Question about Denon DVM-1800 DVD Player
Need help! DVD tray won't open
Vacation Emergency!! tray won't open on the dvd player. don't hear the motor, doesn't even sound like it's trying. It worked last night. I took out a dvd this morning, still one in there.???? the read out says it's on disc 1 but won't do anything. denon 1800 multi-disc
  • winepro Jan 08, 2008
    My unit pauses around the one hour time when playing a movie. It pauses for just a split second. It also is very tempermental if the disc has ANY dirt whatsoever.
I unscrewed the case and now just use it with the case off.. not safe but still works...
Posted on Oct 28, 2007
    President:
  • 3,130 Answers
Soundsa as though there is a draw drive problem and that could be a motor or as simple as a belt?? are you sure tjhat the eject button works properly as I found out on these denons that the eject switch or push button wont make contact with the switch behind it because the Printed cuircut board shifted??
Posted on Apr 03, 2006
SOURCE:
B&O DVD1 PLAYER DOES NOT OPEN ON DEPRESSING EJECT. NO DVD IN IN THE PLAYER. CONNECTED TO B&O BEOVISION. HAVE TRIED DISCONNECTING POWER. ANY SUGGESTIONS?
if disconnecting power does not help then you will have to open the player and make the DVD tray roll out.
Aug 05, 2008 | Televison & Video
Dvd tray doesn't open
need to replace the motor charge belt
Aug 13, 2012 | Sylvania SSD803 DVD Player/VCR
Go Video DV 2150 - DVD door won't open at all. You can hear a mechanism working behind the closed door, but nothing happens and the door remains shut. Any advice??
There is a small belt under the loading tray which would have gone slack ( loose ) and the sound you hear is it slipping on the motor pulley. If you are confident you can remove the mechanism and turn it upside down and access this belt. Dismantle only if you can get the spare belt or your efforts will be in vain.
Sep 13, 2011 | GoVideo Go Video DVD/VCR Combo
Sony RDR-GX360 won't respond to any buttons on unit or remote. Only function that works is power button. Disk tray won't even open.
Try unplug,replug the unit back like about an hour later for the unit for resetting itself back to factory setting.If getting the same result the unit might have a shorted motor drive for the disc tray.Or shorted control panel on the unit itself.Well,this thing a basic DVD player only wright?If u can tries take it aparts and check out tries to repair it ur self that great.If u tries the shops,not worth it.Trash it.These basic DVD player only are very cheap now.U can get one brand new like $40 dollars.
Aug 11, 2011 | Sony DVP-S360D DVD Player
When loading a dvd it displays, "NO DISK". Is it
Hello
There are mainly three motors for most of the DVD players. One to spin the disc we insert in, other to load the laser pickup unit to-and-fro inside it to read the disc and an other one to load the tray mechanism 'in-out'. According to your description, the disc spins inside, and you can hear its spin. So motor which spins the disc has no trouble at all I should say. Then comes to the second motor that moves the laser assembly inside it. If it do not work, the laser pickup unit won't move and no reading will take place and 'No Disc' display will be the result. The last chance is with Laser Pickup Unit itself. Just get this unit repaired by any well experienced service technician or by the authorised service center, because, there are special tools to open this unit. As it is a compactable one, more care should be given to it while repairing. Suspect the second motor I described earlier, and the Laser Pickup Unit. OK.
Jun 14, 2011 | RCA DRC628 Portable DVD Player
Ihave a Cyderhome dvd player, and i cannot get it to play.The green light on but cannot get the tray to open,what can i do ?
You seem to have two different problems. The tray won't open and a DVD won't play. First use the emergency eject slot on the bottom of the unit to eject the DVD. Now test the drawer by seeing if the drawer will auto close when you push the drawer closed without a DVD. If you hear the loading motor running but the drawer will not close than check the loading motor drive belt. Also check the 12V and 5V power supply outputs. Low voltages are caused by bad filter caps.
Nov 20, 2009 | Cyberhome CH-DVD 300 DVD Player
Unable to open the door of the dvd --when you press the eject button to open the slot---the door does not open---everything else works
Quick trick
First let's find out if the motor is dead or
the magnetic clamp is to strong for the motor.
Press eject then listen closely for the sounds of struggling motor
if you hear it trying SLAP the top right over the DVD drive
and that should break the magnetic seal and release the tray
you may have to try a few times Press eject and open hand slap kinda
hard the top of the DVD drive , don't worry you won't hurt it.
if that works email me and ill tell you how to fix this.
Rob
rsheehan@northernsteeldesigns.com
Oct 14, 2009 | GoVideo Go Video DVD/VCR Combo
DVD Tray will not open
Uhm..
Unplug it/turn it on and off
Try to press the eject button and lightly pry the tray open with your fingers.
Call support.
Good luck
Dec 21, 2007 | Jwin JD-VD130 DVD Player
Denon DVM-1800 DVD Player Logo
430 people viewed this question
Top Denon Televison & Video Experts
 Grubhead
Grubhead
Darial Jr Lasaria
Darial Jr Lasaria
Are you a Denon Televison and Video Expert? Answer questions, earn points and help others
