Question about RCA P46924 46" Rear Projection Television
RCA P46924 46" Rear Projector TV
Would like to know where to purchase the power supply for this TV, also need to locate instructions on changing it out. I'm sure that is the problem, it shut off by itself, and when trying to turn back on sounds like a heart beat with no luck turning back on. I like this TV and would like it back up n running w/o paying a technician. Believe I can do it with instructions.
thanks
lynn
  • derietter Oct 19, 2008
    Hello. I have the same problem with my RCA same model. It happened during the 2nd game of the ALCS. What do we do after determining the power supply is good? Thanks for any help.
  • 4,234 Answers
First of all, we need to determine whether the power supply has a problem or if it is being told to shutdown because of a problem detected in the set. Are you familiar with electronics repair? Do you have a meter?
Dan
Posted on Sep 10, 2008
How do I change my projector lamp?
Instructions
  1. Front Projector
    • 1 Disconnect the power cable from your projector. Allow it to cool for 30 to 60 minutes. Lay the projector upside down on a table.
    • 2 Remove the lamp cover, typically located on one of the rear corners of the projector's underside. Depending on your projector, you will either have to loosen a few Phillips screws or press on one or two plastic release tabs to remove the lamp cover.
    • 3 Loosen the screws holding the lamp assembly in place. Grab the assembly by the handle and slide it out of the projector.
    • 4 Slide a new lamp assembly into the projector. Don't touch the glass on the bulb because it will damage the bulb. Tighten the retaining screws on the lamp assembly and replace the lamp cover.
    • 5 Turn the projector right side up and reconnect the power cable. Power on your projector.
    Rear Projector
    • 6 Unplug the TV from the outlet. Let it cool for 30 to 60 minutes.
    • 7 Remove the lamp cover. On most rear projection TVs, the lamp cover is located on the right or left side of the TV's rear panel. Remove the cover by loosening the screws and pulling the cover away from the TV. Certain manufacturers, like Mitsubishi, have the lamp cover in the front of the TV, near the left speaker. To get to the cover, you must first use your fingers to pry off the front panel below the screen, revealing the speakers and lamp cover. Loosen the screws on the cover and pull it away from the TV.
    • 8 Remove the lamp assembly. Loosen its screws, grab the handle and slide it out of the TV. If you have a newer Sony model, there are no screws. Instead, press the release tab to unlock the lamp assembly and slide it out of the TV.
    • 9 Slide a new lamp assembly into the TV. Don't touch the glass on the assembly, as the oils in your fingers will damage the bulb. Tighten the screws or pop the retaining tab into place.
    • 10
      Replace the lamp cover and front panel, if necessary. Plug your TV back into the electrical outlet and power it on.
Tips & Warnings
  • Touching the lamp assembly before it has cooled can cause a nasty burn.
Read more: How to Change a Projector Lamp ' eHow.com http://www.ehow.com/how_7307928_change-projector-lamp.html#ixzz1rpURlpva
Apr 11, 2012 | Office Equipment & Supplies
The picture went blank on my tv but I can still hear the sound. How can I get the picture to come back? All plug ins are tight. Thanks
When was the last time you changed the bulb for the projector? has this gone bad? If the bulb needs changed, consult your manual for instructions and if the bulb is good let us know.
Mar 24, 2011 | RCA HDLP50W151 50" Rear Projection HDTV
RCA D52W20 52--Delayed Power On and does NOT turn on now.
U DM power supply board have dead capacitors,before the capacitors have some functions left,that why u able to recycles by pushing the power buttons 3 or 4 cycles to get power to the tv.U have tools,soldering iron,solders,and know to do soldering?Tries website like Tvrepairworld.com to buy a capacitors kit,that design to replaced in the DM power supply board.Look around and replaced these dead capacitors,it alway bulges up or puff up on it top.Ur tv will power up and as normal again.
May 30, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
How To change Sony XL-5100 Projector Lamp with housing
  • Installation is Quick and Easy:
    In most cases, replacing your projection lamp is quick and easy. However, it is recommended that you consult your owner's manual for more detailed instructions:
  • Unplug your TV from your power outlet
  • Allow the lamp to cool for at least one (1) hour before replacing it
  • Remove the Lamp unit cover (Usually located at the rear of the television)
  • Unscrew the lamp housing unit
  • Remove the old lamp housing unit and discard
  • Screw in the new lamp housing unit
  • Place the cover back onto your TV unit Caution: Do NOT touch the bulb directly with your fingers.
  • Jun 15, 2009 | Sony XL-5100 Projector Lamp for Grand WEGA...
    Power supply sparks when tv is turned on
    That can either be the Flyback or the HV splitter. The flyback is located on the lower left hand side when looking in the rear and has a large red cable coming out of its top. The HV splitter is located in the front in the center of the set. These are both very easy and inexspensive to replace. I can post a link where you can get replacements with instructions.If you would like.
    May 08, 2009 | RCA D61W20 61" Rear Projection Television
    MY RCA 52 IN TV WONT TURN ON?
    MOST LIKELY, THE PROBLEM
    IS THE BULB USED IN THE SET?
    BY THAT I MEAN THE HIGH INTENSITY REAR PROJECTOR BULB?
    DO A SEARCH ONLINE AND THERE ARE COMPANIES SELLING THE BULBS AT A PREMIUM. YOU MAY WANT TO CONSIDER DUMPING IT.........
    Mar 14, 2009 | RCA P52920BL 52" Rear Projection...
    My 1995 RCA 52
    Replace capacitors in power supply,( 4 cap. ) 2.2uf 100V, 39uf 100V, 470uf 25V, Ready!!
    Apr 25, 2008 | RCA P52926 52" Rear Projection Television
    Fuse locations for RCA Scenium HD65W20
    there are 2 fusable devices in this chasis dt307 they are f14200 and f14100 fl200 6 amp 125 v is located Power supply pcb. left rear chasis. f14100 3 amp 125v dm1 power supply pcb left rear. Does the unit have no flashing light... good luck on your troubleshooting and if you need any help contact me via email at the my shop at willie@fordtv.com
    Mar 03, 2008 | RCA Scenium HD65W20 65" Rear Projection...
    Philips universal remote codes
    For the majority of phillips/magnavox universal remotes: Hold code search button down till red light satys on. Press the tv button and the red light should blink and stay lit. With the tv on, push the power button repeatedly until the tv turns off.(dont push the power button again after the tv turns off or it will go to the next code). Push the mute button to save the setting.
    Feb 07, 2008 | Panasonic PT-47WX53 47" Rear Projection...
    RCA P46924 46" Rear Projection Television Logo
    180 people viewed this question
    Top RCA Televison & Video Experts
    jason
    matt martin
    matt martin
    Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
