Question about Toastmaster TUV48 UltraVection 1400 Watts Toaster Oven with Convection Cooking
Ttm602 toaster,browning one side ,even on highest setting , of 5
The problem is with the heater (bars) connection, which would be under the cover on the left side. Caution ! You're dealing with electricity which may cause a fire. That said, the solderless connecters on the heat elements and the wires probably need replacing,that's all,I did it to mineand it worked. DON'T forget the caution!!!!
Posted on Mar 26, 2009
Hi i have a four slice toaster it is only 13 months old but one side does not work please can you help as i think this should last a lot longer as it was not cheap i dont think it is fit for purpose i
Hi, Try to set the toaster to a darker setting. this will make the toast stay down longer. But keep an eye on it as it can burn. As for the other side not working. Unplug it and look carefully at the heat coils.
If there is a break in the wire you will have to take it to be repaired. Good luck.
Jan 12, 2015 | DeLonghi Toaster Ovens
WHY DOES MY TOASTER OVEN NOT BROWN ON THE BOTTOM
Does the lower element come on? If not check the element, it may be burned out or one of the spade ends may have broken off. If its OK, check for 120Vac or 250Vac as the case may be, at the elements terminals.
Aug 21, 2014 | Applica Black & Decker 6-Slice Convection...
KCO223 toast function not working
I too have the same KCO223 countertop toaster oven, and the toast function is not working. All other functions work fine, but the blue light won't come on in the TOAST mode setting.
Apr 09, 2014 | KitchenAid 12" Convection Toaster Oven...
I need to replace the timer on a Delonghi EO1251 toaster oven. It is very similar to other EO series ovens. How do I remove the side panel to access the timer. I removed the three screws, two at the...
Toaster Ovens are purposely not meant to be repaired. Fire hazard.
Sorry for the bad news, Norm. Do as I do - take out your frustrations with it with a sledgehammer. Even then, you will find it hard to crack open.
Oct 24, 2017 | DeLonghi EO1238 Toaster Oven with...
How do you set the clock on the delonghi DO400 toaster oven
  1. Press for 5 seconds the TEMP./SELECT/CLOCK but- ton (7) (the hours flash on the display).
  2. Press the TIME/TOAST COLOR buttons (8) to the desired time (hours). The time set will begin blinking on the display.
  3. Press the TEMP./SELECT/CLOCK but- ton (7) (the minutes flash on the display).
  4. Press the TIME/TOAST COLOR buttons (8) to the desired time (minutes). The time set will begin blinking on the display.
  5. Press the TEMP./SELECT/CLOCK but- ton (7) to confirm. It is pos- sible to press the button at any time during cooking to display the current time (the display shows the time set).
  • If you wish to change the hour on the display once it has been set, press the TEMP./SELECT/CLOCK but- ton (7) before proceeding to set the new time as described above.
  • It is possible to display the current time even after starting a function, by pressing the TEMP./SELECT/CLOCK button (7) (the time is displayed for 2 seconds).
Oct 14, 2010 | DeLonghi DO400 Toaster Oven with...
Door spring broken
Hi Eli - here is the link to the delonghi service centers, perhaps you can call them and ask then where to hook the spring
http://www.delonghiusa.com/index.php?service
Jun 02, 2009 | DeLonghi EO1238 Toaster Oven with...
Model 460/5 can not control the heat
I would have to say that your issue is thermostat related.  The thermostat only send a signal when temperature is reached, not what the current temperature is.  So if it is malfuntioning, the desired temperature will never be reached.  Therefore, not sending a signal to cut the heat, even though it is 350.
Mar 04, 2009 | Farberware T490C 1500 Watts Toaster Oven...
Light and oven does not turn on.
:-) Same here, in the middle of cooking the toaster just died. O' well, i am a tech! i opened the unit and diagnosed the problem. the unit has a non-resettable high limit thermostat that blows open when reaching high temperature. the problem is that when it happened, the oven wasn't even hot and was only on for a bout five (5) minutes. From my experience, it is due to a design defect. from all i have seen so far, it doesn't seem that the company cares about its reputation or customers... what can you expect from the French?!
Oct 29, 2007 | DeLonghi EO1238 Toaster Oven with...
Half working
see my above comment for suggestions on how to fix it...
Jun 18, 2007 | Black & Decker CTO6300 Toaster Oven with...
Toastmaster TUV48 UltraVection 1400 Watts Toaster Oven with Convection Cooking Logo
Top Toastmaster Toaster Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dennis Boxerman
Are you a Toastmaster Toaster Oven Expert? Answer questions, earn points and help others
