Question about Thetford Norcold DE0051 Refrigerator
DE0061 draws power when not cooling
My brand new DE-0061R installed on my boat draws 3.1 Amps when the compressor is running and 0.48 amps when the compressor is off. Norcold support says this is as designed and I should "return the unit to the place of purchase" if not satisfied. The unit is built in to the boat and requires bulkhead removal to remove.
Can I install an auxiliary thermostat on the DC power feed to stop the power draw when cooling is not required?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 171 Answers
Hi captstu,
I'm Harvey th Master Plumber.
Your question is: Can you install an auxiliary thermostat on the DC power feed to stop the power draw when cooling is not required?
I understand your frustration. I live on a boat. Since the fridge thermostat is reducing the amp draw when the compressor is off, just remember to turn off the curcuit when you leave the boat and emptying the fridge. You are probly doing this already. Since any modification to a new unit voids the warranty I wouldn't go down that path. The unit should have been tested before installation. Water under the bridge. I agree with the manufacturer. I would tear it out and get a warranty replacement. Sorry, Norcold is right, this is the least painfull way out. It is beter than the cost of repair.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 13, 2008
The rla on my weather king ac specs says 26 amps but a serviceman measured the current at 40 amps. he said the compressor was on its way out and recommended i install a new unit. is he correct? what would...
Hi, if a compressor draws that many amps above its running load amps, it is not normal at all. It would be tripping the breaker at 25 to 27 amps!! If the compressor is overloading that much, it wouldn't run at all.It could be that your outdoor coil is very dirty causing this reading. Take a water hose and wash it out good. Careful not to bend the aluminum fins when doing this.If the specs say 26 R.L.A., it wouldn't run at all at 40, no way at all. This tech must be green, or very fresh out of school.Wash the coil to bring the head pressure down, and see if it starts cooling. Any compressor that draws max amps will shut off on internal overload. If the compressor is on its way out, and he said its drawing 40 amps, it would be locked up, L.R.A, locked rotor amps. Wash that coil very well, as this is what causes high amps, and see what happens. He is wrong.Have them send a different tech out free of charge, and tell him what I have told you. If the compressor is 30 years old, it still could not draw that many amps, as the breaker, or fuse would blow in a second, or it would lock up! Please keep me posted,
Shastalaker7
A/C, Contractor
Jul 12, 2011 | Weather King Heating & Cooling
Ice cubes & frozen food thawed out, food in refrig not cold. Compressor runs for 20-25 second and clicks off, after 1-2 min comes back on. The a/c amps reads 8.5 wht wire and 9.5 on red wire to the...
You are cycling on the compressor overload, meaning the compressor is drawing excessive amperage, the overload takes it out then it cools down and tries again. the normal amp draw for those compressors is 3-4 amps. Have you checked the condenser fan and made sure the coil is clean?
unfortunately those compressors cannot be serviced
Jun 27, 2011 | Kenmore Side by Side Refrigerator
Hello bill willliams here i have a client witjh a reach in cooler the compessor in kickingf off an on every 3 to 4 sec off and on off an on what could be the problem
Most likely the PTC relay and run capacitor. However there is a value on the side of the compressor label that is LRA (locked rotor amperage) followed by and amp value between 14.7 amps and 21.9 amps for a 1/3 hp compressor. If the unit is drawing that LRA amperage and the compressor is not starting then the compressor is bad.
As a tech before making that change the compressor decision I wil ALWAYS install a new PTC relay / Klixon thermal-overload AND a run capacitor. IF after changing those 3 components the compressor is still drawing LRA amperage the compressor has to be changed.
With the every 3 - 4 seconds cycling.. and the thermal overload is not kicking off for around 4 to 5 minutes I really would suspect both the run capacitor and the PTC relay
Thanks for choosing FixYa,
Kelly
Jun 15, 2011 | Refrigerators
I have a Rheem heat pump/air handler; it draws 2.9amps with only the fan running, 13amps when the heat pump is running and 38amps with the heat strips on. My question is why the unit draws that many amps...
Sounds like it must be about a 2.5- 3 ton system. The 13amps has to be the compressor draw -normal. and 38 on the strips- normal. 2.9 fan -normal.
You may want to check your wiring to see where the outside unit gets its power. Theres nothing inside that can draw 13 amps. That almost has to be the compressor power wire.
Jan 27, 2011 | Heating & Cooling
Hi my botton frezer no working the compressor its hot
Compressors are normally 100-120 degrees when being cooled by a condenser fan motor. If there is no fan motor near the compressor then it can run up to 180 degrees, so the compressor temp by itself doesnt mean much. You can take an ampmeter and clamp it around one of the wires to the compressor to see if it is running, drawing anywhere from 1-2.5 amps or trying to start, in which case it may draw up to 20 amps every 3-5 minutes.
Oct 05, 2010 | Amana ARB8057CSL Bottom Freezer...
AC runs for 5 minutes and then circuit breaker
What else do you have running on hydro while AC is running? Such as coffee maker, microwave, water heater, fridge. That 30 amp breaker is your main breaker I assume, or breaker on pole your plugged in to. Keep in mind your AC will normally draw approx. 15-17+ amps momentarily when compressor kicks in to cool, then drop back to 12-15 amps when running normal. If your AC is drawing too much current, then you would only normally trip 20 amp breaker for AC in your panel. Try switching other appliances to gas operation while running AC, such as water heater, and fridge. Make sure incoming voltage is up to specs as well . (115-120 volts)
If water heater takes 5-8 amps, and fridge takes same when they are calling for power, you'll be close or over the 20amp mark when you consider your on board converter etc. as well. That only leaves approx 10 amps for AC that requires approx 15 amps to run, and up to 20amps when compressor kicks in. If you switch all those other items over to propane, and it still happens, then a current draw test should be done on AC unit to see if perhaps a capacitor is faulty, or possible compressor faulty.
Jul 22, 2010 | Dometic Rooftop RV Air Conditioner
Start up current draw
Lock motor Amps ( LMA ) is the current draw when the compressor starts.This draw of current is less then 1sec.The amp amount shoud be on the compressor Name Plate.This amp draw is also the amps used when the compressor goes bad and locks up then the overload kicks out.
May 21, 2010 | Kenmore 5 cu. ft. / 142 liter Chest...
Refrigerator installed under counter and stopped cooling
possible bad compressor. check amp draw of compressor. tech info is usally on model # tag on amps. If amps close to recommendation you could need a start kit but more than likly a compressor .
Mar 05, 2010 | Refrigerators
Power draw on start up
When the compressor first starts up it can draw as high as 15 amps but for no more then a second or two. After that it should run at 1-1.5 amp and will draw less as it continues to run. After 10 minutes it should pull anywhere from .5-1 amps.
Nov 04, 2008 | Haier White 2.7 Cu. Ft....
Kenmore chest freezer.
Most likely a bad compressor. You could try a new relay on it first.
Nov 21, 2007 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Thetford Norcold DE0051 Refrigerator Logo
199 people viewed this question
Top Thetford Refrigerators Experts
John Tripp
John Tripp
christian nielsen
john h
Are you a Thetford Refrigerator Expert? Answer questions, earn points and help others
