Question about RCA F32649 32" TV
RCA F32649 - Won't Recognize Ch 3
The tv no longer recognizes Channel 3. Subsequently, the cable box and satellite box will not work. It is not caused by parental control lock out or any other FAQ solutions. We have followed all the instructions in the owners manual, and on RCA's website. The tv worked one morning, and did not that afternoon. Nothing had been altered. RCA's "tech support" is a joke. No one answers. I really don't want to have to buy a new tv.
  • Karen Clinton Apr 03, 2006
    You can manually put it on channel 3 - but it is nothing but snow. We have tried doing the auto-tune, and it won't pick 3 up. When the cable was installed Friday before last - everything worked. We left to go eat, my husband turned it off, and when we turned it back on... nothing but snow. He swears he did not hit any other buttons - especially the "Who Input" button. At this point, I'm afraid we've tried to "fix" this so many times that we really have ruined it. Thank you for your help!!
  • Anonymous Nov 18, 2008
    Hello, Yes my problem is the same, that the TV cannot find Channels 2 & 3. Got new indoor rabbit ears with the digital converter. The old one-pole antenna on Sylvania TV picked up many if not all local & non-local channels. TV used to get 2 & 3 but not since the new antenna & converter installed. Need Ch 2 to tune the digital converter. Hoped new antenna wood solve this.
    President:
  • 3,130 Answers
What do you mean??? it doesent reconize channel three?? does it skip over the channel three or can you take a remote and manually put it on channel three and theres all snow when you put the set on channel three There is no magic wand to fix a set unless I get a few more magic words(HE HE) please indicate what you mean dosent reconize channel three??? and if im not mistaken there is a video input on ythis set and I used a set for my satallite for overr 5 years so far and the set was given to me as it has a bad tuner so I simply ran my sat. through a video input and have a great set get bacj to me please
Posted on Apr 03, 2006
  • Larry  Dillon
    Larry Dillon Apr 03, 2006
    ok this sounds like a tuner problem and could be as simple as a resoldering around the tuner grounds But a quilifyed tech who knows this problem can assist you if it is ,or tell ya that the tuner is bad.. Use the video inputs!!
Lost channel 3 to watch tv on uverse
you need cable box on when you search so the tv can find it
Feb 16, 2015 | Westinghouse SK-32H640G 32" LCD HDTV
Screen is all snow and channel 4 shows in the upper right hand corner. TV needs to be on channel 3, but trying to change it manually does not work; therefore, satellite tv does not work. I've checked...
Check your TVs settings. Check if channel skip option in on. If it is on, this type of fault occur. Turn it to off if it is in on condition. If the blue back screen option is there, just turn it on to avoid grains on unused channels.
Oct 13, 2010 | RCA F32649 32" TV
Satellite connection to tv doesnt recognize
At least you know the set does work. I'm also assuming your satellite receiver is working and that all your cables are good.
There are two ways to hook up to the TV: RF (antenna) and the A/V jacks. Maybe the seller was using the RF input (the threaded round connector where you screw on a cable connection, then choose channels with the set's tuner), and you're trying to connect using the A/V jacks (the red, white and yellow RCA jacks). If that's the case you need to switch the TV to those inputs. You may need the original remote to do that if the TV doesn't have a front panel TV/AV button.
The other possibility is you're connecting the satellite receiver to the RF connector and the TV isn't on the right channel (usually channel 3 or 4). If you're using the RF input, have the TV autoprogram and it should find the channel. Most sets can do that from the front panel menu button.
Hope this helps. Thanks for sing Fixya!
Feb 19, 2010 | Quasar SP-3235 32" TV
Tv not working with cable box
Insure your TV is set to channel 4. Then go into your TV's menu and make sure it's set to CABLE and not AIR. There is no need to program your tv, as long as it's on channel 4 and set to recieve Cable it will be fine.
Mar 26, 2009 | RCA F27665 27" TV
Tv will not program in digital signals; only anolog from direct tv box
Any TV hooked up to a cable or satellite box can only "see" one channel...the set-top box (STB) converts the channel you are watching to (usually) Ch. 3 or 4. With cable you can split the input if your TV has 2 RF inputs, with a dish that won't work.
That's why the TV stays on Ch 3 and the STB changes to whatever you want to watch.
Dec 20, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Rca tv
1) Buy RCA remote part # 240895 original about $25.00
2) Enter channel 00 for video sometimes works
3) Channel down 4-3-2-Vid 1, Vid 2, etc. sometimes works
4) Try Auto-Program Channels selection ( can be accessed on
front of set buttons or remote
Let me know ...........................................T.
Nov 04, 2007 | RCA F32649 32" TV
Cable connector repair
use RCA cables instead of ch 3
Oct 24, 2007 | RCA D52W15 TV
Cannot get DVD to Play on TV
Try the old RCA/GE channels of 90/91 or 92 to get to the inputs. Or try entering channel 00. Let me know if that works.
Feb 21, 2007 | RCA F32649 32" TV
No picture channel 2-3-4-5-6-7
bad tuner or gemstar module
Dec 08, 2006 | RCA F32649 32" TV
RCA F32649 32" TV Logo
143 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
