Question about JVC GR-DVX90EG Mini DV Digital Camcorder
Dvx 90 a problem
Unit comes on for 30 seconds then gives a error mesage and unit turn off. Bat is 100% and unit was cleaned and de-humidified etc but still not coming on. pls help
    Champion:
  • 277 Answers
Hi if you have the last messege on this page: http://www.fixya.com/user-guide/p398974,m16857,gm92/JVC-GR-DVX90EG-Mini-DV-Digital-Camcorder.aspx then .... good luck
Posted on Apr 03, 2006
  • ted windem Apr 03, 2006
    copy the whole URL to the title bar
Tank is full, but after a few minutes why does it stop and the 'Tank Empty' light comes on?
Reset light comes on, unit stops operating when tank is full ...
www.fixya.com/support/t384577-reset_light_comes_unit_stops_operating
Feb 6, 2008 - Question about Vicks Warm Mist V745A 1 Gallon Humidifier ... Tank is full. ... for about another 5 minutes when the unit stops, reset light comes on etc. ...the humidifier since the reset light keeps going on immediately after I turn ... water in the tank because of course, the heater is on, but no water is getting ...
How to Fix a Humidifier ' HomeTips
www.hometips.com/repair-fix/humidifier-doesnt-work.html
Jan 17, 2016 | Humidifiers
MY v5100 humidifier keeps reverting to an orange light. We have had the humidifier for about a year and have de-limescaled it twice, thinking that this might be the problem, but the orange light keeps...
First off, you should not have lime buildup if you used distilled water and NOT TAP Water. If some build up occurs, cleaning should be done using VINEGAR solution. Check the float valve and gaskets. Replace any filters. Clean nozzles or exit ports where mist is spewing from.
These units are low cost devices and repairing them is not economical.
Feb 06, 2018 | Vicks V5100N Humidifier
WE havent used this in a while- I was wondering if the mist barely comes out of the top? it seems like it's not coming out very much and I have it set high.
Fan problem is most common. Make sure the unit is not on carpet, blanket or has paper etc blocking the bottom. Second cause could be the nebulizer has gotten dirty. See the instruction manual for how to clean this.
Link to Manual:
http://www.crane-usa.com/manuals/HumidifierManual2008.pdf
Nov 19, 2009 | Crane Frog EE-3191 1 Gallon Humidifier
Venta-sonic VS 207 humidifier. Turns on but the display just flashes lights. I had it stored all summer (followed the manual instructions) and it's the first time I'm turning it on.
I had the same problem. During the cleaning process, the white float was installed upside down and humidifier water level sensor was unable to read the float. I removed the phillips screw and inverted the float with the dark ring toward the bottm. Quick fix.
Nov 08, 2009 | Venta Airwasher VS 207 3.7 Gallon...
Furnace blower motor turns on with no flame burning
Hi!!! You might have a bad flame sensor its a single rod located in the burners its white..If the unit runs and then shuts off and on and off.change your flame sensor..Good luckk..
Jan 04, 2009 | Honeywell Power Humidifier: Furnace...
Venta 207 digital humidifier
Caring For Your Venta-Sonic Humidifier
IMPORTANT!
Always unplug the unit before cleaning!
When to Clean Your Humidifier
 Clean your humidifier weekly or more often during heavy use, depending on your
individual water quality. Clean your humidifier before storing and after long periods
of storage.
 When cleaning the inside of your unit, keep water away from the air outlet. Exterior
may be wiped with a damp cloth when unit is off and unplugged.
Cleaning the Oscillator and Water Sensor
 Turn off the unit and unplug power cord. Remove tank from base and empty
reservoir in base. Use cleaning brush provided in base to clean off mineral deposits
and sediment from oscillator and water sensor. Do not scrape or clean with tools
that have metal parts. Be careful to not damage the surface of the oscillator.
ATTENTION: Damage to the oscillator may cause the unit to not work properly.
 The oscillator (ultrasonic transducer) is highly sensitive. Keep this important part
clean and treat gently. Do not touch the oscillator while the unit is operating.
 Do not use soap, cleaning agents, detergents, or other chemicals for cleaning the
tank and humidifier.
 After cleaning fill water tank (see instructions above) and return tank to base.
Storing the Venta-Sonic
Switch off and unplug power cord from A/C outlet. Empty remaining water from base
and tank. Clean tank and unit (see for instructions above). Make sure all parts are
thoroughly dry—allow at least 24 hours to dry. Leave the filling cap of the tank
loosened. This will keep the cap and gasket from sticking together. Pack Venta-Sonic
in original packaging and store in a cool and dry place.
You can find your manual at this link:
http://www.venta-sonic.com/pdf/vs207manual.pdf
Good Luck.
Apr 03, 2008 | Venta VS 100 Humidifier
Cleaning
I also need some information on cleaning, specifically the base. Not sure if I should use soap or if that will affect the nebulizer?
For cleaning the reservoir, just add a capfull of bleach to some water, and swish it around intermittently for about 20 minutes -- rinse until you don't smell bleach anymore.
Feb 22, 2008 | Crane Cow Humidifier
JVC GR-DVX90EG Mini DV Digital Camcorder Logo
74 people viewed this question
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Mohamad Abdan
Mohamad Abdan
Roger Goldberger
Roger Goldberger
Level 1 Expert
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
