Question about Rancilio Silvia Espresso Machine
I've had a Rancilio Silvia espresso machine for less than a year. No the indicator light does not go out, even after leaving the machine on for much time. The pump works, but the water comes out cold.
  • Anonymous Sep 22, 2008
    Reset the thermostat, a very small red button on the inside of the machine. Open the to lid to find it.
  • 76 Answers
This can easy be a wireing problem,see if all the wires is conected corectly, otherwize check the alement if its working.
Good luck....
Posted on Sep 10, 2008
Machine squeals, Why?
Honestly, no idea, bu you can check user's manual
http://expert-cm.ru/images/stories/shemy_tehnich/tech_silvia.pdf
and watch this tutorial video
How to make cappuccino on the Rancilio Silvia Espresso Machine
Might give you some clue?
Alos, have some interesting information about your machins
CoffeeGeek Rancilio Silvia Espresso Machine
May 19, 2015 | Rancilio Silvia Espresso Machine
My silvia is less than 2 years old. Yesterday I let the steam switch on and forgot to turn it off after steaming. It was on for about two hours. Then it won't heat up either. Should I get new part
On the happy side, if you tried to re-heat the boiler and found this problem straight after it failed, the thermostat may still re-set once the unit cooled down. So leave it a day and try again. Alternatively, it could be a burnt out fuse or on the less happy side, a burnt out boiler.
If no lights come on its a failed fuse. But if everything else is normal but it still wont heat, the best option is to take it for a service to a qualified technician as it may be that the boiler was damaged.
Jul 13, 2012 | Rancilio Silvia Espresso Machine
Why has my rancilio silvia v3 steamer stopped
Remove the top panel and check the 3 thermostats there, one of them tripped.
Jul 16, 2010 | Rancilio Silvia Espresso Machine
Rancilio Silvia: The steam works only for about 10 seconds
Remove the top panel and check the 3 thermostat on the machine one of them is not functioning properly, find the wire to the steam switch and trace it to the thermostat.
Jan 26, 2010 | Rancilio Silvia Espresso Machine
Rancilio Silvia coffee machine worked once and the
Remove the top panel one of the thermostats on the tank tripped, reset thermostat, and turn machine on.
Dec 25, 2009 | Rancilio Silvia Espresso Machine
Rancilio Silvia Keeps tripping the Breaker
Usually when that happens there is a problem with the element in the boiler.
Jul 06, 2009 | Rancilio Silvia Espresso Machine
No water from group head, Roncilio silvia
Hi Sounds like you have a stuck 3 way valve. Its behind the panel in the front. The panel slides to the right when the screw are out.
Jun 26, 2009 | Rancilio Silvia Espresso Machine
Rancilio silvia espresso coffee machine
Esprosso Parts http://www.espressoparts.com/ sells all parts for the Rancilio Silvia, including some customized and modified parts.
Mar 29, 2008 | Rancilio Silvia Espresso Machine
Rancilio silvia
Youve probably run your boiler dry and blown your thermostat/s. You'll need to have them replaced. You may get away with only having to replace one. It will cost about $80(AUS) to have done or less if you source the parts and do it yourself (not recommended).
Sep 08, 2007 | Rancilio Silvia Espresso Machine
Rancilio Silvia Espresso Machine Logo
97 people viewed this question
Top Rancilio Coffee Makers & Espresso Machines Experts
andy just round the...
Level 1 Expert
sonic boom...
sonic boom...
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
