When you say messed up do you mean the convergence is out? please explain a little more detail as to what you are seeing. Also when its messed up if you press the menu button on the remote does the menu look good?
Tim
This is a common problem on your model it sounds like you have a bad hyper module. This module is not made anymore but there is a company that is able to rebuild it for you. If you call a repair man to come and take it out of your tv and send it off for repair you can expect to pay $500-$700 for the repair. If you are able to solder i can get you in touch with the company and help you furthur. let me know what way you would like to go.
Tim
http://www.ptscorp.com/
This company will fix the module but you will have to either be able to un-solder it from the tv or have someone un-solder it from the tv and send it off to them. I have seen trained technicians brake the circuit board getting it out so if you are going to attempt this yourself please let me know so i can help you more
Thanks
Tim
I can see the menu fine. When I change a channel or turn it on the screen comes in fine at first for about a second then it is messed up. What I mean by messed up is that the signal looks almost like a blocked channel that is scrambled. Like when a premium channel is blocked and the signal is scrambled. I have checked all the blocked setting and I unblocked everything I could find.
Sure whats thier number or website?
