Question about Canon PIXMA iP1800 InkJet Photo Printer
Pixma iP1800 need a solution to "ink absorber full" problem. prionter cannot print anymore.
  • 3 more comments
  • jcandrsn Sep 10, 2008
    I cannot access Users Guide in on-line manual
  • pietut Sep 10, 2008
    i need a resetter for this kind of printer
  • agustpatty Sep 13, 2008
    my printer canon pixma 1800 can not print because always paper jam
  • Anonymous Sep 16, 2008
    yes i have same problem that my PIXMA ip1880 show the box
    that ink absorber is full
    how to fix this problem
    Tx. aGoes
  • Anonymous Mar 13, 2014
    I got this message ink absorber is full. I cant print anymore.I'm using pixma ip1800
I have solution this problem but manual
1. Reales power cable
2. Push and hold power button
3. connect power cable
4. push resume button 3 time (fast)
5. reales finger from power button than push power button again
see what this way working, if no working repeat again
sorry, if my english not well
Tx
Posted on Sep 16, 2008
Why is my canon ip1800 printer still not printing after cleaning the ink absorber, I still get the message ink absorber is full
Shelly, Did you reset printer after cleaning absorber.
Press and hold the "Power" button and reconnect the power cord. When the printer comes on, release the button. Wait five seconds and push the "Power" button again. This resets the printer's internal memory and overrides the "ink absorber full" error code.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
The ink absorber is full Canon Pixma IP1980 IP1880
How to Clean Canon Ink Absorber
iP1800 ink absorber
Apr 07, 2016 | Canon Office Equipment & Supplies
Canon PIXMA ip1980 full ink absorber
This may clear the ink absorber.
There is ink absorbers located at both ends of the printerwhere the ink head move.
To dry the ink absorber, power up the printer and open the cover so the inkcartridges and print head will move to the middle of the printer.
Then take several sheets of absorbent tissue, fold it into a pad and place itinside the printer over the ink absorber on the far left hand side of theprinter to soak up the excess ink. You may need to change the absorbent tissuea few times. Then repeat the same procedure on the right hand ink absorber.
Closethe lid and the printer should now function normally.
Jul 18, 2011 | Canon PIXMA iP1800 InkJet Photo Printer
How could i fix my cannon ip1800 encounter this problem,ink absorber almost full?
This is a job for a canon repairer. the ink absorbers are in the bottom of the printer and the whole print engine needs to be removed in order for them to be changed. its a huge job. (and very messy too). After that the software needs to be reset to remove the message.
Jul 04, 2011 | Canon PIXMA iP1800 InkJet Photo Printer
In printer canon ip 1800 is showing ink absorber is full cant use the printer
Hope you find this information helpful.
The printer has a built-in ink absorber to hold the ink used during Print Head Cleaning, for example. Eight flashes indicates that the ink absorber is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the ink absorber becomes completely full, contact a Canon service representative. (You will need to replace a particular part of the printer. Canon recommends that you call for service as soon as this error occurs. Once the ink absorber becomes completely full, printing cannot be performed until the ink absorber is replaced
Mar 31, 2011 | Canon PIXMA iP1800 InkJet Photo Printer
Ink absorber is almost full problem is for cannon 1800
Hope you find this information helpful. The printer has a built-in ink absorber to hold the ink used during Print Head Cleaning, for example. Eight flashes indicates that the ink absorber is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing.Before the ink absorber becomes completely full, contact a Canon service representative. (You will need to replace a particular part of the printer.) Canon recommends that you call for service as soon as this error occurs. Once the ink absorber becomes completely full, printing cannot be performed until the ink absorber is replaced
Mar 23, 2011 | Canon PIXMA iP1800 InkJet Photo Printer
Received a solution to replacing the ink absorber on my Pixma iP1800 printer, however, it did not tell me where the ink absorber is located and if it's something I can get to. Please advise.
When the printer is _NOT_ printing, where do the print-heads go? Correct! They go to where ink-absorbers let gravity drain the excess ink into the absorbers.
Jun 09, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
Can I fix my full ink absorber myself? Canon iP1800
Only service centre can help you to replace the ABSORBER KIT.
May 25, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
I try to print on my canon ip1800 but it says the ink absorber is full how do i fix this
Hi It is a pad inside your printer witch absorbs the left over ink when it cleans itself this pad is full there only one way and that is to open it up with a screw driver it a messy job and put some other pad in place of it after any thing just to absorb the left over ink
Jan 22, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
The ink absorber is full... for the canon PIXMA iP1800
My printer is not printing for feed paper. It tells me that it has a paper jam, but there is no paper in the printer. Please advise
Dec 05, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
How to reset canon ip1800
ink absorber is full contact service" ???????????//
Oct 03, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Canon PIXMA  iP1800 InkJet Photo Printer Logo
118 people viewed this question
old marine
old marine
