching--a corrosion of the glass--can be caused by using too much detergent. A rainbow hue on the glasses is the first sign of etching. Try cutting in half the amount of detergent you use.
Do I really have to run the water in the sink before starting a cycle? Yes. Dishwashers work best with very hot water. Letting the water at the sink run for a few moments (until it's hot) before turning on the dishwasher brings hot water to the dishwasher faster.
Oct 16, 2008 | KitchenAid 24 in. KUDS01FLBL Built-in...
KitchenAid Superba KUDSO1FLSS3 Not Rinsing? No Cleaning at all!
Here are a couple of things that you can try:
If there is hard water residue or film left on the dishes:
Check water hardness.
If the water is hard, use maximum detergent or try pouring 1/4 cup of Dishwasher Magic into the bottom of the dishwasher. I would also recommend using the High Heat option to ensure proper cleaning. To clean the dishwasher, use a cup of vinegar and place it in the upper rack.
Detergent carryover:
If it's below 10 grains, use less detergent and the High Heat option.
It is also possible that you may have a problem with the drain loop check valve as it's not sealing. This may cause residue or food to be left on the dishes. For this, I would recommend you have a technician do it, as it requires replacing the entire drain loop.
Let me know if any of this solves the problem.
Oct 12, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
Whirlpool Quiet GU2300XTLS2
Could be a a couple different issues.. Not filling with enough water or food chopper broke or food chopper filter screen clogged.
Check water level:
Run the DW and wait for the main wash to start (water will fill. pause then complete fill) The water should be no more than 1/4 inch below the heating element. If not there..replace water inlet valve.
Inspect food chopper:
Remove lower spray arm and rear water supply tube to upper spray arm. Remove torx screws that secure the sump cover. Remove the rounded cover on the left side to expose the chopper assembly. Inspect for breakage of blockage. There may be an additional plastic screen to remove first.
Jun 13, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishes not clean
Water-inlet valve
Internal filters
Drain valve
Spray arms
Water temperature
Detergent cup
Tools required:
Adjustable wrench
Multi-Screwdriver
Pliers
Apr 04, 2008 | KitchenAid 24 in. KUDP01IL - Multiple...
Dish washer frigerdaire, some dishes do not come clean
ck water level, a few min into wash cycle open door . make sure your water level is just below heater coil
Feb 24, 2008 | Frigidaire 24 in. PLD2850 Built-in...
Dishwashers Logo
182 people viewed this question
Top Dishwashers Experts
